Question about M-Audio Delta 1010 PCI CARD Sound Editing & Recording Sound Card
60 Hz digital input noise on all channels
Have looked at all grounds and cables, not the problem. What could be wrong with the 1010, do I need to send it back to M-Audio or is there another way to fix it? Any tests I can run to overrule everthing else?
I use this thing all the time, started out abou two weeks ago on a random basis not happens all the time. Playback works fine, problem is only on the inputs. Please advise, don't reall want to part with it for 3 weeks if I don't have to. I use Traction 3, bot also happens with other software too.
SOURCE: firewire audio problem
Please notice that the firewire 410 is known to have problems with firewire chipsets that are not manufactured by either Texas Instruments or NEC.
This means that it's not enough to buy a Firewire card or to make sure you have it on your motherboard. You have to make sure that the chipset (the chip that actually manage the data transfer) is manufactured either by NEC or TI.
It's not always easy finding out the manufacturer of the chipset, but it's possible (for example my GigaBute motherboard came with a TI chip and it was written on its spec). Good luck!
Posted on Feb 04, 2008
SOURCE: S/PDIF not working
Hey hoof
My only experience with faint sounds is when ground wires in the particular circuitry are not property connected. That means tracking the wires from the one end to the other if you can get to them. If they are not embended in a casing or housing I would change them.
Also, try changing the RCA plugs; even their connection can cause the sound shorting if there is a short.
Well....hoof... well,,,,good luck buddy.
Posted on Mar 01, 2008
  • 30 Answers
SOURCE: m-audio firewire 410 on macbook
Use a 'Y' splitter. Usually from balanced to unbalanced. Also try looking at your device's control panel and see if you can change the channel options from mono to stereo. Beta drivers are for testing purposes, so try the signed driver also.
Posted on Mar 10, 2008
SOURCE: Using drum triggers with M Audio Delta 1010 and Digidesign MP 7.3
This site is useless. I posted this problem awhile back and nothing is posted for it. Don't waste your time here.
Posted on May 24, 2008
SOURCE: M-Audio Delta 1010 PCI CARD
It has 8 mono inputs or 4 stereo pairs, which can be recorded in cubase or whatever sequencer at once.
Posted on Jun 21, 2008
HDMI input works ok. Hooked up external antenna. Did channel scan. It will only scan for analog channels. Has analog raster on screen. It has no information on menu page for digital channel scan.
do you have the air option in the scan menu see
http://tv.manualsonline.com/manuals/mfg/sanyo/dp42841.html
page 9 important fact cable digital gets wiped by air digital channels
You may be able to get around this via a digital hd tv decoder box and then have it on a hdmi input on the TV as a backup to the cable if you can't have both cable digital channels stored and aerial digital channels stored
Oct 09, 2016 | Sanyo DP42841 42" LCD TV 1920x1080,...
Wiring connection diagram
Sorry but i do not know of any tv that uses ground wires,
if you mean rca cables these have coloured plugs either red,white and yellow or red blue and green,if you look into the sockets on the back of the tv you will see the matching colours
Sep 03, 2014 | SEIKI Digital SE322FS 32" LED TV 1366x768,...
How can I adjust the height of the HP LP2465 24" LCD Monitor?
MOST OF THE TIME THEY WILL NOT ADJUST UP AND DOWN. LOOK FOR A SMALL LEVEL AT THE BOTTOM OF THE BASE OR JUST BEFORE THE BASE. I JUST GOOGLE IT AND FOUND PICTURE OF IT.
May 21, 2014 | HP LP2465 24" LCD Monitor
Hum when mixer is turned on
If it is a 60Hz or 120 hz hum, the fault may be a bad solder connection to a filter capacitor in the power supply.
If it is a hum like a bad mic connection, you may have dirty contacts on an input, dirty tracks on a mixer control, even on the EQ portion.
It may also be a bad cable is connected, or a 1/4 inch jacked input may not be grounding out when the plug is removed. You may have a bad ground on the power feed and you have a ground loop as a result, or a cable is faulty and creating it's pwn ground loop to something else.
Contact cleaner is not a bad idea, slide pots are notorious for spurious noise over time. LPS1 is not bad, but it does use silicone as the dry lubricant portion.
If all of that is ruled out, look internally for bad solder joints- anything that looks crumbly is suspect, and also check for loose wires and jacks with bad solder connections. Also look for loose connectors too.
Mar 29, 2012 | Mackie 3204VLZ3 32-Channel USB Mixer
I was thinkin bout buyin a planet audio ac2600.2 car amplifier but cant find what gauge power an ground wire it takes and how many watts it puts out 2 channel @2ohms rms. can you help?
Here are your specs. RMS 900 Watts Nominal and Max 1300 on 2 Channel @ 2 Ohms.
4 Gauge should do fine but if you like to feed the beast go with 2 gauge.
Looks like going rate is $110 on Amazon or elsewhere.
If it attains the RMS wattage it would be a good amp. I like monoblocks but
you will pay more. I looked into Tri-Mode and it is straight forward but people
are having problems figuring it out. With your 2 speaker operation you should
avoid the issues others are having.
Good luck and remember, rearview mirrors were meant to fall off!
Mine: JL 1800A monoblock into 2-JL 12" W3's in series for low bass 20-80 Hz; Lanzar Vibe 266 bridged into 2-12" Memphis in series for mid bass 40-200m Hz. 2 guage wire to mononblock-250 amp fused at battery, 4 guage to Vibe w/250 amp at battery.
Anarchy Series 2-Channel Car Amplifier
  • RMS Power Rating:
    • 2 ohms: 900 watts x 2 chan.
    • Bridged, 4 ohms: 1800 watts x 1 chan.
  • Max power output:
    • 2 ohms: 1300 watts x 2 chan.
  • Total Power Output: 2600 watts
  • Pulse width modulated MOSFET power supply
  • Convenient remote subwoofer control
  • LED power (green) and protect (red) indicators
  • Variable Bass Boost 0 to +18 dB
  • Bridgeable Tri-mode operations
  • Chrome-plated connections enhance durability
  • Variable high and low pass crossovers
  • Illuminated logo
  • 3-Way System Protection circuitry (thermal, overload, and speaker short protection)
  • Dual speaker terminals simplify the hookup of multiple speakers
  • Heavy duty aluminum alloy heatsink for extreme heat dissipation
  • Low level high inputs
  • Heavy-duty set-screw terminals
  • Input sensitivity:
    • Low level: 100mV-2V
    • High level: 2V-8V
  • Variable high-pass filter (45-90 Hz, 24 dB/octave)
  • Variable low-pass filter (50-500 Hz, 24 dB/octave)
  • Damping factor: >125
  • Signal-to-Noise Ratio: 102 dB
  • Frequency response: 20-20,000 Hz
  • Dimensions: 15-9/16"L x 10"W x 2-3/16"H
  • 1/0-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
  • 1-year Manufacturer's warranty
Mar 19, 2011 | Planet Audio Car Audio & Video
Will this amp push 2 2000 watt subs?
hope this helps.
caution
About Power supply wires (MRP-M1000 only)
• 21mm2 is the minimum power and ground cable size
that should be used to connect this amplifier. The
length of these cables should not exceed 1m to assure
safe operation.
• If the length of the power and ground cables exceed
1m, or if you connect more than one amplifier, a distribution
block should be used with 33mm2 or 53mm2
power and ground cables depending on the length
necessary. Ensure that you install a correctly-rated
in-line fuse on the power cable near the battery positive
post.
RMS Continuous Power (at 14.4 V, 20 - 200Hz)
• Per channel into 4 ohms (?1% THD+N)
MRP-M1000 ......................................... 600 W x 1
MRP-M500 ........................................... 300 W x 1
• Per channel into 2 ohms (?1% THD+N)
MRP-M1000 ....................................... 1000 W x 1
MRP-M500 ........................................... 500 W x 1
Total MAX Power
MRP-M1000 ............................................. 1900 W
MRP-M500 ............................................... 1100 W
S/N Ratio
• IHF A Weighted, Reference: rated power into
4 ohms .................................................... 100 dBA
Input Impedance
• RCA IN .................................................. 20k ohms
• SP IN .................................................... 40k ohms
Frequency Response (200Hz/ -3dB) ....... 20 - 200 Hz
Crossover Frequency .......... 50 - 200 Hz (-24dB/oct.)
Input Sensitivity (RCA IN) ............................ 0.2 - 4 V
Dimensions
• Width (Heat Sink/Footprint)
MRP-M1000
......... 320 mm (12 - 19/32")/380 mm (14 - 61/64")
MRP-M500
............... 210 mm (8 - 17/64")/270 mm (10 - 5/8")
• Height ..................................... 60 mm (2 - 23/64")
• Depth .................................... 242 mm (9 - 17/32")
Weight
MRP-M1000 ................................................ 4.2 kg
MRP-M500 .................................................. 2.7 k
Feb 04, 2011 | Alpine MRD-M1000 Car Audio Amplifier
Can i hook this amp to a 2 channle out put stereo?
Sure. Specs are listed below. I think it's designed for regular 2-channel input, isn't it?
Front Channels: 100 W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
  • Rear Channels: 25 W RMS x 2 @ 1.5 ohm-4 ohm(11V-14.5V)
  • Subwoofer Channel: 250 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
  • THD at Rated Power: <0.03% @ 4 ohm (F&R), <0.05% @ 4 ohm (Sub)
  • S/N Ratio (F&R): >108.5 dB below rated power S/N Ratio (Sub): >95 dB below rated power
  • Frequency Response (front and rear): 5 Hz-30 KHz (+0, -1dB)
  • Frequency Response (sub channel): 5 Hz-500 Hz (+0, -1dB)
  • Damping Factor (front and rear): >200 @ 4 ohm/50 Hz
  • Damping Factor (sub channel): >500 @ 4 ohm/50 Hz
  • Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
  • Differential-Balanced Input Topology: (3 pairs of inputs)
  • Front Crossover: fully-variable (50 Hz-5 KHz), selectable- slope BP or HP (12 or 24 dB per octave)
  • Rear Crossover: fully-variable (50 Hz-5 KHz), selectable- slope HP (12 or 24 dB per octave)
  • Sub Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
  • Preamp Output: 2-channel (full-range or LP)
  • Bass EQ: Variable boost up to 15db
  • Infrasonic Filter: defeatable 24dB/octave at 30 Hz
  • Left minus Right Ambience Circuit: ambient effect for rear channels
  • Front and rear speaker output connections: accept up to 8ga. wire
  • Dual mono subwoofer output connections: accept up to 8ga. wire
  • +12V and Ground connections: accept up to 4ga. Wire
  • Dimensions: 19.7"L x 9.25"W x 2.36"H
  • Dec 02, 2010 | Jl Audio 500/5 Car Audio Amplifier
    I am trying to find the output power, watts?
    bad transformer. A $10 part at most electronic stores. U fried it when you dropped it. Happens all the time.
    Jun 08, 2010 | Audio Players & Recorders
    Slow refresh rate - fuzzy picture on HD channels with AT&T Uverse
    That would have nothing to do with the fact your TV only has a 60 hz refresh rate, the cable box will switch to the correct format just like it does with 720 or 1080 resolution.
    Nov 11, 2017 | Televison & Video
    Power acoustik gothic OV2 800 manual
    Could not get a manual for you but did get the follwing specs. Hope they help.
    Power Acoustik Ov2-800 2-Channel Class A/B Gothic Series Amplifier (800-Watt)
    POWER ACOUSTIK OV2-800 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER
    800-WATT 2-CHANNEL
    4 ohm RMS: 150W X 2
    2 ohm RMS: 180W X 2
    Bridged mode MONO RMS: 360W
    BRIDGED MAX: 800W
    FULL MOSFET POWER SUPPLY
    PWM CIRCUITRY
    FULL SELECTABLE CROSSOVER
    3-WAY PROTECTION CIRCUIT
    TRI-MODE CAPABLE
    VARIABLE LOW PASS 40 HZ - 120 HZ
    VARIABLE HIGH PASS 150 HZ - 1.5 KHZ
    VARIABLE 18 DB BASS BOOST @ 40 HZ
    FREQ RESP: 10 HZ TO 30 KHZ
    S/N RATIO: 98 DB
    THD: 0.02%
    2 ohm STABLE STEREO
    SYSTEM DISTRESS INDICATOR
    HIGH/LOW LEVEL INPUTS WITH FLOATING GROUND
    4-GAUGE POWER/GROUND CONNECTION
    PLATINUM RCA CONNECTORS
    LINE OUTPUT WITH FLOATING GROUND
    BLUE LED
    CHROME TOP PLATE PANEL 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER (800-WATT)
    Aug 18, 2009 | Power Acoustik GOTHIC OV2-800 Car Audio...
    M-Audio Delta 1010 PCI CARD Sound Editing & Recording Sound Card Logo
    107 people viewed this question
    Top M-Audio Computers & Internet Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    John Bolton
    Jim Goldsmith
    Jim Goldsmith
    Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
