Question about Hitachi 60VS810 60" Rear Projection HDTV-Ready Television
Hitachi 60vs810 blue screen only no other functions but on, off
Turn tv on, blue screen and no other functions work, but on off
  • 2 more comments
  • bose802 Sep 30, 2008
    The inside of the unit is dust free.
    Blue power light flashes till bulb warms up, and shows a blue screen. I can't bring up any other screens, when I shut the unit off, the blue power light blinks till cool down, and the unit turns off. The bulb and temp light come on for a breif second when you turn the unit on, but it has always done that.
    The owners manual says this is normal operation, the power light will blink 12-15 seconds as the bulb warms up.
    I have tried leaving it unplugged for a week, still no success on reseting it.
    Brigadier General:
  • 6,966 Answers
Often a "blue screen" is an indication of the absence of an usable video signal similar to mute for audio. Frozen/no controls after power up as an indicator of logic problem/controller problem. Think of it as like a computer, will boot but hang and then the BSOD (blue screen of death). Initially, pls check all your signal source cables, try switching them around, remove the battery of the remote, see if any buttons in the front/side panel control are stuck.
This then would translate to either a hardware or firmware problem. Since you have tried a "reset" and the system still hangs, then it is most likely a hardware problem.
This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 30, 2008
    Master:
  • 763 Answers
Try to pull the power plug for about a couple of minutes and after that turn it on. see also the settings of your tv and manual of it. if all suggestions here didnt fix your problem then you might send it to repair service. hope that helps!
CHARCOIS
    Scholar:
  • 148 Answers
Is there any led indicators that appears.. to blink or flashing?
  • Zander Rovic Ocampo
    Zander Rovic Ocampo Sep 30, 2008
    The STANDBY light will flash if an issue is detected within the
    television. This can sometimes be resolved by simply following the
    steps below to reset the television.
    1. Turn off the television. IMPORTANT: For
      a projection television that uses an internal lamp, wait 5 minutes
      after turning off the television to allow the lamp to cool before
      continuing with the following steps.
    2. Unplug the television power cord from the electrical outlet.
    3. Let the television remain without power for 60 seconds.
    4. Plug the power cord back into the electrical outlet. NOTE: If
      the television is plugged into a power strip or surge protector, remove
      it from the power strip or surge protector and plug it directly into
      the wall outlet. If the issue is resolved, the problem is with the
      power strip or surge protector and not the television.
    5. Turn on the television.
    If the issue is still unresolved after following all of the troubleshooting steps, service is required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
    Genius:
  • 1,913 Answers
Check your power supply and eartihing probelm.
open the case of your tv and clear dust and also dry the all things amy be there is dust .
Tv will not stay on
Power board problem. Find a honest TV Tech.
Nov 11, 2013 | Hitachi 60VS810 60" Rear Projection...
Tv shuts off when tuned on
FIRST TRY TO UNPLUG SET AND REPLUG IT. BUT IT SOUNDS LIKE YOU HAVE A POWER SUPPLY BOARD PROBLEM. FIND A HONEST TV TECH. THIS IS A GREAT MACHINE.
Hi, I have a 60VS810 60inch LCD projection and the blue power light flashes but no picture comes on...i just got it for free so i dont know how it worked before..yesterday i did get a blury pic on the...
Flashes of blue light are fault indications. From the number of flashes occurs at one time switch on, you can get an idea about the faulty section circuit board inside. If you wish to get details about these blinks, check this link.
Mar 14, 2013 | Hitachi 60VS810 60" Rear Projection...
My 60vs810 will not come on. the power on light blinks and the screen has a faint blue tint
Hi, How long has it been sence the lamp has been changed ? Is the lamp indicator light on or the temp light? Sometimes a lamp will become weak and not turn the lamp indicator on at all. I had a 50V715 kinda do the same thing. But.. it would come on for about 3 to 30 sec. then shut down and start over again. It was the lamp, It drove me crazy for about 3 wks. Well... all said, it could be the lamp. Hope this is helpful.
Nov 23, 2009 | Hitachi Televison & Video
Hi, I have a 60VS810 60inch LCD projection. Normally when i turn on the TV, theres a blue led that flashes, and when the blue led turns solid, the screen picture appears. My problem now is that the blue...
It could possibly be the power supply unit or the lamp.The power unit is HA01331. cost is about $120.The lamp is UX21514 cost about the same. Hope this is helpful.
Oct 23, 2009 | Hitachi 60VS810 60" Rear Projection...
Picture intermittently goes dim.
How many hours on the lamp timer?  If 10,000 or more the lamp is approaching end of life and should be replaced.  Lamp will dim when approaching end of life rather than just go out.
Jun 03, 2009 | Hitachi 60VS810 60" Rear Projection...
Hitachi 26LD6600 no signal coming up
You have to switch the Television to the correct input line. This can be done by pressing an Input, or AV of function button on the television remote control.
Nov 08, 2008 | Hitachi 26LD6600 26 in. HD-Ready LCD...
Tv won't stay on
Try removing the back of the set and vacuum out the inside. It should only be a few screws and may even have little arrows pointing at them. Be sure to unplug the set first.
Feb 29, 2008 | Hitachi 60VS810 60" Rear Projection...
Hitachi 60VS810 60" Rear Projection HDTV-Ready Television Logo
202 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
