Coils freezing up on a/c unit - Heating & Cooling
  • 958 Answers
Hello quincy4,
a lot of things to consider of coil freezing up, first as doc jhon has stated, could be the filter. check and clean it out.
another thing would be the evaporator itself, if it is dirty, the coils would freeze up too. that you need a service guy to clean your coil. they do have aluminum cleaners that they use to bring out the dirt in between the fins.
then there is this undercharge unit where in a partial of the coil only will freeze( the start of cooling tubes). not the whole evaporator.
with this problem, you need a qualified tech to do it.
tnx 4 using fixya,
drcool
Posted on Sep 27, 2008
  • 943 Answers
Hi thanks for the question i would check the air filter this is a must it has to be kept clean the only other reason is if your trying to keep the room too cold the unit.has to shut down to let that ice melt so if your trying to keep the room too cold it will never shut down don't try to get 68 degrees
When a air conditioner freezes up can one put it on fan low speed
If the unit is freezing up then you have a problem. One is the air flow is to low going through the evaporator coil this could be caused buy a dirty filter, dirty coil and fan blade or low freon charge. the lower the fan speed the colder the coil temperature. the coils and unit should be cleaned every year. running your unit on low is not a good idea.
Jul 08, 2014 | Samsung AW1203B Air Conditioner
Coils freeze
Either your coil is blocked with paper or wrap, or you have a refrigerant leak in the coil and the little bit of gas that's left is flashing as it enters the coil. Make sure that the cooling coil and condenser is clear and the fans are running. That's all you can do without refrigeration tools. Good luck and hope this helps
Apr 22, 2014 | True Refrigerated Sandwich Prep Table 72"...
My A/C freezing its coils, while the fans keep running. The AC unit (outside) keep running and never stop caused the coils freezing. It doesn't matter when I turn off or set it to Cool position, the...
Sounds like the contactor in the condensing unit is stuck. That is why it will not turn off when the thermostat is satisfied. If the inside air handler is not blowing and the outside condensing unit is running, then this will cause the inside coils to freeze up rather quickly.
The contactor is located in the outside condensing uni in the electrical compartment.
If it is sticking it will need to be replaced.
Sep 07, 2011 | Heating & Cooling
DEHUMIDIFER COILS FREEZE OVER, WHETHER MACHINE IS RUNNIG ON LOW OR HIGH. FILTERS ARE ALL CLEAN.
Turn the Master ON/OFF Switch to OFF, unplug the unit and allow it to thaw out completely. You may want to put some old towels under it, to absorb the dripping water. Once it has completely thawed, remove the bucket, the air intake filter and the face of the cabinet. You should now have access to the coils. Clean them with a mild soap and warm water. Rinse and thoroughly dry the coils. Once they are totally dry, spray a very light film of WD40 on the coils and then wipe off any over spray. Reinstall all the remove parts and test the unit.
Keep in mind, if you are using the dehumidifier in a basement, the air temperature at floor level is colder than at chest level. Dehumidifiers don't work well between 40 & 60 degrees F. (Unless, they are a low temp unit). Any lower, the coils will freeze. Raise the unit up off the floor onto a sturdy table or counter top, that can hold the weight of the unit plus, a full tank of water. In a basement application, doing usually solves the problem of freezing coils.
If after doing all the above, the coils still freeze during operation, the compressor may below on freon and needs to be recharged. Or the defrost sensor on the unit, needs to be replaced.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 08, 2011 | LG Dehumidifiers
My lines are freezing and the ac works sometimes and sometimes it doesnt. How do I avoid the lines from freezing
you need to check your filter to start with if thats good make sure all you vents are open and your returns are free from abstruction
Aug 25, 2010 | Honeywell Heating & Cooling
Frigidaire central unit freezing up leaking
The coil freezing can be caused by a couple of things. 1) Not enough air flow over the coil or 2) A low refrigerant charge. First make sure that the indoor fan is running. Then check your air filters and make sure your evaporator coil is clean. After that you can get the refrigerant charge checked. The lower the refrigerant pressure is, the lower it's boiling point is and when it gets below 32F then the evaporator coil and usually the low pressure line freeze up. The leaking you were talking about is probably from the ice melting. Hope this helps.
Jun 06, 2010 | Frigidaire Heating & Cooling
My unit is 9 years old Ruud RCGA-60AIGH24B seems
It's possible that there is gas leak causing part of the coil to freeze. The cost will depend where the leak is.
Jul 12, 2009 | Heating & Cooling
Coil freezes up
Usually when the indoor coil freezes up you either have dirty filters or coil but if you had this unit replaced last year your coil and filters are probably OK so you probably have a leak in the unit and are low on refrigerant.
Apr 24, 2009 | Heating & Cooling
Indoor unit freezing up
The coil probably needs to be pulled and cleaned with a power washer. Usually what happens is the coil becomes dirty over time and when the filter starts to get dirty as well, it will cause the unit to free up. Also it could also be a little low on refrigerant and when the temps change, it can cause the coil to freeze up. But I bet it is in need of a good tune up and coil cleaning.
Mar 21, 2009 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
488 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
