Question about Amana Refrigerators
Hi, I have the amana drb1901cc bottom freezer. I think the compressor is out, but how do I check it?????? When plugged in the lites come on but no fans or compressor is there a reset button or something I could check out???
  • trickit Sep 27, 2008
    Hi, where or what does the defrost timer look like? can I jump/bypass it to check if the compessor/fans will come on??????
  • 943 Answers
Hi thanks for the question i don't think you have a compressor problem i think the fridge is stuck in the defrost cycle you need a defrost timer thanks the appliance doc
Posted on Sep 27, 2008
Problem with the Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Clicking, buzzing, compressor too hot, thawed out freezer, fridge is semi cool
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
Oct 10, 2010 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana Bottom Freezer, Neither freezer nor refrigerator is cooling
Contact the for tech advice, they are very knowledgeable about these types of problems and what causes them, the service is free and they can sell you the needed parts after you chat with them online.
Apr 20, 2017 | Amana ARB1917CSR Bottom Freezer...
Freezer not freezing nor ice maker
Is the refrigerator still working? Is there any cold air in the freezer? If your compressor stopped working it would cause the refrigerator to be warm also. I had a problem with my amana refrigerator where the freezer wasn't getting cold enough and it was due to a condenser fan running intermittently. i replaced the fan and was back in business. i would check to make sure both your fan and your compressor are operating...
Mar 03, 2010 | Amana ABB1927DE Bottom Freezer...
Compressor makes a light tinny motor noise and freezer is not working
If not cooling the pull away from the wall, remove cover over compressor, unplug and feel the top of compressor to see if too hot to hold your hand there. Inspect the fan by plugging back in for a few minutes. I think either a fan or the compressor start components are failing. If hot do not keep the plug in the wall until we can check it out. If that is the correct model number I may can find a service manual and the you could follow with me. If ABB1927DE is not your model I need to know so we both will be working on the same refrigerator. Thanks, Sea Breeze
Dec 21, 2009 | Amana ABB1927DE Bottom Freezer...
My amana bottom freezer model #abb1921dew smelled like smoke and the compressor was not running. I unplugged it over night and when plugged in again it appears to be running fine. Any suggestions?
I would suggest replaceing the overload/relay w/capacitor .
Pt # 67005560 . This piece , easily plugs onto the side of the compressor . If you replace it now , since it is already burnt , it would save you the trouble of replacing it later , when the compressor will not restart . It will happen again , due to the burning .
Nov 22, 2009 | Amana ABB1921DE Bottom Freezer...
I have an Amana bottom freezer frigerator. The
Possibly a bad relay/overload or shorted run capacitor.If it was built between 2002 and 2005 it may be a bad compressor in which case you would want to check the warranty for possible coverage.
 the relay/overload and run capacitor plug right into the compressor on the left hand side.
 IF it isn't under warranty and the Oem part won't get it going pick up a 3in1 hard start for it they are easy to install and will get it working for you.
Sep 05, 2009 | Amana SXD524VW Side by Side Refrigerator
Not cooling properly
Sounds like your coils are getting plugged,(excess ice in and around the coils)if you have a cooler or some other place to keep your food cold,turn off or unplug the fridge,you want to defrost it,for the freezer place pans of hot water in it to speed up the process,leave doors open,should only take around 4 to 12 hrs.A good time to clean it to lol.
Hope this helped.Let me know.Also rate me.
For more help go to live chat.
Jan 30, 2009 | Amana ABB1927DE Bottom Freezer...
Compressor not starting
the thermostat is in the fridge and fridge runs at about +4-6degC. if temp in the garage is about that value, appliance will not want to turn on
Dec 01, 2008 | Amana DRB1901C Bottom Freezer Refrigerator
Buzzing intermittent
most likely the compressor relay is the clicking noise but i think the problem is most likely the compressor is starting to go bad and is lcoking up. if the refig is under 5 yrs old it is most likely still in warranty by amana
Dec 09, 2007 | Amana ABB1927DE Bottom Freezer...
Amana bottom frezzer refrigerator
Gazzo, You are on the right track. I've been finding a lot of compressor failures on these Amana's. It's possible that the overload and relay for the compressor failed, but Im more inclined, from what I've seen, that the compressor is the problem. The compressor is covered under warranty, parts and labor for 5 years. I would call for warranty back.
Jan 04, 2007 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
270 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
