Computer pc pass word forgotten
Pass word forgotten. unable to proceed further with the hint. can I rest the CMOS clear shorting link to clear the present pass word.
Problem is after initial start up, the window is blocked by the pass word. I can't proceed with the hint provided. please help me
  • 4 Answers
You should actually have 2 accounts. One is called Administrator and appears when you start your operating system in safe mode. It has no password by default so you should still be able to access it.
Restart your computer and keep hitting 'F8' until you're prompted with a menu. Select something along the lines of 'Start Windows In Safe Mode' and Windows will load. Just login to the administrator account and remove the password.
It might also be a good idea to put a password on the admin account and keep it somewhere safe.
If that doesn't work then reset the password via the jumpers on the MOBO. See below:
Assuming that you have a Pentium Processor:
Shut down your PC. Detach Power plug. Open your CPU case. Touch casing or metal to ensure grounding. You will see 3 pins on the mother board. In that 3 pins first 2 pins are closed with a jumper. Take the jumper off & replace it on the other two pins. Now try to turn on your PC. It should open Windows without asking you for password.
Posted on Sep 27, 2008
  • 781 Answers
Resetting your cmos won't reset your windows password. (assuming you're referring to your windows operating system user account password to log into windows)
try this:
1. try to log into your system with the administrator account (if you know your administrator account password or if the administrator account password is blank)
a. if windows xp home:
* restart your computer and as computer boots start pressing the f8 key with 1 second intervals to get into advance startup options (if the computer gets to the windows logo with the little bars going accross you missed it.. so restart and try again).
* when you get the advance startup options screen with the arrow keys navigate upto safe mode to select and press enter.
* log into your computer using the Administrator account (if it doesn't have a password you will go right in).
*. you may not be able to reset your password but you may be able to access your files and create another account with administrative priviledges (computer administrator account) that may allow you to get access into your computer again.
b. if windows xp pro.
* start your computer and at the log on screen enter the following sequence twice: ctrl-alt-del.
* enter the user: Administrator or (administrator) and press enter (here again if the administrator account does not have a password you will be in luck and you will go right in)
* go to start>right click my computer>manage>select user and groups>users>go to the user that corresponds to the you (account you forgot your password for), right click and select all tasks>set password> reset the password as needed.
2. if you don't have your administrator account password or you just found out the administrator account is not blank..
this are some tools and procedures that may work:
Dear expert Sorry my english writing is not my strong point!! my problem is that i can't start up because there is a startup password. disconnecting the cmos battary does not clear that password the...
Sadly there is no easy fix for this, you will be presented with a pass request code when you have tried and failed to enter the correct pass? This requires a response code, which you need to get from HP
Jan 06, 2011 | HP ProBook 4710s Notebook
My Dell XPS 400 PC will not Boot up past the "System password"
Both the system password and the BIOS password are set in the BIOS CMOS. You need to clear the CMOS.
The online Dell service manual for the XPS 400 provides a clear and detailed procedure for clearing the CMOS. It's just a matter of moving some jumpers around:
If you are not used to working inside computers, start with "Removing the computer cover", then go to "System Setup" and click on "Clearing Forgotten Passwords".
Another method is to unplug the power cord and remove the CMOS battery for a 1/2 hour or so. For details on how to do that, try this website:
May 22, 2010 | Dell XPS 400 PC Desktop
How do I clear the CMOS password on my Satellite
To remove the bios (cmos) password, With notebook turned off;
Open Wi-Fi Cover that's located under the laptop and remove the WiFi card, locate & Short Out pin JP1 for 15 Seconds, or short out pin G1 for 15 seconds.
Sometimes you have to short the pins out while turning the laptop on.
The power on (bios) password will now be cleared so you will need to enter the bios to input the date and time.
Dec 02, 2009 | Computers & Internet
Forgot my passwords and i do not have the software cd anymore
If you don't know the power-on password for your System, forgotten it, or its not accepting it again, then you might have to reset your CMOS.
Which means you will have to unscrew your system, remove all cables supplying power to the board, locate the CMOS battery and remove it for a few seconds, then replace it and screw your system back.
This will reset your system's CMOS back to its Factory default settings.
(If you cant unscrew your PC yourself, you can just get a good technician to do it for you instead.)
But if it is Windows Logon Password you are referring to, then let me know, so that I can help you with it.
Hope it helps.
Dec 02, 2009 | Dell Studio 1737 Laptop
ACER ASPIRE 4730Z. How do I clear the CMOS (password)?
Below is the steps for clearing the password. Below that is the link for the manual, the picture of the jumper tabs is on pg. 153, good luck
Steps for Clearing BIOS Password Check
If users set BIOS Password (Supervisor Password and/or User Password) for a security reason, BIOS will ask
the password during systems POST or when systems enter to BIOS Setup menu. However, once it is
necessary to bypass the password check, users need to short the HW Gap to clear the password by the
following steps:
• Power Off a system, and remove HDD, AC and Battery from the machine.
• Open the back cover of the machine, and find out the HW Gap on M/B as picture.
• Use an electric conductivity tool to short the two points of the HW Gap.
• Plug in AC, keep the short condition on the HW Gap, and press Power Button to power on the
system till BIOS POST finish. Then remove the tool from the HW Gap.
• Restart system. Press F2 key to enter BIOS Setup menu.
• If there is no Password request, BIOS Password is cleared. Otherwise, please follow the steps and
try again.
NOTE: The steps are only for clearing BIOS Password (Supervisor Password and User Password).
Oct 11, 2009 | Computers & Internet
How to get my computer unlocked have forgotten
If you've forgotten the BIOS password you need to short the CMOS by setting the jumpers or remove the battery.
If you've forgotten your Windows password you can download a program here and burn it to disc and follow the instructions.
Sep 23, 2009 | Computers & Internet
We cant reset our password because we dont have the wizard cd.not only that we never set the password anyway the computer came with it and we want to set our own password.
Is that a Bios password? then take out its cmos battery for a short time then place it back again this should rest to its default configuration without the password or clear it using its cmos reset jumper header on the motherboard. Consult manual for more info.
Do this when unit is off and unplugged to source outlet. Touch first the frame of your case to free you of static.
If this password is from user accounts. Log on to it goto control panel goto user account select account to be set with your password enter old pass,new pass then confirm it. your now set. Do this changes using account with administrator privilidge.
Hope it helps
Apr 14, 2009 | Acer Aspire X1200 Desktop PC - Athlon X2...
By pass it by software or use omnipoten password. here
Apr 13, 2009 | IBM ThinkPad X60 Tablet PC
When I turn my laptop on the screen is black and is asking for a current pass word.
As far as you described, someone may have put a password on the CMOS chip so every time you turn on your computer, it will ask you for it.
If you want to clear it, you can try by opening the case of the computer and clear the CMOS values by shorting the Clear CMOS pins. If you cannot locate it then you can unplug the computer and take out the button battery on the motherboard and wait for a few minutes before putting it back in.
If its a laptop then you'll probably have to take it hack to the retailer and get it cleared by manufacturer.
Oct 08, 2008 | Averatec Computers & Internet
Computers & Internet Logo
205 people viewed this question
David Payne
David Payne
