Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Ixus 75 battery discharges overnight even if the camera is turned off.
A fully charged battery last only for about 2 minutes video and 30 M2 fine pictures. Even if the camera is turned off it discharges the battery in 20 hours. The camera is 9 months in use now and was purchased in Germany.
That's it, the battery's defective, it's not the camera...unless you've tried another (new) battery...
Posted on Oct 11, 2008
Battery life draining overnight
Try disabling everything you can through the software, if not possible, unplug them. Then plug one in at a time and leave it overnight. If its OK in the morning, plug in the next item, and so on. Make sure battery is fully charged between each test. When the unit discharges overnight again, the last item you reconnected befroe it discharged is the one causing the voltage drain.
Aug 20, 2014 | Toshiba NB520 Netbook
Took a few photos, switch off, 5 minutes later switched back on, blank screen but can view playback and menus
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
Jun 10, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
My 2 yr old Ixus 70 keps turning itself off.
How old is your battery? Keep in mind rechargeable Li-Ion batteries aren't meant to last more than a couple years, regardless of whether they've been used or not. If yours is as old as your camera, I think you know the answer. The good news is there are many inexpensive generic alternatives available these days. Some are very good, and vice versa. Research the buyer reviews before considering purchasing.
Nov 10, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon IXUS 100is battery pack problem.
Happened the same with mine. At the beginning I tough it was related with the sd card as when I removed the card the camera would turn ON. Later on I found it to be related with the camera contacts. After cleaning the battery contacts with alcohol and a cotton swab it started to work fine. SOLUTION: Clean battery gold contacts.
Oct 12, 2009 | Canon PowerShot S90 Digital Camera
Charge not lasting
try discharging the battery completly and i mean dead wont even try and turn on the charge it overnight and see if that helps a bit as far as i know there arnt any batterys you can change with it, and anyway the battery if avalible would cost you about as much as a brand new mp3 player
Sep 16, 2009 | RCA JET S2002 MP3 Player
Camera will not turn on. Battery fully charged;
You can give it to an expert for repair, he can repair it for less as there must be just a fuse problem, which can be fixed for a very less amount.
Aug 10, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Battery Life
It is a very commom comphenion,the original canon nb-4l battery often decrease its capacity and won't charging normally after 30 charge/discharge cycles or so.If you don't want to miss the important shots,get a cheap higher capacity replacement canon nb-4l battery as a spare power bank in hand.
Jul 12, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Battery
Before you change the battery:
  1. Charge the battery fully
  2. Discharge the battery fully
  3. Repeat steps 1 and 2
If the battery does not reset itself and start lasting longer then you do need to replace it.
Jun 26, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Help
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
May 25, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon Ixus 75 not charging
The camera was working fine 5 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. i Please help!
Mar 24, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
88 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
