Question about Irons
Parts for rowenta dg5030 steam iron
I have looked at several different websites and i can not find the Green O-ring. Does you know where to get it? Or can i use an o-ring found at home depot or a parts store?
  • 2 more comments
  • cutty9 Nov 24, 2008
    I'm trying to locate a spare Green "o-ring" for my Rowenta 5030 steam iron.
  • Anonymous Dec 22, 2008
    I have the same problem. I tied the o ring from home depot and it didnt work
  • Anonymous Jan 08, 2009
    where can you find a suitable replacement for the green o ring.
  • Anonymous May 25, 2009
    This did not work for me...had to order it
  • 3 Answers
You can use a # 12 O-Ring 13/16" O.D x 5/8" I.D x 3/32" available at hardware stores. Danco # 96729. These work perfectly and seem to last longer than the original O-Ring.
Posted on Mar 07, 2009
Water leaking from iron
Posted on Dec 09, 2009
Steam comes out the filler cap on the water base on my Rowenta DG5030
WIre brush the caps screw threads and replace the O Ring ASAP.
DOn't use the iron until you get a new O ring and they need to be the orange/red rubber ones they are able to withstand the hot steam black o rings at home depot won't last.
Jul 24, 2014 | Rowenta Pressure Iron and Steamer DG5030
Fix rowenta dg5030
Send it in for repair.
Google Rowenta Repair Center
Jul 22, 2014 | Rowenta DG5030 Iron
The tank in my rowenta iron is producing steam but the iron is not producing steam
Yes the iron needs to be cleaned. They do have a descaler to clean. the Steam valve with a electronic switch is broken, that is what opens and lets the steam out of the iron when you press the button.
Google Rowenta repair Centers.
Jun 30, 2014 | Rowenta DG5030 Iron
Rowenta pressure iron and steamer model DG5030? We have purchased the iron and cord, now we need to assemble the part.
Google Rowenta and go to their website, they will have parts diagrams and wiring diagrams. Hope this helps, please post solved on fixya.com. So I get credit for a solved problem if it does.
Apr 30, 2014 | Irons
I am having issues with my steam generator iron. I used it today and after heating up steam was pouring out from the screw on cap. Put on new green rubber ring and I can iron with steam until I sit on base...
I think lime and calcification are the culprit. Use some "CLR" at Home depot, can decalcify the build up on your irons pressure cap.
I have the Rowenta Steam Station. Love it!
Cheers,
Embroidery Services
San Diego, CA
Oct 25, 2017 | Rowenta DG5030 Iron
Steam comes out of the place where you put the water in
check the holes in the hot plate are not blocked with lime scale...sounds like you have a back pressure problem
Dec 29, 2012 | Rowenta DG5030 Iron
Do you know where I can buy the trigger knob for a rowenta steam iron model dg5030
Hi there.
You can buy parts for your steam iron at http://www.rowentausa.com
Regards.
Jul 14, 2011 | Irons
Need a cap gasket for a Rowenta DG5030
I showed the part to my husband. He took it to our local Aubuchon Hardware and bought the same size gasket for 59 cents. I just tested it out and my iron works just fine now. The one from the hardware store is black, vs the Rowenta one which is green. Who cares what the color is, no one sees it anyway. However, if you have to send your machine for repair for something else, they may not honor your warranty as you've now added after-market parts. Just thought I mention that. Good luck.
Jan 10, 2009 | Rowenta DG5030 Iron
No steam, button jammed
I posted a similar fix under Rowenta DG-980 troubleshooting section. You may be able to pry off the soft rubber cover and access the switch assy and initiate a "surgical procedure".564568
Are you working on another iron similar to the DG-980 posting elsewhere on the FixYa website?
As for the Rowenta manufacturer, you can "Google" the Rowenta website at http://www.google.com typing in Rowenta and looking specifically for the Rowenta home website to get manuals, PDF reader and other good stuff. Please advise if your problem is fixed. I'm in SoCal and been to the UK only once.
Jul 10, 2008 | Rowenta DG5030 Iron
Irons Logo
2,436 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
