Question about Cyberhome CH-DVD 300 DVD Player
Have picture, no sound
My DVD player was working fine, but then suddenly the sound disappeared. I tried a new cable connector from the DVD player to the TV, but still no sound. I double checked to make sure all the connections were in the right place. I double checked the mute and volume options on the remote, but still no sound. Any ideas?
  • Anonymous Mar 23, 2014
    tv volume fine but no sound on dvd
    Scholar:
  • 147 Answers
I've had this trouble too. Not sure how to fix it, but I've found a work-around:
Remove DVD.
Insert Audio CD.
Wait for audio to play.
Remove audio CD.
Reinsert DVD.
Sound should work again.
If you power off the unit, you may have to try this procedure again.
Posted on Oct 07, 2008
How to change a bulb in a apex pf2720 tv
I'd guess it is not a bulb issue if the audio also stopped working. Check your input source, connections and the like. Try using a different input (ie input 4 or the front AV connectors) and a different source (ie your old Nintendo instead of your DVD player).
Nov 17, 2011 | Apex Digital PF2720 27" TV
When hooking up to a new tv, the sound no longer
Hi
This all depends on how you connected the two. If you used the component cables then you've forgotten the audio cables. If you're using an s-cable then you've bent a pin or the connector is not centered. If you're using an Html connector then the cable may be bad but my money is on the DVD player being bad.
Jun 05, 2010 | Panasonic DMR-E75V DVD Player/VCR
All of a sudden the sound just quit on my Toshiba SDK990 DVD player. Any ideas? TV works fine and have checked different audio settings and cords and all.
First: be sure the TV sound is ok. then, try the DVD sound by using headphones. If it sounds, then try moving by do a little pressure aside the audio connector from DVD to TV while it is connected
Apr 20, 2010 | Toshiba SDK990 Player
Only audio works. No video. Worked fine last time. Tried new cables. Tried video 1 and 2 inputs to tv, still sounds great but no picture. T.V has no problem with video camera in either...
if the camera works, and you tried new cables.. it sounds like the problem is in your dvd player. make sure you have the video cable plugged into the correct slot on the dvd player.
Mar 01, 2010 | Oritron Televison & Video
The DVD player only has audio, no video
That may be a problem at the head of the video cable, try to replace it, and see if that solve your problem.
Dec 30, 2009 | Televison & Video
Player works fine, speaker works fine but screen is blank...
This dvd player is having a problem with the video input /output circuits. This could be a minor problem with a loose connector or some over expanded solder joints. It could also be a problem with the video ic have a problem with its circuits. The connector problem and the possible cold solder joint problem can be repaired. The dvd player must be taken apart and the connection cleaned and repaired. If the problem is with the video solid state components, you will have to have it repaired by a service center. The video has a main ribbion connector that connects the laser lens to the main board video inputs. This ribbion cable usually will run under the laser transport mechanism. It is connected to the main board and laser transport by clamping connectors. You can look and see if this connector is loose or bent and has lost its function. Try cleaning the contacts points of the connectors and the connectors on the main board and laser transport.Also look for bad or cold solder joints in the areas of the connectors. Try to resolder these points.Use new solder to insure a good connection. Remember to only work on these dvd player with all power disconnected. Always wear anti-static wrist bands and gloves when working on the dvd player to prevent further damage. If the cleaning and repairing the of the possible cold solder joints do not repair the problem, you probably have a bad video chip and should replace the dvd player.I hope this information helps you with your problem.
Mar 21, 2009 | Mintek MDP-1815 Portable DVD Player
Picture of dvd wont play
just bought a new car with one of these dvd players. when i put a dvd in, the sound is working fine but the screen says it cant show the picture because the car is in motion
Mar 21, 2008 | Eclipse AVX5000 Car DVD Player
DVD no picture but sound ok lg v8824w
hi there, had same problem, try turning on the player then holding the stop button on the remote for five seconds.this should restore the video picture
Jan 19, 2008 | Televison & Video
How do you take progressive scan off
eject the tray and press the stop button for 5 - 10 seconds...if not stop then try pause button
Nov 17, 2007 | TruTech TT320
Flickering of screen (comes and goes) and weird DVD/reception problems
Depending on how old this set is, there might be a bad Hyper board bad. good Luck
Jun 29, 2007 | Toshiba 43H70 43" Rear Projection...
Cyberhome CH-DVD 300 DVD Player Logo
249 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
