Question about HP Pavilion Slimline S3123W Desktop PC - REFURBISHED
Disc Drive Please I don't know where the disc drive is on my computer can you please describe where the disc drive is and not the cd burner disc.
  • 781 Answers
I think a video will do the trick better
http://www.youtube.com/watch?v=vnEga6ga5hM
Posted on Sep 27, 2008
My cdrom makes noise when i insert dvd
What type of noise does it make? If you hear the tray close and then the disc "spin" for a minute or so, that is normal. If it sounds like something is shaking or rattling or lasts more than 5 minutes, there is probably something wrong.
If it is an extended spin noise, the drive isn't recognizing the disc. Check if there are scratches and try another disc. If you hear a shaking or rattling, do not use the drive. It's probably better to replace the drive (check if it is under warranty - usually 1 year). This drive has an IDE connection. You will need to check your motherboard specifications to identify if you can replace the drive with a SATA optical drive (more common now) or if you need to find an IDE drive. (Note: OEM drives do not ship with the data cables or software discs, this will matter if you get a SATA drive.)
Some optical drives have a problem with the magnet that holds the disc for the laser to hold it. Some people fix this problem with duct tape; at <$20 for a SATA DVD-RW OEM drive, it isn't worth my time to fix.
I hope this helps. Please add a comment describing your sound and the computer you have for additional help.
Dec 26, 2012 | Sony CRX830E CD-RW/DVD-ROM (Combo) Burner
My burner don't recognize the blank disc
Good day,
One of the reasons why a CD drive won't recognise a disc is if d disc is corrupt or not good again. I'll suggest that you buy another one and see if the cd drive will see it. If not, try putting a non-empty disc (either a movie disc) and see if it works. If it doesn't, then d burner might have a little problem.
But if it does work, please feel free to reply.
Thank you for using Fixya!
Aug 21, 2012 | Toshiba Satellite A215-S5837 Notebook
Describe your hl dt st dvdram gsa t50n Problem get error that disc (DVD+R) is not supported please try another disc
maybe you need to change the blank dvd its not compatible with drive that you are using
Jun 10, 2011 | Computers & Internet
Model #GWA-4164B DVD Writer does not recognize any disc Cd or DVD. computer sees the drive when you install a DVD it tries to read and fails . Try to explore it indicates please insert a disc. Firmware is...
It sounds as if the disc drive laser has died, when they burn out they will not recognize any disc inserted. fortunatly a replacement drive is relativly inexpensive to replace.
Aug 24, 2009 | Hitachi Computers & Internet
When attempting to back up a file to cd error
make sure your disc is a rewritable CDRW or DVRW
Jun 27, 2009 | NEC ND-6500A DVD±RW Dual Layer Burner
Not find disc in drive
Sounds like you need to install a DVD decoder, Roxio, WinDVD and PowerDVD are good decoders.
May 20, 2009 | Sony DRU 530A DVD±RW Burner
Set-up not working on sony dvd
After reformatting a computer, inserting an optical disc into a drive will not allow it to autoplay (there is no operating system to take control of the situation). If the disc is bootable and the BIOS is configured to allow booting from an optical drive, restarting the machine with the disc in it should allow the system to boot off of that disc. If this is the problem you are trying to describe, press whatever key (F2, F12, Del, etc) allows you to enter your BIOS setup program and ensure that your computer will attempt to boot from your CD/DVD drive, save your changes, and allow the computer to reboot. This should solve the issue.
Jan 17, 2009 | Sony DRU-820A DVD RW Dual Layer Burner
Sony CD ROM drive model CRX140E
Hi I need help with my Sony 5cd changer model #RCD-W500C
Compact Disc Recorder AC 120 V 60Hz 25W serial #9021823 When I purchased this abour 7-9 years ago and ther weren't any manual instructions on how to use it. My husband experimenting with it had figured out the basics, time has past and since then we haven't used it and now I would like to use it but I don't know how. Can you help me with this?
Jan 02, 2009 | Sony (CRX140E/CH2) CD-RW Burner
Sony drive how do you insert disc?
No such thing as a stupid question! There will be some type of button beside the drive drawer. If not, click on my computer, right click on dvd/cd drive, could be called drive E but that is different for different machines. Select eject. The drive drawer will open so you can put the disk in.
Jan 06, 2008 | Computers & Internet
No Disc inserted or drive not ready, please try again
Setup Nero for CD recording mode, not DVD. The software does not change automatically.
Dec 09, 2007 | Sony VRD-VC10 DVD±RW Dual Layer...
HP Pavilion Slimline S3123W Desktop PC - REFURBISHED Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
