Question about Watts Onan Portable Generator - 4000 , Model# 5500
Onan 4000 RV Generator - where is the oil drain plug?
Where is the plug to drain the oil on an Onan 4000 Generator? My manual just has an arrow pointing to the bottom, but there is no access. I think it looks like it is near the dipstick, but it is a female plug. If it is, what kind of tool do you use?
Thanks - LXILABS.
  • Anonymous Mar 12, 2014
    will not start
It should have a cover on the floor bottom that is held in place with two torx (star) screws. remove the cover and you can remove the plug with a 9/16 socket.
Posted on Dec 02, 2008
What is the point gap for model:CCKA-S/25830?
Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ...
www.partsfortechs.com > Home > Generator Part
Generator Parts Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ... for this plug require the spark gap to be set at .025" (25 thousandths of an inch).
Onan Gen HGJAB What is the best spark plug and gap? - Heartland ...
https://www.heartlandowners.org/.../39632-Onan-Gen-HGJAB-What-is-t...
Jun 8, 2013 - 3 posts - ‎3 authors Also what is the the correct gap on the plugs? ... brands · Generators; Onan Gen HGJAB What is the best spark plug and gap? ... Gap: 0.025
Nov 04, 2015 | Watts Onan Portable Generator - 4000 ,...
How to fix onan 4000 that will not stay running
Check the slips rings and brushes, check the stator and rotor windings for continuity and for shorts to ground. Check PCB plug connections. After that you need a new control board
Jan 07, 2013 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
Sensor de aceite de un onan cummins rv QG 4000 generator 4000w
If it runs while start button is pressed but stops when you let go?
Check the rotor bruhes, slip rings are clean on the rotor. If you want to get deeper check and ohm the resisitance of the rotor, and stator both for continuity and ground shorts. Check plugs and wiring on control board. Failing that replace control board
Nov 18, 2012 | Onan Cummins RV QG 4000 Generator, 4000W,...
Oil is being pulled from valve cover to air filter on my onan microquiet 4000 generator, what do I need to do?
63525c2e-e749-4a53-8402-d0463bb6c753.jpgThat sounds like the reed valve sticking or dirty.
You will need to take out the reed valve, clean and re-install. Be aware that a small amount of oil is common, also do not over fill the oil. The full mark is hot. Too much oil in the crakcase can build up pressure and keep the reed valve open.
Aug 22, 2012 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
Manuals for Onan 6.5NH-3CR/16004P RV generator
onan mcgraw RV model NH-3CR/1600HP, need to know how much oil,what weight of oil how much etc, the type of spark plug , oil filter, all the specs
Aug 04, 2010 | Garden
Onan generator service codes
Check the spark plug and the ignition coil for good sparking.
Get the spark plug out, or with another spark plug connected to high voltage cable, outside the motor, the outer part of the plug connected to motor ground and see if spark is present at cranking.
Jun 30, 2010 | Watts Onan Portable Generator - 4000 ,...
Oil Leak
Need model and serial number off this unit in order to proceed.
However, if it is a KY model, with an about 2" cover underneath. That cover is blocking the oil drain plug. It is possible that the oil drain plug is leaking. Remove and drain oil into pan. Clean the plug and add plumbers tape to the plug and install. Then fill the unit back up with oil.
Mar 14, 2009 | Watts Onan Portable Generator - 4000 ,...
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
1,238 people viewed this question
Top Watts Electrical Supplies Experts
rlev_7
Level 1 Expert
Steve
Jim London
Jim London
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
