Question about Samsung CLP-500N Laser Printer
Black dotted line
Hi i have a samsung laser printer and every time i print a document there seems to be a dotted line across it, giving a blank area
    Problem Solver:
  • 13 Answers
Sounds like the imaging unit may be scratched.
Posted on Oct 26, 2008
Konica Minolta 2430 DL has Smudges or dots on page
Not an expert on this brand of printers but it looks like dirty feeder rollers to me. Try cleaning them and Print a Blank document and see if the marks show up
Jan 24, 2014 | Konica Minolta magicolor 2430 DL Laser...
Black dots/blotches on the sides of printed sheets - whats is the cause and how t to fix it
If you have random blotches on both sides of the sheet, your printer probably needs cleaning, especially in the fuser section. If the fuser is difficult to get at, here's a good cheat developed for HP LaserJet 6 printers: Use a basic graphics program such as Microsoft Paint to draw three solid black rectangles about 2.5" top to bottom, going all the way across the paper (the space in between is not critical - the key is that you go as close to edge-to-edge as you can get). Print out this sheet.
Put the sheet back in the paper tray so it will print on the blank side (usually printed side up). Open up a quick text processor (Notepad in Windows). Type a single space, then print (some text editors won't print a document with no data in it). Dirt in the fuser will get stuck to the black areas on your cleaning sheet. Test your work by printing another copy of " ". Repeat with a new cleaning sheet if necessary.
May 02, 2011 | Brother HL 2140 Laser Printer
When I copy there are black lines across the page. I changed out the cartridge for a new one, but it still makes the lines.
Lift the copy bed cover and locate the **** glass (it is about 1" wide and sits on the left of the large glass)
Use a microfiber cloth, and a bit of water, and remove the debris from this **** glass. Make sure it is clean, then clean the white bar on the underside of the top cover (It will sit on that **** glass)
take a blank piece of paper and copy it through the feeder, if you have lines on the page that prints, you need to look harder for a spec on that glass. a small dot will create a line on any document fed through the feeder. A dot on the large glass will print only the dot as the paper is not moving over it.
Jan 13, 2011 | HP Laserjet M2727nf Multifunction Printer
Ricoh CL7100- Black Dots on all printouts
What are the correct colour settings for optimum colour printing for Ricoh Aficio Cl7200
Apr 12, 2010 | Ricoh Aficio CL7200 Laser Printer
Deskjet F380 is normaly printing but it will print blank
If the printer is printing blank pages, make sure you are using the correct printer driver and make sure the paper size is correctly selected in the driver. If the printer is printing black only, the Ink option in the printer driver may be set to Black instead of Color or a setting in the software may be set to print black only. Also, the print head nozzles may be clogged. From the Utility section found in the printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Performing up to 6 cleaning cycles is not uncommon if the print heads are severly clogged.
Feb 04, 2009 | HP DeskJet F380 All-In-One Printer
Black dotted lines accross the whole page
If the whole page is covered with stuff that's not supposed to be there, and that stuff sometimes changes shape or color on each page. then you look to the DRIVERS and connection 1st. Corrupt printer memory can also cause this.
If the corruption tends to be consistent across print jobs and it's only on certain spots on the page, you can start to look for mechanical defects.
Can you describe in more detail?
Jul 18, 2008 | Samsung CLP 300 Laser Printer
My Hp 1020 printer is printing full black pages.....
is this a laser printer? have you replace the toner cart?
Dec 12, 2007 | HP LaserJet 1020 Printer
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Samsung CLP-500N Laser Printer Logo
106 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
