Question about Acer Aspire 5100-3357 Notebook
Aspire 5100 keyboard not responsive
Keyboard and touch pad not working. black screen that states; the last attempt to resume the system from its previous location failed. attempt to resume again? (use the arrow keys to highlight your choice.)     continue with system resume     delete restoration data and proceed to system boot menu
 i attempted to resume but there where no response from the keyboard
  • Anonymous Jan 16, 2009
    My computer is also an Acer Aspire 5100 and it froze.My only choice was to turn my computer off by pressing the little off button. after that It wouldnt turn on at all. It finally comes on now but my keyboard or touch pad will not work. I've tried to use the instructions by pressing Fn+F4,Fn+F5, Fn+F6, and Fn+F and nothing worked.
  • Anonymous Apr 10, 2009
    Same problem here,
    but not on a laptop.
    Got into that state by choosing sleep mode.
    Keyboard does not work.
    Got an old keyboard out (no USB)... does not work either.
    And it stays it this screen too... if it would only do one of the two choices.. i don't care which.
Pointer stuck in middle of screen on my acer laptop,Help!!
Are you using a mouse or the touch pad? Make sure the touch pad is turned on.
Jan 06, 2010 | Acer Aspire 5100 Notebook
Unresponsive keyboard + mouse pad
I guess you have a mechanical problem, sounds like the mother board have some issues on starting all devices.
If you could use keyboard to go in the bios, and see the screen, if would be the OS that need to be repaired.
Aug 04, 2009 | Acer Aspire 5100 Notebook
Keyboard and mouse pad on my laptop. Acer 5100 vista
On an Acer, the Fn key plus F7 will turn the touchpad on and off.
Try that to see if it works.
Mar 22, 2009 | Acer Aspire 5100 Notebook
Aspire 5100 Kepad and touchpad not working
have k/b and touch pad been disabled in BIOS?
Oct 30, 2008 | Acer Aspire 5100 Notebook
Acer aspire 5100
please take the laptop to the service center
Jul 27, 2008 | Acer Aspire 5100-5022 Notebook
Acer aspire 5100
This is generally a driver glitch. You will need to use an external keyboard and mouse, in order to uninstall the drivers for the onboard keyboard and mouse from the device manager, then disconnect the externals and reboot. The machine will find and reinstall the drivers for them automatically. If this doesn't work, then the problem is with the motherboard and you will need to have it serviced.
Jul 03, 2008 | Acer Aspire 5100 Notebook
Window resume loader
There is a known corruption problem with Windows Vista's resume operation, but I've not yet confronted it on a laptop. On a desktop the problem occurs when a USB keyboard is in use, and the resolution is to unplug it and make sure that you're using a standard PS/2 keyboard instead, but I am not sure if this will work on a notepad. It depends if the notepad scans for an external keypad at boot time. Try plugging in an external keyboard before you turn the power on and see if that works.
If it doesn't work, I'm not sure what to suggest. People who have had this problem appear to have tried everything from resetting the BIOS to reformatting the hard drive. If you try it and report failure I'll investigate the matter further.
May 28, 2008 | Acer Aspire E380-UD420A (ASE380-UD420A)...
Keyboard, Touch mouse and all USB pads not working
first of all u have to re install windows( operating system)
before inserting the windows cd u have to plug an external keybord and mouse and start the system.
boot from cd and continue.
the laptop keybord and mouse could be unusable anymore.
May 24, 2008 | Acer Aspire 5100 Notebook
maybe a driver issue.... if possible, attempt to find the keyboard drivers for it again... might have to do it from a different computer.
Apr 06, 2008 | Acer Aspire 5100 Notebook
Frozen keyboard acer 5100
for aspire 3050, try to remove the battery, battery can cause many strange thing.
if you still got problem after removing battery, it's look like motherboard need repair.
Mar 02, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 5100-3357 Notebook Logo
476 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
