Question about Music
Sound quality changes from time to time losing tone and the great sound before
My name is Robert Andrews and play regularly in church.I love my amp and have never overcranked.Sometimes it just seems to loose its tonal quality and kinda looses its presets without touching anything.I know it has a built in circuitry that supposed to keep everything sounding normal .I cant think exactly what the term used is but its in my book and i cant find it at the time.Theres nothing inparticular that is going on when this happens but it is urely noticeable when it happens.Sometimes it goes away quickly then other times i find myself readjusting to try to get my original sound.It just kinda looses its highs and its efx to an extent,hardly no vol. problems.I plat through a takamine supernatural with cool tube.Does the same with my others.Sometimes it wont happen for a month then couple times in an hour.Could someone please help me.All chords are top notch and have been checked Thanks praisethelord316
  • praisehim316 Sep 29, 2008
    i have a peavey 112 ecoustic 125 watt efx amp.IT looses tone and its quality sound from time to time.It might do it every time i play or not for a month.It has built in effects and 10 in. woofer and 2 in. tweeter.I usually end up trying to get my great sound back by adjusting, but doesnt really help then it goes away.Ive been told to check back-up battery buti dont think it has one if it does, where is it?Ive checked chords and guitars.Not that. Please help if you can.Thanks Praisehim316.
  • 1,512 Answers
Hi Robert
So you got problems with your acoustic/electric/peavey rig There a few things to check first, you may already have tried most of them, but here's a check-list to help narrow down the source of the problem.
  1. Have you checked the battery in the Takamini, by that I mean been able to replace the battery at the time of the problem/solving it? If you have a multimeter, check for freshness. Anything that has a voltage of less than 8.5 volts should be discarded and replaced if you do not wish to see sudden failure half way through your gig. The preamp is using battery energy the whole time if has a jack plugged into it.
  2. Same thing goes for FX pedals and stompboxes. Digital Battery powered devices use up heaps of batteries. Pays to use an approved regulated power adaptor,or fresh battery before every performance.
  3. Leads you say you have already checked. Best way to do this is just replace the lead, or try with another. If you get caught mid performance with a noisy jack plug that crackles a lot, just quickly give the plug a ****. The contact will improve for the gig, but STILL NEEDS ATTENTION LATER.
  4. Noisy controls on the Preamp section of the guitar. Often crackling, or cutting out. If they do, cleaning them with contact spray will make them bind. You need to try tube spray burst of electrical contact treatment grease from Electrolube. It may still now resolve the problem. Replace the preamp.
  5. Some occasions in 4-5 year old plus guitars, the SMD capacitors in the preamp will fail, but this is generally more synonymous with a progressive reduction in performance,rather than an intermittent problem that you seem to be experiencing. When they do go, they leak electrolyte all over the PCB and corrode everything :( I recommend just replacing them.
  6. Same thing goes if you may have had a battery go bad in the guitar. If it has leaked into the circuit area, it will need immediate attention, or even eventual replacement also.
other than that, it may be an
  1. intermittent electronic fault occurring in the amp, The amp will need a techs attention expertly heating and cooling the amp in sections to aggravate the fault and localise what work needs to be done. Mechanical and electrical stress may also be used in the form of Poking and prodding, or hard yakka into a dummy load to put some electronic hardship across its existence. This may be as simple as some resoldering of poor or Dry solder joints, replacing some capacitors that fail with age, to being a more complicated repair that needs total attention for several hours to pin down the problem :) That's where guys like me come in to fix it for you.
  2. Or vary rarely a loudspeaker failing, or a foreign object in the voice coil magnet gap, polling the voice coil. This unit has a Black Widow type speaker that can be dismantled by the user and the voice coil gap cleaning with a piece of masking tape bent over a stoat business card and rotated in the air gap a couple of times, or at least till clear. Inspect the voice coil and former for any abrasions and burning at this time also. This job is sometimes best left to the expert also, and seeing as how the electronics are more likely to fail than Peavey's super reliable classic Black Widows, the would be a last resort to try and locate a stubborn intermittent sound problem.
What I have suggested are some of the things to consider when you have an intermittent sound problem. Feel free to use the ASK feature to follow up if you want more advice on your problem. :)
If you think I have done a god job addressing your problem, a FixYa is a great rewards. Thanks mate!!
rock on!! ;)
regards
robotek
Posted on Sep 30, 2008
  • Graeme Ross
    Graeme Ross Sep 30, 2008
    whoops, I need to correct a small error in recollection:) Your amp does not use a Black Widow driver, but a coaxial type, If you believe the speaker to be at fault, you will need to seek and experts attention here also.
    Guru:
  • 859 Answers
How long can you hold out for one of our real electronic techs to get wind of this problem you posted. I'll make an effort to reach one or two and have them come in on this problem.
Does that sound worth waiting for?
Worldvet
  • 10,594 Answers
Please replace Back-Up Battery in unit, if any.
or give model and brand of suspected unit.
Posted on Sep 29, 2008
  • Shahid Electronics
    Shahid Electronics Sep 29, 2008
    I would suggest to spray small amount of WD-40 Contact cleaner in its controls to work smoothly.
    Master:
  • 479 Answers
Internal circuit problem
  • tech gurus Sep 29, 2008
    some solderings could be loose in the circuit so causing you this problem.get it resoldered firmly and then try it will work.
    or you can just get dry soldering done on each and every soldering joints.this can be done by any local mechanic who can disassemble the unit and who knows how to use soldering machine.
Tone changes in pearly gates pick up
What you describe sounds like pickups fighting against each other meaning, does this occur when using pickups individually or together? This is normal when using more than one pickup together, if it occurs in single mode, something is wired wrong. Another thing is, If using single, are you splitting coils? Individual coils wired wrong can do this, a bad pickup selector switch can also. A loose wire or fiber touching the tone pot capacitor or ground could also. A dead coil on a humbucker can as well. I'm guessing that you are using these in combo meaning a possible pickup selector switch may not be switching properly. The player's level of experience is also in my mind since, all of my guitars do the exact same ONLY when I use more than one pickup. I hardly ever use more than one at a time unless I'm playing a strat.
Mar 28, 2014 | Seymour Duncan ShPg1 Pearly Gates Pickup...
Is there any way to make the hb15tsk louder acoustically,I love the guitar.
In a word, NO. Changing type of strings might make it a bit louder, however the sound quality would drastically change if it does. Best to leave alone... Get a small amp, portable battery if needed... OR there are headphone amps that are designed to be used for practice.
Sep 02, 2011 | Washburn HB Series HB15CTSK Electric...
I have an Epiphone Les Paul Custom Silverburst, and it's pretty new and has worked great until now. It seems my bridge pickup lost tone and volume for some reason. My volume and tone knobs are cranked...
Need more info: 1- does the volume control still change the level? 2-Does tone control still change the tone? 3- What happens when in the center position on pickup select switch? Put pickup switch in center position (both pickups active). Then take a coin and tap on the pickups. Does bridge pickup sound lower? Lastly remove rear electronics cover and inspect all wiring for something loose or disconnected.
Aug 26, 2011 | Epiphone Les Paul Special II Guitar...
Well, my Ibanez TBX150R Tone Blaster Xtreme Guitar Combo Amp worked fine for the longest time, and suddenly after a show, every time I turned it on the "hot" channel it popped and banged every...
Sounds like a problem with the channel itself, if the clean channel works then its not the lead, input, guitar or the drivers. You have to be careful when opening up amps as some can hold a residual charge and there can be danger of electrocution.
I would recommend getting it looked at by a pro, it doesn't sound like an expensive fix.
Jun 30, 2011 | Ibanez Tbx150h Tone Blaster Xtreme Guitar...
FM 65R plays and sounds great for about 5- 10 minutes then it sounds weak and distorted. If I play directly into the power amp input it sounds great again just no control for the volume and tone.
Also the volume will probably be lower going into the line level PA input... If the amp is shutting down for thermal reasons, driving it less might not get to the point of shutdown. The schematic shows a temp sensor that reduces and shuts down the amp if the heatsinks get to hot. Possibly you are driving the amp harder than it is intended, If it is as loud (I doubt it) driving the PA input, then I would expect it to shutdown, but you would probably have to drive it harder than your guitar because guitar levels are well below line level. The amp claims 65 watts... don't believe everything you read in spec sheets... You should be able to generate 100 Db of sound with it... The more distortion you use will drive the amp harder and heat the heatsinks faster.
May 13, 2011 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Ok, i love the tones on this amp, but for some reason, i start to play, not even on at a high volume, just like at a nice level, ill play it for like 5-8 mins and it will shut off, like the power is still...
This is a tiny amp good for practice at low volume levels. You are likely overdriving it and the power amp chip goes into thermal protect. If you volume level is much louder than a small boom box, you are driving it too hard. Best to get a bigger amp.
Jan 26, 2011 | Line 6 Spider Iii 15 Modeling Guitar...
Can the epiphone p/ups be changed to gibson's, is it worth it ?
Yes, the pickups can be changed.
However; In my opinion this is not worth it. Pick up a pair of aftermarket pickups for a better sound that will fit your playing style.
-Sheeves
Sep 21, 2010 | Epiphone Les Paul Studio Electric Guitar
Guitar amp no sound or lighting
Ah yes: complete catastrophe. Usually when everything is not working, it is a single reason and when that single reason is fixed, so is the amp.
Based on what you tell me, I am going to say you have a bad power tube. And I will even go as far to say that you buy a set of tubes and play on them as long as you can. If so, then you not only burned up the tube, but weakened the power section and may have a slooow tube frier. I always tell customers: modern tubes have an effective life of less that 1200 or so hours and that varies. Replace the tubes once per year if you gig with the amp: period. Otherwise, guys like me (doing repairs) stay busy and the tube companies get rich selling tubes to amps with weakened power sections.
It sounds like you burned a power tube and blew a fuse. First, you need a new set of power tubes and some extra fuses (go to Radio Shack and set the value you need in SLOW BLOW fuses).
Then, replace all the power tubes. Don't worry about biasing yet, we are just seeing if there is a problem. Next, replace the fuse.
Turn on the amp and play on it at various volumes and settings. If all is well, take the amp to a tech and get it rebiased. If you can afford it, pay to have the grid/plate and other resistors changed so the power section will be like new (clean slate with new tubes). Your amp will love you for it.
Almost all of the amps I have worked on for performance problems (cant keep tubes to stay alive for very long) are directly related to end user use. When you use a tube until it blows it ALWAYS TAKES SOMETHING WITH THE TUBE WHEN IT GOES (like the power section components). The compents will be weakened and the tubes will 'wear' at different rates that can even move them out of the 20% tolerence they must be within to sound good. 99% of the time a board repair with a retube after a catastrophe fixes the amp until the next time it is 'run into the ground'. Tube amps are NOT invinceble: they are weak compared to solid state and expensive to own. But we love tubes because they sound great. I have solid state to knock around on, when when it counts, I play only with tubes. I have spent hundreds on good tubes because you do get what you pay for.
Hope this helps!
-mike
Mar 14, 2009 | Music
Music Logo
238 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
