Question about Westinghouse 0101 IntelliBLEND¿ Work Top Blender
Westinghouse inteliblender This blender has been on the shelf a couple of months. When plugged in the blender does not start, mix, blend, chop. The recipe menu comes up and works fine.
  • 1 more comment
  • Anonymous Oct 25, 2008
    Mine did the same thing....but being an electrician I took it apart and put a meer on teh motor leads and found that the windings were open. So basically the motor is shot. So unless you can get a replacement motor it's toast.
  • latina123069 Jan 04, 2009
    My's don't want to do anything at all... where you push the blend button or chop button etc....
  • Anonymous Mar 21, 2009
    i also had the same problem while i was using it.
Mine developed the same problem except it stopped blending while I was using it. Being an electrician I opened mine up and put a meter on the motor windings and found that the windings were open. So basically the motor is shot...unless you can find a part number for motor replacement or if your's is still under a warranty...it might just be easier to buy a new blender.
Posted on Oct 25, 2008
Recepies for the cactus smoothie
Some of the names of cactus smoothies are:
a. Detox Cactus Smoothie
b. Pineapple Cactus Smoothie
c. Cactus Pear Green Smoothie
d. Nopal Cactus Smoothie, etc
Nov 29, 2016 | Blenders
Oven will not heat up
Kitchen Aid blenders are used for chopping/blending not heating.
Apr 03, 2014 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Ninja stopped working
Our Ninja 1100 also stopped during blending.
We set it aside and chopped manually.
Next day tried it again - it works.
Reason: motor probably has overheating protection. Must wait until motor cools down enough to re-start. So don't overload or overwork it.
Feb 27, 2014 | NINJA Blenders
Diagram of 06 jeep grand cherokke blend doors
Asking about a Jeep Grand Cherokee in the kitchen blender department will probably not get you the information you need.
Jul 25, 2013 | Vitamix Vita-Mix 18007 Door Cover for...
Cuisinart Quick Prep is not working properly
I think the ice was too hard for a hand blender. I think the impact has caused the blade to separate from the shaft or caused the shaft to separate internally. If your blender is still under warranty you might be able to get it fixed. Note: none of the "Smoothy" recipes in the manual call for ice. One uses ice-cream. One uses "partially thawed frozen strawberries" and one uses sherbet.
Oct 11, 2009 | Cuisinart CSB-33 Quick Prep Handheld...
When trying to blend things like frozen fruit or frozen yogurt with the Vitamix, the blade stops moving, but the motor continues running. Even if there's only enough frozen yogurt to cover the blades, it...
Frozen elements are generally not recommended for blenders of any brand. They may cause the blade assembly to stop moving completely, or to "bog down," and this may eventually damage the motor. It is recommended that frozen fruits and/or yogurt be thawed when possible before placing into a blender. If this is not a possibility for you, I would use a "pulse" or "chop ice" function to rapidly spin the blades for just a moment. This will chop the contents in smaller, more manageable parts. This should be done before adding other liquid ingredients.
Jul 09, 2009 | Vitamix Blenders
While mixing anything the mixer will slow down and usually stop.
This is normal for household type blenders. Sounds like you do a lot of blending. Commercial blenders provide more power and can withstand lots of blending projects. Thicker the material the more load on the motor. As the motor heats up the winding become hot and the motor begins to breakdown,
I really hope this helps answer your question. If not please let me know... Thanks, Sea Breeze
Jan 24, 2009 | Sunbeam Blenders
KITCHENAIDE BLENDER
sounds like you engage gogs under you canister are slipping or wore out lift up your canister to check them. not sure if your particular model has set screws in them or not look and see might be it hope this helps
Sep 01, 2008 | KitchenAid KSB5 Professional Stainless...
Blender performes poorly, if at all
Hi, cauliflour is not compact no water mix, I have suggestion , cut it 1/2" long make it fine put in blender mix w/small amount of water then start. shut off mix with wooden mixer and start again then okey.
Jan 14, 2008 | KitchenAid KSB5 Professional Stainless...
Westinghouse 0101 IntelliBLEND¿ Work Top Blender Logo
275 people viewed this question
Top Westinghouse Blenders Experts
eyecam
ray gallant
Tom Chichester
Are you a Westinghouse Blender Expert? Answer questions, earn points and help others
