Question about Targus AMW15US Mouse
USB device not being picked up
I purchased the AMW15US and am using it on my laptop with Windows Vista.
Spontaneously, my computer stopped recognizing the USB device. It still glows, but it doesn't pick up the mouse signal or anything. I've tried plugging it into different USB ports, restarting the machine, etc. Nothing works. Has anyone else had that problem?
  • Anonymous Oct 01, 2008
    i have the same problem. my computer doesnt reconize the usb any more and i dont know how to solve the problem
  • Anonymous Nov 20, 2008
    I have the same problem
Ganesh
Posted on Sep 27, 2008
Canon Canoscan LiDE 25 shows "USB device not recognized" on Vista Home Premium 32-bit
Point # 1 : Electronic devices are not made to be used sparingly or stored for long periods of time.
Point # 2 : 5-6 years is not 'barely' in-terms of an electronic device's lifetime (Given that the warranty for your device is about 1 year !).
Point # 3 : You obviously tried almost everything on the computer site of this issue, Its time to take your device to a service center.
Dec 03, 2013 | Canon CanoScan LiDE 25 Flatbed Scanner
My Windows 7 cannot recognize my Sata/usb connector
USB hard drive is a portable external storage device that works just like a conventional hard drive. The device is simply plugged into a USB port on your computer as you would connect a flash drive. Unlike a flash drive, however, a USB hard drive can store a much larger amount of data. If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely. Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7). The USB device should be listed as "removable disk" once it is plugged into the computer. If it is not listed among the available drives on your computer, proceed to the next step. Ensure that the data cable is working properly. Try another USB cable if you have one available. Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive. Reboot the computer if the USB hard drive is still not recognized. Plug the USB cable into another USB port and check to see if the device is detected. If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port. If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem. Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager." For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter." Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives." If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears. The external hard drive may have been detected but the device is not working properly. If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced. Hope this helps.
b>
Jan 04, 2013 | Apricorn SATA Wire 3.0 - storage...
Not recognice by usb hard
A USB hard drive is a portable external storage device that works just like a conventional hard drive.
Hope this helps
Nov 07, 2012 | Computers & Internet
Windows xp does not recognize the wireless targus model amw15us. Registers as unknown device.
While pc is on.unpug usb adapter for mouse.then turn off pc.
Turn pc back on then plug adapter back in.
Jan 05, 2010 | Targus AMW15US
USB Memory Key not Recognized on Desktop running Windows Vista
check the formats of the keys. if they are NTFS they might not be recognized by earlier Windows versions. What version of windows does the laptop computer use? It may be as simple as using the correct formatting (FAT or FAT32) on the USB memory key.
Sep 14, 2009 | Maxtor Hard Drive
This solution worked for me when I got the USB device not recognized message:
http://www.infobarrel.com/USB_Port_Repair
It can be quite frustrating. I've heard that older computers are more likely to have the USB device not recognized message.
May 31, 2009 | Dell Inspiron 6400 Notebook
I purchased the AMW15US and am using it on my laptop with Vista
Go to control Panel and click on the Mouse icon. Then it it should show weather you can change the buttons and settings. Most do. Hope this helps. Bud
Nov 29, 2008 | Targus AMW15US Mouse
Targus Wireless Laser Rechargeable Notebook Mouse problem
The mouse worked initially....have you tried doing a system restore back to a few weeks ago to see if that solves the problem..
With Vista and so many of it's incompatibility issue's...you maybe have downloaded something and it corrupted your software for that mouse...
Here is the url with vista drivers. Redownload the drivers and install...see if this helps
http://www.targus.com/us/support_downloads.asp
Feb 25, 2008 | Targus AMW15US
"USB Device Not Recognized" - any usb device
1-Make sure you are using XP SP2. You probably are but just in case....
2-Unplug all USB devices
3-Uninstall any software for the devices you just unplugged
4-Reboot into safe mode and open the device manager. Make sure to choose the show hidden devices option
Note: Follow the order of removal exactly and this MUST be done in safe mode only!
5-Remove any entries for USB peripherals like scanners and printers
6-Remove any entries for HID devices or Combp USB devices
7-Remove all USB root hub entries
8-Remove all USB host controller entries
9-Reboot to normal mode, let Windows reset the USB stack and try your thumb drive.
If this didn't work then repeat steps 1-8.
Staying in safe mode, right click in the device manager and scan for hardware changes. Let Windows reset the USB stack and try your thumb drive again.
Also when doing any of this try and get a hold of another thumb drive and try it instead of yours. Your thumb drive could be the source of the trouble. We had similar issues we tracked down to a bad batch of Memorex thumb drives.
Jan 20, 2008 | Toshiba Satellite A135-S2276 Notebook
Vista and firewire 1394?
Firewire works fine under Vista, but it's quite possible your USB to Firewire bridge doesn't have proper Vista drivers. You wouldn't expect Vista to include these, they would be installed from a disc that came with your adaptor. USB to Firewire is a questionable option at best... there are often problems with it. You may be better off with a PC-Card or ExpressCard solution, if the laptop is your only computer.
Also, when the camera says "DV IN", it's expecting video from the PC to be sent to it, it's not in capture mode. Most camcorders must be in either "play" mode, or a special "link to PC" mode in order to even be recognized by Windows (any version) as a video input device.
However, until you resolve the issue of supporting your Firewire device in Vista, nothing the camcorder does will be an issue yet. You should check the documentation that came with your USB to Firewire device, the driver disc, etc. for information on Vista support.
Jan 05, 2008 | Canon ZR200 Mini DV Digital Camcorder
Targus AMW15US Mouse Logo
617 people viewed this question
Top Targus Computers & Internet Experts
steve morris
steve morris
Brian Sullivan
Brian Sullivan
dhnguyen
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
