Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Freezer works but frige dosent get cold enough.
Side by side about fifteen years old need to know what type freon to charge it with
  • 750 Answers
Welcome to fixya richarddl53,
You said, you have a side by side about fifteen years old need to know what type freon to charge it with.
The freon that's used in the old refrigerators is not legal now!
They started using a newer kind of freon years ago that does not deplete the ozone layer.
Yes you are low on freon, but that's because you have a leak somewhere.
And if by chance you could acquire the freon that you need to add into the older model fridge, it will just leak out again shortly!
My opinion is that you should not put good money into bad!
A new refrigerator uses less electricity than a fridge that is ten years old.
And yours uses 10% more than that!
you will see the differents in you utility bill as it will pay for it self in a few years!
I just read this report you may find interesting.
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Posted on Sep 27, 2008
The freezer works great but the frige is not very cold. Its 2 months old
If brand new should have 1 year parts and labor warranty. Call them. Get it done free.
But no warranty. Don't worry. This is nothing major.
Major cooling happens in Freezer. If it is reaching cold enough then your compressor, gas etc is good. Your problem is little cold air needed to fridge is not getting there.
Sep 26, 2014 | Refrigerators
Side by side Whirlpool in insulated cold garage ompressor seems to be running all the time, freezer not working fridge is warm
Sounds like low on freon. Some refrig. has a charging port. It may even say on name tag what type of freon to use. You need a guage to check if unit is low on freon.
Jan 20, 2014 | Gladiator Freezerator Top Freezer...
I have a 2 door fridge, with the freezer at the bottom. My KIC fridge is 4 years old. My problem is that the freezer is cold, but the fridge is warm. I desperately need help, what cold this be ?
Pull it from against the wall, to let it breath. The condenser is usually in the back of the frige...It can also be a problem with the compressor or it's simply loosing freon. Make sure doors shut with a seal too. Try adjusting both thermostats too.
Apr 19, 2011 | Refrigerators
Not getting cold enough to freeze, How to check Freon
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 05, 2010 | Kenmore 53082 / 53084 Side by Side...
Blowing cold air but not cold enough to keep frige cold
if one of the panels in the fridge has frost on it, the evaporator coils may be iced up. this restricts the cold air flow. to defrost: empty the fridge and freezer, turn it off, remove the panel in the freezer that has the frost, use a hairdryer and defrost the ice buildup, sop up excess water, dry it up, replace the panel, turn it on (while it's empty), set the temp halfway, and close the doors. when the compressor turns off, fill the fridge. if the panels are frostless and the coils are warm, you may be out of refrigerant from a freon leak somewhere. it might be cheaper to replace the fridge.
Jul 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Trubleshoot refrigerator staying cold enough
First review the troubleshooting steps in the instruction manual. Check the freezer and frige temperature setting control knobs. Make sure the fan, coils, compressor etc. are clean. Check the door seals, especially at the bottom. If all that does not work, do some more online research (which is what I'm up to right now because I am faced with the same problem).
Sep 02, 2008 | Admiral 26 cu. ft. Side-By-Side...
Side by side Sub Zero not cold enough.
How old is "OLDER" ? If there is no frost buildup on the back wall of the freezer you could have one of two problems. On older units the compressor wears out with years of service and no longer pumps efficiently. Or it could possibly be low on refrigerant charge. ether one of these two problems is a sign that is time to update to new unit.
If you have frost buildup on the back wall of the freezer section you then would have a problem in the defrost circuit attributed to the timer, defrost heaters or defrost thermostat.
Jun 11, 2008 | Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
187 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
