Question about Sharp XR-30X Projector
The power light blinks green and beeps , no lamp turns on , has been stored for 2 months
This projector has not been used in at least 2 months, I hook it up and press the power key and the lamp does not light and the power light blinks green and beeps, I have been through the manual and everything they say to do does not work, I would like to avoid bringing it into the shop. can you guide me or should I bring it to the shop?
  • amberdee Dec 06, 2008
    green light blinks indicating bulb is warming, but shuts down and will not turn on
    Problem Solver:
I'm not an expert, just a fellow XR-30X owner. I have two suggestions: 1) unplug the unit for 30 seconds or so and then plug it back in. I guess this "reboots" it or something, but has fixed several weird problems for me. 2) If that doesn't work, a blinking green Lamp light usually means that the bulb is burned out. Visually inspect it to see if it looks bad. (Mine had black marks and clouds on the lens.) Replacing it is fairly easy, but the bulbs are costly.
Posted on May 03, 2009
The indicator of temperature is red, the indicator of the bulb is off and the fan after 3 o 5 minutes
PowerLite 7800p Multimedia Projector - Epson
EpsonPowerLite 7800p Multimedia Projector. Support ... Indicator Light, Status, Description... Temperature, Red, The projector is overheating, which turns the lamp off ...
PowerLite 735c Multimedia Projector - Epson
EpsonPowerLite 735c Multimedia Projector ... Indicator Light, Status, Description ...Lamp/Temperature, Red, The projector is overheating, which turns the lamp off ...
Maintenance Indicators - ManualsLib > ... > Notevision PG-F212X > Operation manual
The warning lights (power indicator, lamp indicator and temperature warning... ... Redon. Normal (Standby). Green on. Normal (Power on). Red blinks. Abnormal ... Sharpmultimedia projector model xg-mb67x-l operation manual (71 pages).
Dec 14, 2015 | Office Equipment & Supplies
Epson 460 powerlite hooked to smartboard green light blinking and no image.
Yes this is most likely the lamp. Does it eventually go back to just a red light?
Dec 06, 2012 | Epson PowerLite 410W LCD Projector
Epson 84+ green light blinks no light
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
May 21, 2012 | Epson Corporati PROJECTOR, EPSON,...
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
Hello. I have optoma ep716 with problem: 1. When I power it on the green blinking for 20-30 seconds and after this stays green. Due to manual it's meaning that projector on however lamp does not provide...
Do one one thing. check the lamp of your projector. For removing the lamp see the bellow picture.
also check the lamp colling fan. If it is faulty this fault can occur.
1. Use a screwdriver to remove the screw from the cover.(1)
2.Push up and remove the cover.(2)
3. Remove the 2 screws from the lamp module.(3)
4.Pull out the lamp module. (4)
Feb 16, 2011 | Optoma (BL-FU180A) Projector Lamp for...
Lamp not lighting
Reset the lamp and try it.
Mar 28, 2008 | NEC VT660 Multimedia Projector
Sharp XR-30X Projector Logo
244 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
