Question about LaCie (300770) 250 GB Hard Drive
LaCie drive won't turn on (blue light doesn't go on)
I recently took my LaCie on a flight through security in my carry on. I just tried to plug it in to my iMac and it has no power. The blue light doesn't turn on but the green light on the power cord is on so I don't think it's the cable. Is there any way to fix this or is my hard drive dead?
  • 2 more comments
  • LoomisBub Oct 19, 2008
    I had the same problem with my drive. Tried a second power supply with no luck. I was going to take the drive out of the enclosure but I haven't figures out how. There is only one screw on the back and the top of the back seems to be stuck. Any ideas?
  • Anonymous Dec 10, 2008
    where do u get another hd enclosure?
    joan
    My light will not go on, the cable from outlet source is green, but the next leg of the journey to the disc doesnt light up the light and the computer does not recognize the drive as being there. what to do?
  • kiahmark Jan 26, 2009
    I have the same problem with my Lacie drive. It just stopped working, no light no noises no nothing. Tried changing the cable, no change and the cable light does come on. And, there are no screws whatsoever, so as a non-techy I have no idea how to take it apart and put it in an enclosure.
    How do I fix it without killing it forever?
  • Christina Stow
    Christina Stow Nov 16, 2013
    Same thing happened to me!
    Sniper:
  • 59 Answers
I doubt your hard drive is dead, even if your HD was dead the blue light would go one. It has to be the internal controller.. Your best bet is to get a HD enclosure and put your old drive in there. I've burned through 3 Lacie cases, all with similar problems..
Ciza
Posted on Oct 29, 2008
  • Christina Stow
    What a hassle though - why not just buy a new hard drive, so inexpensive now.
4big Quadra drive not appearing in disk utility or LaCie desktop manager
Could be defective. Try swapping power cord and usb cable with know good ones. You could also plug it into a different (known working) usb port.
Good Luck
Nov 28, 2013 | LaCie 4TB Biggest Quadra U SATA II Hard...
Lacie External Drive won't turn on (blue Light doesn't go on)
Inside the LaCie D2 250GB (300770) external harddrive's case, is a 250GB IDE (PATA) harddrive that is 3.5 inches across in width.
A desktop computer sized harddrive. (May be a Western Digital WD25000JB)
The harddrive plugs into a small circuit board, (Bridge board), and the circuit board has a USB port on it.
Using this Western Digital Passport for an example,
http://www.xbitlabs.com/misc/picture/?src=/images/storage/wd-passport-250gb/p3.jpg&1=1
Scroll down to the second photo, and left-click on it. The case of the external harddrive is shown open.
Inside is a 2.5 inch laptop sized harddrive.
An aluminum tape strip covers the small circuit board, attached at the back of the harddrive.
The second photo down on this page, shows you the small interface circuit board, that the harddrive plugs into, with the aluminum tape removed.
http://www.xbitlabs.com/articles/storage/display/wd-passport-250gb_2.html
(Another design has wires coming from the small circuit board, to an interface the harddrive plugs into )
It is this small circuit board that goes bad in a LaCie. QUITE common.
Solution?
Simple.
1) Obtain a 3.5 inch IDE external enclosure
2) Remove the 3.5 IDE harddrive from the LaCie's case.
3) Install the harddrive out of the LaCie into the external 3.5 IDE enclosure.
An example of a 3.5 IDE (PATA) external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 19, 2012 | LaCie (300770) 250 GB Hard Drive
My mac laptop suddenly won't recognize it
you may need to swap the usb port it's plugged in
Jun 11, 2012 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
My Mac suddenly cannot find my Lacie external storage device. I have turned off, unplugged, restarted... etc. and it is still not finding it. The Lacie seems to be on, at least the blue light is...
A continuous flashing light on a Lacie drive is a notification of a problem. I do wonder if the light is flashing the same if the drive is plugged in to the Mac or unplugged.
Lacie external drives tend to have power-supplies which become weak/bad. Most users replace the supply and it will work again for awhile until the supply dies again. Try bringing the drive to a retail dealer with Lacie drives -ask them if you can just test your drive with another power-supply (if you do not have another). You can also try calling Lacie, it's always slightly possible they will be aware of this problem.
Alternately, IF the light is only flashing when the drive is plugged-in to the computer, try using a different USB or Firewire cable.
Aug 31, 2009 | LaCie Computers & Internet
Fan keeps going, blue light always on, clicking noise
Hello
Have a look at the link below, it should be of help.
Click HERE to navigate.
Please feel free to let me know of you have any further questions.
Kind regards
Lock123
Jun 28, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Lacie hard drive won't turn on
My 1TB Lacie suddenly won't power up (no sound, no blue light). It turned out that I might have worn out the on/off switch over the seldom-use 4 years of usage. I push and flip the switch multiple times, and the Lacie came back to live and mount normally. I will just leave it at the On setting and simply pull the power cord when i want to switch it off.
Obviously, Lacie failed to do QA on the on/off switch because my 4 years usage did not totalled to more than 10 on/off per month.
Mar 09, 2009 | LaCie (301074) 80 GB Hard Drive
Hello, I have a Lacie 330770 250 GB hard drive.  It does not respond when I plug it into the outlet.  I have tried several different outlets in different rooms, and neither the green light on the power...
If the green light on your LaCie power supply does not light, you likely have a bad power supply. You can buy a new one from LaCie. If you are purchasing a new power supply from LaCie ask for the higher wattage unit. LaCie upgraded this a while back.
Jan 26, 2009 | LaCie (300770) 250 GB Hard Drive
My 500GB LaCie will not power up
that is an external drive correct. It should run just off the usb. is the drive recognized ?
Robert
Aug 27, 2008 | LaCie d2 Extreme (300793U) 500 GB Hard...
LaCie 250GB: Power (blue) light flickers when pushed, nothing happens
Sound very much like ypur disk is fried. Slim to zero chance of recovery.
Aug 26, 2017 | LaCie Big Disk (LAC300966U) 1024 GB Hard...
LaCie (300770) 250 GB Hard Drive Logo
1,116 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
