I'm looking for a quote to replace a broken monitor on my Acer Aspire 3690 Laptop. Son dropped it and it is cracked and will not show a picture. Can anyone help?
  • 781 Answers
How do I fix / replace a cracked screen on Acer Aspire V5 - 571 LAPTOP
Take a look on Amazon for the screen and then google the term "disassemble Acer Aspire V5-571P. There are most likely videos showing how to do this.
May 16, 2015 | Acer Computers & Internet
My daughter just dropped her acer aspire netbook. Only half of the screen is visible the other half is white and black with a line down the middle
Dropping the netbook will have probably broken the LCD screen.
There is no other way to repair the problem without replacing the screen itself. You can however use a external monitor and use the keyboard to toggle between the two screens.
I know this is probably not what you wanted to hear but unfortunately LCD screens are fragile so a good knock can crack them causing only one half or the part or the screen which is not broken to show. The backlight itself sounds like its working as there is still light showing behind the cracks.
Regards.
Mar 14, 2010 | Acer Aspire One PC Notebook
How do i bluetooth pictures from my nokia 2690 to my acer aspire 3690 notebook
Hello
First you need to install the bluetooth driver software [that can be found on the acer CD that came first time with your laptop or just look here www.acer.com ] , then reboot your system . after that turn on the bluetooth buttons on your laptop and on the device you want to connect your laptop with for example [Cell phone ] . make on of them look for the other . then you need to pair them , so that you don't need to do that again .
Just look around in the software that you already installed and problem will be solved .
your rating is very important for me , that's why I've helped you .
good luck .
Jan 24, 2010 | Acer Aspire 3690 Notebook
Fan for my acer 3690 spins, green light is on but no display show
Look to See If Your Hard Drive/Data Indicator Light is on and blinking (or solid)..
You need to try and hook up a desktop monitor to the laptops serial port.. Reboot with the External Screen Plugged Into The Laptop.. If You See Windows Booting From The External Monitor - Then You Have A Faulty Screen, or possibly a faulty Display Cable.. Most Likely The Screen Has Failed Though... Also, Hold The Screen Up To A Bright Light while its powered on, You Might have just lost the backlight and have a display still, It will be REAL faint but holding it up to a light and looking to see if you can see Windows Running..
If No Display on the External Monitor When Connected To The Laptop, Then You Have GPU/Graphics Failure, Due To Thermal Damage.. This Is A Motherboard Issue Because The Chips Are Integrated.. A ReBake/ReFlow Of The Chips Will Get Your Video Back, Or Replacing The Motherboard.....
Nov 15, 2009 | Acer Aspire 3690-2196 Notebook
Computer is on, screen stays black
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 04, 2009 | Acer Aspire 3690-2196 Notebook
ACER cracked screen..external monitor???
Hi there.
The keyboard toggle you are using is the correct one.
Sometimes you have to hit Fn + F5 a couple of times to stay on there is no real set time. Make sure Fn + F6 is on so the laptop screen stays on.
Good luck and thanks for using FixYa!!
Apr 21, 2009 | Acer Aspire 5500 5570-2609 Laptop
Monitor flickering and rolling
Thanks for the git back: #1 I hooked up a second monitor (depressed fn+f5) and was able to view everything fine. No problem in any area. Ran Some security checks (malwarebytes,checked windows updates,Secunia PSI,and a virus scan. #2 I opened up the monitor and checked for possible loose connections. #3 brought up the graphics display and checked that 60 hrz was set and correct. #4 ran a backup of all my data from my other monitor,and I made the assumption that it was a bad monitor and I might save some money if I just bought a new laptop.Would like to here your comments. Sincerely : dandee4u3
Mar 22, 2009 | Acer Aspire 3690-2196 Notebook
Acer 3690 Notebook/laptop computer
Carefully open the screen lid and look at the back of the screen there is a type number [like LTN15ox3] you can then obtain a replacement screen from ebay searching for this type number.
However if the screen only shows a faint dark image the fault could be the screen inverter that powers up the backlight tube in the screen.
Mar 14, 2008 | Acer Aspire 3690-2196 Notebook
LCD problem with my laptop "Aacer aspire 3690"
Based on your posted image, it would look as if you have an LCD panel problem. You can verify this by attaching an external monitor to your laptop, using the Fn + F? keys to activate it. If the display is correct, then you have just confirmed that is the LCD display that is at fault.
There are readily available replacement parts, as shown here.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Feb 01, 2008 | Acer Aspire 3690-2196 Notebook
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
