Question about Nokia 6300 Cellular Phone
I was doing a software update on a Nokia n73 and it failed. the phone now wont power up and seems to have corrupted the internal software i was doing a software update on a Nokia 6300 and it failed. the phone now wont power up and seems to have corrupted the internal software
SIM IN TO PROBLEM ON OFF PLEEJ FORMET SYSTEM
Posted on Sep 30, 2008
Not switch on my N73
try to update 1 more time maybe software corrupted
Aug 29, 2012 | Nokia N73 Cellular Phone
My nokia n73 dont open after software update corruption . any help?
Once you update your phone firmware then it fails,there is no longer you can retry that procedure again,because the phone needed in normal or in test mode.To fully recover your phone,It needs a gsmgadget flashing a complete package of firmware,and this can be possible by bringing the phone to a mobile service center.
Aug 19, 2011 | Nokia N73 Cellular Phone
I would like to update Nokia n73 music edition software. May i know the procedure. Thanks in advance.
Hi
For updating your firmaware of Nokia N73
You need to Download The following tools
  1. Nokia Pc Suite
  2. Nokia Software Updater
or else Nokia Ovi Suite
But i Will say the methods using Nokia software Updater
  • Download Nokia pc suite from
http://www.softpedia.com/progDownload/Nokia-PC-Suite-Download-11999.html
  • And Nokia software updater From
http://www.softpedia.com/progDownload/Nokia-Software-Updater-Download-141287.html
Install Nokia pc suite then Nokia software updater
It will ask for your PC to restart
Continue ,then Select Nokia software updater .
Connect your phone
It will Find out the connected phone
Before Proceeding further: A Word of CAUTION:
  • Your phone will be useless when updating failed in the Middle of updating due to System Restarts or Internet Connectin Failure or Cable Disconnection
  • So consider in mind that
U Need
  • An UN interrupted internet connection
  • Do not disconnect the Data cable after full installation of new firmware
  • Computer shall not restart or shutdown while updating
(If any of this failed the phone cannot be recovered )
So method continues.....
after Nokia software updater finds your phone, it will check for new firmware avail for your phone or not ,
\if avail select download and install
Keep in mind the Above words of caution
An advice is that If You feel not good ,then better give it yor nearest Nokia Service centre ,they will install a new firmware for your phone
Hope this will Help You........
May 13, 2010 | Nokia N73 Music Edition Smartphone
My N73 aint working at all i updated a software and it got hanged now its nt even starting
Dear Ashad , your phone software not done proper Updating. Result is phone software corrupted and dead. Only one solution Just Visit Nokia service center and tell then to install the updated software for your Nokia N73. Problem will solve then. If your handset not on at home you can't fix it by yourself.
Thanks & waiting for your feedback.
Feb 06, 2010 | Nokia N73 Cellular Phone
N73 Software update 4.0839.42.2.1 failed
remove the cable and before update make a backup then download the nokia software updater from here
http://europe.nokia.com/get-support-and-software/download-software/device-software-update# then wait about 15 minutes thats what the softare tells after that your phone is updated if
Dec 21, 2008 | Nokia N73 Cellular Phone
Nokia N73 got corrupted while updating software disconnected the phone
The Only thing that u can perform right now is to get ur phone flashed at the nearest phone repair man the hood.
flash is like to give it a new firmware/flash file/Software.
best regards
plz do aret this post so we can help others
Oct 07, 2008 | Nokia N73 Cellular Phone
MY N73`S SOFTWARE CORRUPTED
my phone memory is full i try already 2 restore my phone is not work and i open my phone they appear memory full what we ganna do plz can u help me
Jul 26, 2008 | Nokia N73 Cellular Phone
My N73 is off
when the software updating process is happening the PC must not be turned off.. if this happens then there is a possibility of the phone software getting corrupt.
think that has happened to your mobile also.. take it to nokia priority show room and reinstall the phone software.
N73 start up problem
Your phone needs to be reprogrammed, only a repair shop can do this for you.
You need to download the latest Nokia PC Suite to do an update on your phone.
Before updating software you should check that there’s a newer version of software available.
WARNING
When updating software on Mobs, be sure to:
HAVE A FULLY CHARGED BATTERY INSERTED;
PUT IT ON GENERAL PROFILE;
TURN OFF YOUR PIN NUMBER;
CONNECT YOUR CHARGER TO YOUR MOB AND SWITCH IT ON;
DO NOT ----- DO NOT ---- TOUCH YOUR PHONE WHILE THE UPDATE IS GOING ON;
THIS CAN TAKE 30 MINUTES OR MORE.
And obviously don’t unplug the phone from the PC.
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again (not recommended). But give it plenty of time.
It is also wise not to use your PC while updating software, just in case the PC freezes.
If the PC freezes during an update, you’re up the creek without a paddle...
I did an update on a Sony Eric 810i it took nearly two hours.
More... Your phone turns itself on and off, sometimes more than once while updating software, you should leave it well alone during the update.
May 05, 2008 | Nokia N73 Cellular Phone
Nokia N73 fail to turn on
There's nothing you can do to your phone. A repair shop might be able to re-program it. But it wont be cheap. Read below for future reference.
WARNING
And obviously don't unplug the phone from the PC.
If the PC freezes during an update, you're up the creek without a paddle...
Before updating software you should check that there's a newer version of software.
Feb 21, 2008 | Nokia N73 Cellular Phone
Nokia 6300 Cellular Phone Logo
99 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
