Question about Samsung HL-R6167W 61" HDTV
Problem with HL-R6167W green vertical lines
I have a SAMSUNG DLP model HLR6167w with a problem.
I just changed the light hoping this would fix the problem. the PROBLEM IS No picture at all. I have white and black static on the screen that also has a green viritical lines. I have 5vertical evenly spaced lines. I can put the TV on air-antenna, Satelite, DVD, NindendoWii, and the greenish static follows all components. When I hit "menu"on the TV remote, all menu options are crystal clear. Set-up, channel,sound, etc...all perfect picture...Just a problem with the actua lpicture on all components
  • 1 more comment
  • yoyo6999 Feb 08, 2009
    well had a tech come out they said it was the DMB i ordered it and it will be here tuesday 2/10/09 ill keep you posted
    well had a tech come out they said it is the DMD board got it coming in on tuesday 2/10/09 ill let you all know ASAP!!!!
  • check56check Feb 09, 2009
    My HLR6167W is 3 years old and has the same problem now. Green screen with sound. Some HD channels show good pcitures for a few minutes and then freeze, the screen goes black for about a minute and then back. The cycle repeats. Can not turn off or change channels.
It is doubtful if not impossible that it is the color wheel if the menus are working fine with full color. The DMD mirror device will not project the menus in color if the color wheel is not spinning at the proper speed to sync with the pixel mirrors flipping on and off. Most likely it is the interface between the inputs and the DMD board, like the analog or digital board. I am having the same problem and have not figured it out yet but am working on it. I have seen many thoughts that it is a thermal problem but have not verified.
Posted on Feb 07, 2009
Replace the color wheel
Posted on Nov 12, 2008
Green vertical lines,minor. flashing goodback ground pic good sound . i have samsung dlp tv model hl-r4667w
the lines are from the vertical control, theres a minor short on the vertical board if not fixed the power supply will short and whole tv will go green call repair shop and get short fixed
Jun 11, 2010 | Samsung DLP HL-P5663W 56" TV
Green shade color on screen over tyhe program that is been broadcast
its a loose connections to you color amplifier RGB. cold solder in that board section.
May 30, 2009 | Samsung HL-R6167W 61" HDTV
You need to do an aggressive reset on the TV. This solved problem completely for me. You must unplug the TV when it is on. Repeat this several times until the TV is jolted back into the factory default settings. The issue is actually with the programming I believe. The clue was that the display worked 100% perfect in HDMI mode, and the problem only existed in the cable setting, no matter if wires were attached or not.
Again, do an aggressive reset to the TV by unplugging it several times while it is on. It may not register the reset at first because after all, the actual problem is a programming issue and it's having trouble recognizing commands in the first place.
Good luck!!
May 29, 2009 | Samsung HL-R6167W 61" HDTV
Samsung Model HLR6167W
Does the TV appear to be cycling on and off, like its attempting to boot up? Or, does it just not come on at all? Don't miss the lamp door interlock switch. Many Samsung DLPs have tempermental door switches. Try re-installing the door or manually hold the switch in the closed postion and try to power it up. If the lamp comes on and stays lit, you've found your problem.
michtech
Feb 19, 2009 | Samsung HL-R6167W 61" HDTV
I have a DLP Samsung HL-R6167w and it's not working
I had a bad digital board also. I went to parts.com to order a new part way cheaper than from repair service. the only problem I had was that after installation which is super easy 4 cables to unplug and replug. when I turned on the TV the picture came in upside down, not good. no one would give me the code to flip the screen as it is in a hidden menu, well after months of searching the web I found it!! It works for most all newer Samsung TV's. turn the TV off, hit mute then 182 and then power on button on the remote. the "hidden" menu will pop up and you scrool down to h-flip and flip the screen. I don't recommend messing with any of the other setting as you could likely really jack up the TV but at least you can fix it for a 3rd of the cost you would spend otherwise.
Jun 18, 2008 | Samsung HL-R6167W 61" HDTV
I have a SAMSUNG DLP model HLR6167w with a problem. I just changed the light hoping this would fix the problem. When the problem first occurred, I could barely make out the picture, and it was very green...
Good luck!!
Samsung HL-R6167W 61" HDTV Logo
233 people viewed this question
Henry  Thomas
Henry Thomas
