Question about Garmin Nuvi 660 GPS Receiver
Nuvi 660 Speaker
My speaker also bit the dust. I pulled the case apart, and removed the speaker and have hunted all over for a replacement speaker, but can't find one. Does anybody know I can purchase one? Thanks Dave.....
  • wildmack Oct 03, 2008
    Thanks for the help. I was able to order the speaker for under $20.00 and should arrive in 7 days. appreciate your fast responce to my problem....
  • PhilGarmin Oct 09, 2008
    Same problem cant locate a speaker to replace with. Please can you help by showing a link to where I can get a speaker from.
  • Garmin Master
  • 2,130 Answers
Hi Dave,
Please read the article I wrote on this problem. You should now have the info I gave you to find a replacement speaker. I would appreciate you voting on my solution for you.
Thanks,
- Jim
Posted on Oct 01, 2008
No volume on a garmin nuvi 660
Please see this link for troubleshooting information. In many cases this can be just a wrong setting but it is possible that the speaker is bad or a bad headphone jack.
http://www.sharc.net/gps_audio_repair.htm
Too much info to retype here
- Jim
Apr 04, 2011 | Garmin Nuvi 660 GPS Receiver
MY NUVI 660 SUDDENLY SOUNDS LIKE IT'S TALKING IN A CAN....VERY TINNY AND IRRITATING.
Most likely the speaker has failed. try plugging in a set of headphones. If the sound is good there, then the speaker has failed and needs to be replaced. If you need more information, you can look here:
- Jim
Jan 26, 2011 | Garmin Nuvi 660 GPS Receiver
THE SPEAKER ON MY NUVI 660 SUDDENLY SOUNDS LIKE SHE IS TALKING THROUGH A TIN CAN. VERY TINNY.
Most likely a defective speaker. Try using headphones. if the sound is good there, then the speaker is bad and needs replaced. More info on this topic can be found here:
- Jim
Garmin nurvi 660. speaker failed. how do I split the casing to get to the speaker and replace it. Where do I buy a new speaker.
What do you mean by Failed ? Is it crackling, hissing any sound ... do you have it on mute, it the correct language to speak chosen?
If you can not hear the street names anymore see if the proper language is setup,,, go to Tools... Settings....Language ... under Voice make sure one is picked ending with ( TTS ) text to speech
It is Muted on main menu press Volume.. is there a checkmark in mute remove it, OR on bottom of screen you will see FM Trans press that.... on next screen is there a checkmark in FM Tranmitter if so remove it
If all fails I believe Best Buy will replace speaker
Nov 08, 2010 | Garmin Nuvi 660 GPS Receiver
No sound from Garmin nuvi 760 by any method
Sounds like your speaker went south. Since your fm transmitter is working I'll be your earphone jack is too. So you could always use an earphone. Only other option is a speaker replacement.
Dec 20, 2008 | Garmin Nuvi 660 GPS Receiver
Speaker of garmin nuvi 660 doesn't work anymore
Bruce,
I measured a speaker on a Nuvi that I had opened up on my repair bench. It measured 7.8 ohm. I'm pretty confident that your speaker is bad.
- Jim
Sep 05, 2008 | Garmin Nuvi 660 GPS Receiver
Audio gone from my gps garmin nuvi 660
If you can hear audio through the headphone jack but not the internal speaker jack, then the speaker is bad.
This is a problem I have seen many times before. I will be posting an article soon on how to replace the internal speaker, however this is not a repair that just anyone can do.
You have to have skills in dissassembly & soldering.
- Jim
Jun 09, 2008 | Garmin Nuvi 660 GPS Receiver
Garmen nuvi 660
- Jim
Mar 21, 2008 | Garmin Nuvi 660 GPS Receiver
Stop transfering voice from Sony Ericson P910i and Garmin Nuvi 660
Can you update the firmware on your unit
my k800i sony phone had a problem synchronising and would freeze, then one day the nuvi 660 updated the firmware by itself and has been fine since, only problem being the volume, a bit low when trying to contest with large diesel engine, onboard speaker keen to distort over 80% volume
Feb 08, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
248 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
