Question about Acer Computers & Internet
I need to download a program that requires windows and my computer says the program wont run in dos mode how do i get it to work?
  • 781 Answers
If the program requires windows that means it was design to work with windows and not with DOS.. you may want to get an old version of the program that will actually run under DOS.. usually you may be able to do the opposite which is to run DOS program on windows.
if possible try to get a DOS version of the program you are trying to run, or better.. upgrade your operating sytem so you can run your program and possibly other DOS programs.
post the program you are looking to download and confirm what operation system you're running and I'll try to look for it with you.
Posted on Sep 27, 2008
I use Paradox Version 4.5 on my old Windows XP computer. Now I need a new computer that will have Windows 7. How do I install my Paradox 4.5. I've all ready tried everything that I can think of but no...
I use "DOS Box 0.74". it opens a dos window that you can run paradox in. Its FREE and works great, even in full window mode. Only issue I had was I toggle to DOS occasionally to clean up txt files and DOS Box has limited DOS commands.
Jul 26, 2011 | Borland Paradox 4.5 Full Version for PC
I have Mavis Beacon teaches typing cd and I am trying to install it on windows 7 but it wont install i can only read the manual that adobe lets me, my questions is how do i download the program to windows...
What version of the typing program do you have? You have a few choices, depending on what OS runs the version you have.
If the program ran under Vista or XP (version 20 lists Vista compatibility), the compatibility mode is likely to work. For this, right click on the installer. Then choose Properties and then the Compatibility tab. Turn on Run program as Compatible with the appropriate OS. Then right click again on the installer and choose Run as Administrator. Then check if the program itself is running in the compatibility mode by right clicking again and choosing Properties.
If the compatibility mode doesn't work (for older versions of the software), you can use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software on the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them.
Your final option is to upgrade to the current version. The 25th Anniversary edition runs under Windows 7. Other editions are not listed as compatible at the Broderbund site. You can try the Microsoft Windows 7 Compatibility Center for more information on tested software. My ISP is slow to connect to the site.
I hope this helps.
Apr 13, 2011 | Broderbund Computers & Internet
It wont install on windows xp
Trying installing the game in compatibility mode by right clicking on the EXE file on the medium used to start the install for the game and click properties. A window should pop up with a tab called Compatibility. Under compatibility mode click the check box to "Run this program in compatibility mode for:" In the drop down menu click Windows 95. Then try to run the install again.
Mar 16, 2011 | Capstone Software Trump Castle 3 for...
I have a copy of starcon 3 but it won't install on my computer my os is windows 7 but it says that the game isn't compatable with my version of windows
Hi, welcome to Fixya. I hope my info helps you.
What it said is true. Starcon 3 is an OLD game, with compatability with win 95, and DOS. I think there may be a way for you to get to work though, right click on the installer program, and put the program in compatability mode, and tell it win 95 for the o.s. If that doesn't work, then download a program called DOSBOX, and run the installer with it, Dosbox is designed for just this sort of thing.
I hope that you do get it to work, as Starcon 3 was a really good game when it came out.
Jan 20, 2011 | Computers & Internet
I have an old print master gold 16 program. Can I some how download it and make it work on my Windows 7 program
you can buy virtual machine program and use older stuff with windows 7. it will require u to install that os also to run it. please vote
Dec 21, 2010 | Computers & Internet
Wen i download a file and then try to open the file it just keeps sayin this program cant be run in dos mode how do i fix it
Does the file end in .exe?
It sounds like you have downloaded a Windows executable to a Macintosh system, and when you click on it it opens in the text editor, which displays the binary contents of the program, which usually contains the message "This program cannot be run in DOS mode."
Windows executables cannot be run on Macintosh computers unless you have also installed Windows, either under Boot Camp or under a virtual machine monitor such as Parallels or Fusion.
Jun 06, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
DEAR SIR I HAVE COMPAUTER HP COMAQ DC 7900 I WORK WITH SOME PROGRAM WORKING IN DOS .. THAN I NEED INSTALL DOS OPERATING SYSYTEM THE COMPUTER DON'T RESPON ... ALSO THE COMPUTER DON'T HAVE LPT I BRING CARD...
the best way to do this is probably use windows and run dosbox for windows. What it does is it emulates DOS and lets you run any program that requires dos. Because your computer doesnt have a LPT port. and nowadays only drivers for dos or newer operating systems come with the card. installing the driver in windows then running dosbox, it will see the LPT port.
you can get it here
http://prdownloads.sourceforge.net/dosbox/DOSBox0.73-win32-installer.exe?download
May 04, 2010 | Computers & Internet
Windows problem
Try this.
Right Click on your DOS program EXE file. Then go to properties and go to Compatibilty TAB. Click in Check Box for Compatibitlity mode and select WINDOWS 95.
Feb 10, 2009 | Computers & Internet
Unable to load
How to get to a MS-DOS prompt.
Reason: If Windows or the computer is not operating properly, it may be necessary to get to a MS-DOS prompt to diagnose and to perform additional troubleshooting on the computer.
Solution: MS-DOS users
Windows 3.x users
Windows 95, 98 and ME users
Windows NT, 2000 and XP users
Windows Vista users
Other PC Operating System users
MS-DOS users If you are running MS-DOS with no other operating systems, the computer should be booting into a MS-DOS prompt automatically unless you have a shell or other program loading automatically. If the computer is not getting you to a MS-DOS prompt, reboot the computer and as the computer is booting, press the F5 key when you see the message "Starting MS-DOS" or the MS-DOS version. This will load the default standard MS-DOS. If you successfully get to a MS-DOS prompt and would like to prevent the computer from loading the program that is preventing you from getting to a MS-DOS prompt, or if you would like to fix possible error messages you may be receiving when booting the computer, edit the autoexec.bat and/or the config.sys files.
Windows 95, 98, and ME users If you are able to get into Windows 95, 98 or ME, you can get to a MS-DOS prompt by following the below steps.
  1. Click Start
  2. Click Run
  3. Type "command" and press enter.
This will open a MS-DOS shell. However, if you are attempting to troubleshoot an issue with the computer and are using Microsoft Windows 95 or Windows 98we suggest you restart the computer into MS-DOS. To do this follow the below steps.
  1. Click Start
  2. Click Shutdown
  3. Choose the option to restart the computer into a MS-DOS prompt.
If you are unable to get into Windows 95 or Windows 98 to get into a MS-DOS prompt, follow the below instructions (Windows ME does not have this option).
  1. Reboot the computer
  2. As the computer is booting, press the F8 key when you hear a beep or when you see "Starting Windows 95" or "Starting Windows 98". Windows 98 users sometimes may find it easier to press and hold the left CTRL key as the computer is booting.
  3. If done properly the user should get to a screen similar to the below screen.
Microsoft Windows 95 Startup Menu
============================= 1. Normal
2. Logged (\BOOTLOG.TXT)
3. Safe mode
4. Step-by-step confirmation
5. Command prompt only
6. Safe mode command prompt only
Enter a choice: 1
F5=Safe Mode Shift+F5=Command prompt Shift+F8= Step-by-step confirmation [N]
4. Select the option for Safe mode command prompt only.
Windows NT, 2000, XP, and Vista users If you're running Windows NT, 2000, or Windows XP and need to get to MS-DOS prompt follow the below steps.
  1. Click Start
  2. Click Run or click in the "Start Search" field if you're running Vista
  3. Type "cmd" or "command" and press enter.
Additional information about the difference between "cmd" and "command" can be found on document CH000395. If you're attempting to get into a MS-DOS prompt to troubleshoot the computer boot the computer into safe mode. Additional information about how to get into safe mode can be found on document CHSAFE. Windows 2000, XP, and Vista users who are unable to boot the computer into Normal Windows mode or Safe mode can also enter the recovery console to manage their computer from a prompt. Additional information about how to do this can be found on document CH000627. Finally, if you are experiencing issues getting into Windows NT, 2000, or XP, it may be necessary to run troubleshooting steps from a MS-DOS prompt. It is recommended that the Network Administrator get into the MS-DOS prompt by using either a standard MS-DOS boot diskette (note: will not be able to access data using a standard MS-DOS bootable diskette) or the ERD diskettes created after the installation of Windows NT, or boot from the Windows XP CD.
Index
Category:
MS-DOS Q&A
Companies:
Microsoft
Related Pages:
MS-DOS
Safe Mode
Resolved
Were you able to locate the answer to your questions?
Dec 06, 2007 | Microsoft Windows XP Home Edition
Computers & Internet Logo
73 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
