Question about Refrigerators
Water accumulates under the crisper - Refrigerators
  • 943 Answers
Hi thanks for the question you have a clogged drain hose from the freezer to the drain tray underneath the fridge clean that tube it should be fine thanks the appliance doc
Posted on Sep 27, 2008
Why is water leaking from the inside bottom of refrigerator?
Hay Lola , your drain hose is clogged open the back panel and blowdry all the ice until the water drains good luck APPLIANCES R EN
Mar 14, 2013 | Magic Chef Refrigerators
Water accumulating in bottom of refrig under crisper drawers but not in drain pan under unit.cannot locate drain line
Here is a tip that I wrote about how to fix your freezer so that the drain hole does not keep freezing up.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 23, 2010 | Kenmore Refrigerators
Water leakage out of fridge
it may drain hose is loose
Jun 04, 2010 | LG Refrigerators
Water under the crisper
it needs a good de frost now as a chunk of ice develped in a line. un plug fridge, let it warm up, use the chance to give it a good cleaning. this should solve the problem.
Nov 04, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
For some time, water was accumulating on the floor
before you call check the bottom of your freezer, if it is full of ice, yuou more than likely have a clogged defrost drain
remove the back panel of the freezer and ensure the drain is free and clear,
check the fill tube of the ice machine to be properly installed
Oct 13, 2009 | Refrigerators
Unexplained water accumulation under the crisper/produce
OK, I am going to give you a lot of information on one page, so please read carefully and choose the parts that apply to you. PS, Please rate my solution and my thanks to all the Guru's that helped put the following page together. please click on link below, Thanks Sea Breeze
HOW TO FIX A DRAIN LEAK INSIDE REFRIGERATOR AND FREEZER PART 2
Aug 10, 2009 | Whirlpool Refrigerators
Whirlpool fridge ET1NHMXKT00 water accumulates under the crispers
Hhi, Yes the drain is plugged. remove the floor panel in the freezer and then the rear panel. Locate the drain hole (right side of drain pan) and melt all the ice. there is an after market drain heater kit that you will need to buy and add to the defrost heater.
It is a design problem. Part# 819043
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 25, 2009 | Whirlpool ET1NHMXKT Top Freezer...
Water accumulation under crisper bins
Check that the hole at the back of the fridge is not blocked with gunge.  There should be a drip tray at the rear with 2 slopes towards the hole where the condensation drains to.  Some cabinets come with a little rod to clear the blockage.  The rod may live in the hole alowing water to drain around it.  Have a peek!
Feb 22, 2009 | Frigidaire FRT18S6AW Top Freezer...
Water Is accumulating at the bottom of my fridge....below the vegetable/fruit crispers. The fridge however contiues to keep things cold.
The automatic defroster is supposed to drip down a tube and deposit water into a tray underneath the refrigerator. If that tube becomes clogged with either ice or mold, water is supposed to drip down the back of the refrigerator and go under the crispers, but there is a drain under there that takes it to the tray under the refrigerator. That drain might get clogged with mold or food.
So my suggestion is, try to clear out the drains under the crispers. More difficult, remove the floor of the freezing compartment and clear out the drain there. If it is severely clogged with ice under there, you have a defrosting problem.
In this hot, muggy weather you are likely to get lots of condensation. Good luck.
Jun 13, 2008 | Whirlpool Refrigerators
Refrigerator
check behind the drawers is there a water tank for water in thew door that would be my first guess
Feb 10, 2008 | Kenmore 63074 Top Freezer Refrigerator
Refrigerators Logo
123 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
