Question about Coleman Heating & Cooling
My colmen central air unit is not working properly. The Outside unit is not working. The problem initally arouse in June, but it "self corrected" after having the A/C unit turned off. Since that time the unit has run perfectly untill now. I did look for a reset button, but was unable to find one. The system (at most) is only 4 years old.
    Scholar:
  • 121 Answers
If nothing is running outside at times you probably have a weak contactor coil that is not pulling the contactor in all the time. If the outside fan comes on but not the compressor, the compressor is over heating and shutting off on overload protection. This could be a dirty condenser coil, low on refrigerant, the compressor it's self. The compressor comes with a 5 yr. warranty.
Posted on Sep 27, 2008
Compressor and blower of outside unt of AC are not working ....contactor in outside unit. latches for 1second and blower works for that 1second then off
power board or start/ run capacitor on outside unit
could be vermin problem across the board shorted it out
call a technician for a proper diagnosis and quote
Jul 13, 2016 | Heating & Cooling
Why my central a/c unit wont blow hot air
If its and A/c unit its not supposed to blow hot air, at least not to the inside of the house, the hot air is blown to the outside, if its working properly.
Nov 05, 2014 | Heating & Cooling
My corona air conditioner inverter does not produce hot air
these are all in one units, some of them are made like smaller central units and some of these are separate ac and heat units. the heat in the separate ones is run off of a heat strip in the unit it's self the ones that are made like a central unit reverse the flow of the freon in the system to draw the heat from outside. this is not something you can repair very easily yourself. most places require because of the freon that you have a certified HVAC technician to work on them.
Feb 22, 2013 | Heating & Cooling
My frigidaire a/c is set 73fhrenheit after running for a time the temp. on the unite drops to 60 degrees by it self what is the problem ?
AC units, no matter if they are big/small, window or big central units. They will only cool the air in the room, or home, to about 15 degrees cooler than the outside air temperature. If you live in Georgia and it is 100?F+ outside, you will be lucky if the unit will reach 80?F even running all day.
Jul 22, 2012 | Frigidaire FRA186MT2 Window Air...
Hello We have a Trane central air
Bad thermostat, improper wiring or bad circuit board in furnace. Turn off the disconnect outside.
Dec 30, 2009 | Heating & Cooling
Central air conditioner won't stay running
Sounds like it cycles on either head pressure or low pressure. If you have a Carrier unit it has both controls. Is your outside fan running. Is your condensor dirty. A unit that old needs to checked bby a service tech. Remember freon does just go away. If he puts gas in your unit there is leak. HINT Ask for free estimate on repair before it is fixed. That way you know the cost up front. Rus
Jun 25, 2009 | Heating & Cooling
My central air never kicks off
Sounds like you need to recharge it .. To tell while the unit is running go outsiode and feel the large insulated copper line going to the unit it should be cold to point od sweating like a can of coke you take out of the refrigerator and sit on the counter. also feel the air coming out of the unit outside it should be warmer than the outside air if not your freon is low
Jun 09, 2008 | Weather King 10AJA2501AH Air Conditioner
I have a colman ac unit and the outside unit will not come on. i hear it clicking but nothing happens
On my computer screen these two problems are not the same.
To "garys2003" Clicking you hear is the contactor closing in calling for cooling. If no power is being supplied to the outside unit high voltage the unit will not run. Check your circuit breaker or fuses in the outside power box. If the outside power box is of the non-fused disconnect, check that the disconnect is inserted properly.
To Trenina: Is your unit a self contained unit outside ducted to the inside as with a Mobile Home. If so your evaporator cooling coil may be frozen over stopping air movement, turn the cooling off and set your fan to on until it defrosts, then return to normal operation and leave the fan on during cooling.
If nothing comes on inside as with a central A/C system you may have a problem with the blower motor itself.
May 12, 2008 | Heating & Cooling
Heating & Cooling Logo
140 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
