Question about Zenith P42W34P 42 in. EDTV-Ready Plasma Television
Phillips plasma tv MDL 42PF9966 Black Line across screen
I have a black line across screen about 4" down frim top
  • Anonymous Mar 29, 2014
    faint lines across top of screen
  • 113 Answers
The ribbon cable to the drive has either came loose of the drive itself went bad. You can open up the back if you are confident and see if adjusting the cable gets the line back. If not you will need to replace the Upper Y Drive.
Thanks
Josh
Posted on Sep 27, 2008
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
Black vertical line down Sony TV screen
that isa capacitor at vertical area mostiy 1000 uf to 22000 /35volts
Sep 03, 2014 | Televison & Video
Thin black line across screen of plasma tv
lines on a plasma tv can be cause by a few different things. One of your buffers might be bad. The logic board might be bad. Or your tv screen coldu be bad. The only way to find out is by replacing the boards or the screen.
you can get parts for this tv at www.interliquidparts.com
Feb 24, 2012 | Samsung 50 in. Plasma TV
Horizontal black line running entire screen an 4 more lines running vertical
Hello
This type of fault in Plasma TVs are of power supply regulator capacitors. If any one of these DC capacitors, go low in rated value, proper smoothin of DC power does not occur. and black bars across the screen fro top to bottom will be the result. Just check for any capcitors of it power retulator side for bulged out or leaky. You have to open the TV to see whethere there is any of them is damaged. OK.
Jan 30, 2011 | Samsung 50 in. Plasma TV
A horizontal thin black line has appeared across screen.
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Jan 27, 2010 | JVC PD-42V475 42 in. HD-Ready Plasma...
I have a Phillips LCD tv just coming up to 2 years old. I now have a black line across the screen about 3" from top of screen. What is this and can I get rid of it??
You probably have a bad plasma panel. Have a repair shop check it out though because it could also be one of the buffer boards.
Oct 14, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Permanent horizontal line approx. 4" from top of screen
if this line is in the picture, that is possible burn in screen. if you have a black bar at the top or faint white lines that come down from top this is caused by defective filters in vertical circuit or bad vertical output. mch
Feb 20, 2009 | LG 50PC3D 50 in. Plasma Television
Thin black line
Try to replace the YSCAN board. If not fix it, then it's the PDP Panel failure.
Jan 07, 2009 | Samsung FPT5084 50 in. Plasma HDTV
Phillips 42in plasma lines ocross screen
Are the solid horizontal black lines or colored lines. If colored lines there is a posibility that your Y-main, and upper and lower Y-buffers are bad. If black you have a bad plasma panel.
Oct 08, 2007 | Philips 42PF9630A 42 in. Plasma Television
Zenith P42W34P 42 in. EDTV-Ready Plasma Television Logo
292 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
