It's not as easy as popping off the back like some watches to replace the battery. The 4 screws on the top bezel are not the ones to remove. Look at the back side of the watch and you'll see 4 really tiny pinholes. You'll need a jewelers screwdriver small enough to fit into the holes to remove the 4 screws. Once you do that, the two halves of the watch come apart with a little pressure. It takes a little prying to get the case to separate. Once you do that, you'll see the battery. Be careful with the waterproof gasket as you'll need to put that back in the same position to keep the case sealed. The gasket is really delicate. You might consider taking it to a watch maker to change out the battery if you don't have the tiny (and I mean really tiny) screwdriver to remove the 4 back screws.
SOURCE: Steinhausen watch adjustment?
To set time, you need to unscrew crown anti-clockwise direction if you have a screw-in crown watch. You need to softly and slowly pull the crown out a little bit. The best way to do this is to use first and second finger and use finger knuckle as a lever in order to pull the crown out with as little force as possible. You can feel a little "click"! Now you can set the time by turning it anti-clockwise. This would turn the minute-hour hands forward until you set the right time. When time is set, push the button back and screw the crown clockwise for a few rounds to ensure it is screwed back tight.
SOURCE: how do I set time and date on my automatic Steinhausen watch?
you can refer to the customer service on the Steinhausen
homepage:
http://www.steinhausenonline.com or call free: 24/7(800)208-2607. they can offer you the best advice.
