Question about Emerson Audio Players & Recorders
Emerson SmartSet Dual Alarm Clock Radio Won't Stop "Flickering"
Clock radio was unplugged for several days. When it was plugged in again, it would not stop flickering or blinking (all lights) to set a time. It also will not play the radio. It was working fine prior to being unlugged. It is about 3 years old. Any ideas?
Problem was solved. When clock was plugged in after a few more days, it finally stopped flickering and reported an incorrect time and day. Low battery was now blinking! Checked calendar and found all memory was lost. Purchased and installed a new battery and this time when clock was plugged in it correctly set itself! Fixed.
Posted on Oct 11, 2008
I have the emerson smartset clock radio. model cks1702. i need the mannuel so i can set it to go off through the week
There are several SmartSet clock Radios by Emerson. Which model do you have?
It's possible that you have alarm 1 and alarm 2 both set for weekends (if a two-alarm version). For the SmartSet radio, CKD5811, that I am used to, you can change the alarm mode between Everyday, Weekdays and Weekends. Press and hold the Alarm 1 (or Alarm 2) button then press the Alarm Mode button to toggle between the modes. Then release both buttons. If you press the Alarm 1 button, you will see the current alarm mode indicated by the indicators by the day that are lit. The Alarm Mode button is between the On/Off button and the Alarm 1 and 2 buttons on the CKD5811. Make sure that you have the Wake to Radio, Wake to Buzzer or Wake to CD slide set for the alarm in question. For Wake to Radio, set your station. For Wake to CD, make sure that the CD in the unit is one that actually plays in the unit (scratches, etc). Also check the volume (although that seems like less of a concern since it does wake you on weekends).
The manual for the CKD5811 is here:
http://www.emersonradio.com/resources/owner_manuals/manual_1312917117.pdf . Additional manuals are here: http://www.emersonradio.com/owner_manuals.php . Scroll down in the drop down menu for the SmartSet manuals (clock radios all start CKD). The manuals are in alphabetical order.
I hope this helps.
Oct 29, 2011 | Emerson Smartset Clock Radio
Emerson cks3528 Dual alarm clock radio smartset projection Lost User Manual to set time,alarms? Any advice...Thanks
You can get the manual on the link below. Please alow time to load large file.
http://www.emersonradio.com/owners/SmartSet%20Series/CKS3528_110606.pdf
Good Luck and please rate 4 thumbs up for the free answer
Apr 24, 2010 | Emerson Smartset Clock Radio
Manual for Emerson smartset alarm clock
As you haven't mentioned the model no. so I am giving you a link from where you can download the manual for your appropriate model.
Good luck....and have a nice day. Rating the solution is highly appreciated.
Mar 16, 2010 | Emerson Smartset Clock Radio
Need to reset dual alarm to wake up
http://www.emersonradio.com/owners/SmartSet%20Series/ Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson web page of the smartset clock/radios. Find you model number smartset clock/radio and open the link to download a pdf copy of the owners manual.You can use the print function on your computer to make a pdf copy of the owners manual for you own use. I hope this information helps you with your problem.
Apr 08, 2009 | Emerson Smartset Clock Radio
I have an Emerson Smartset radio model cks1862 and cannot get the alarm to go off everyday. I already did everything the manual said to do to no avail. Any suggestions?
You will have to reset the Clock/Radio's microprocessor. To do this you have to unplug the Clock/Radio from the a/c outlet and remove the internal battery (CR2430). You must let the microprocessor completely drain by leaving it with out a power source for at least 2 hours. Then you can put the internal battery back in and plug in the Clock/Radio. Test and see if the functions have returned to normal. If they have not reset to normal functions, you then should replace the internal battery. Let the microprocessor drain of power again for at 2 hours and put in the new battery and test it again. It should return to normal function. If you are still having a problem, you may have a more serious problem with the microprocessor. The Emerson customer support telephone number is 1800-695-0098 you can call between the hours of 7am-5pm CT. Give them the make and model number of your Clock/Radio and ask them for assistance with your problem. I hope this information helps you with your Clock/Radio's alarm problem.
Jan 30, 2009 | Emerson Smartset Clock Radio
Emerson Smartset Clock Radio setting for everyday alarm
You will need to reset the Clock/Radio's microprocessor. To do this you must unplug the Clock/Radio and remove the internal battery (CR2430). Let the Clock/Radio set without any power source for at least 2 hours. Then put the internal battery back in the Clock/Radio and plug it in to the a/c outlet. Test to see if the Clock/Radio functions have returned to normal. If the function have not returned to normal, you will need to replace the internal battery. Then let the Clock/Radio again set with out power for a period of at least 2 hours. after a 2 hour period, put the new battery in the Clock/Radio and Plug it into the a/c outlet. Test the functions to see if the microprocessor has reset to normal operation. If you are still having a problem with the Clock/Radio's operations , you will have to give the Emerson customer support a call. The Telephone number for the Customer support is 1-800-898-9020. You can call them between the hours of 7am-5pm CT. Give them the make and model number of your Clock/Radio and ask them for assistance with your problem. I hope this information helps you fix the problem with the alarm in the Clock/Radio.
Smartset cd alarm clock radio-no working alarms
I had this same problem. I removed the battery and then unplugged it for about a half an hour. When I plugged it back in, I had to reset the date, time, year, time zone and alarm times, but the alarms now work!!
Nov 09, 2008 | Emerson Smartset Clock Radio
Emerson Smartset alarm clock
Hi - You can download the manual from the link underlined in blue below:
CKS3528
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Jun 25, 2008 | Emerson Smartset Clock Radio
Alarm not working
Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!
Oct 26, 2007 | Emerson Smartset Clock Radio
Setting the days on the alarm?
Hold the alarm button down and press the mode button to change the days of the week you want the alarm to go off.
Oct 11, 2007 | Emerson SmartSet CKS1850 Clock Radio
707 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
