Question about Kenwood Excelon DDX-7015 Car DVD Player
Kenwood 8pin harness
The wires that go connected to this harness have been pulled in what order do they go back on that small harness? what goes where? 3 wires (black),(yellow)@(green) please help! thanks (8pin harness)
    New Friend:
Looking at back of 8 pin harnes, with wires facing you and tab facing up, left to right,
top
plugged into head unit i----------- i
______________________| |___________________________
| 1st pin, - blank | 2nd pin - Black wire | 3rd pin blank | 4th pin blank |
| 5th pin - yellow | 6th - pin blank | 7th pin- green| 8th blank |
Posted on Oct 26, 2008
2ooo Ford Mustang,Got MP538U TUNER work. cd look like it was playin no sound though.Exchanged it for MP638u.SAME BULL. cAR GOT ripped out mach system. Carstereo wires without harness
If you are wiring a Kenwood KDC-MP638U to a 2000 Ford Mustang, then below information may be of help:
  • to my knowledge, the original stereo unit uses 2 8pin connector and a single 7 pin connector;
  • if the connector with the harness has been cut, then wire splicing may have to be used based below;
  • If you are using external amplifiers, then it is possible to trigger/switch them with the blue/white wire and their RCA INputs connected to the appropriate RCA OUTputs of the Kenwood;
  • Additionally, the KDC-MP638U has built-in USB port/interface.
  • Incidentally, if what was previously installed is a full Mach system, pls be informed that there are seven (7) versions from Mach 1000.0 to Mach 1000.7, which one was installed?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 17, 2008 | Kenwood Car Audio & Video
I am changing my Blaupunkt car cassette entertainment system serial no BP9480P9471171 a modern Kenwood system. But although I have the schematic for the Kenwood which can be easily followed. There is no...
you can find which ones are the speaker wires by using a small AAA baterry with the car battery disconnected try touching to the wires 2 each side of the battery when you get the right ones the speaker will make a sound
Jul 12, 2014 | XM Radio Car Audio & Video
I HAVE A KENWOOD DNX9980HD 20 PIN HARNESS THAT CONNECTS TO THE KENWOOD HEAD UNIT. I ALSO HAVE AN AXXESS ASWC (STEERING WHEEL CONTROL MODULE)20 PIN HARNESS THAT CONNECTS TO THE AXXESS ASWC. THE AXXESS...
HI,
If you make a close verification on the back side of kenwood DNX9980HD 20 PIN HARNESS then you can see a Light Blue wire with Yellow stip ( BLUE/YELLOW) on it with a identification mark as "Remote cont". You have connect this wire to the Brown wire with white strip (BROWN/WHITE) from the 20 PIN HARNESS of AXXESS ASWC . There wil be a brown wire also from this 20 PIN HARNESS of AXXESS ASWC, leave it free insulated. It will not use with kenwood radios. You have to check for LIGHT BLUE with WHITE strip. There is also two other blue wires of which one with white strip. You hve to choose the light blue wire.
ok
Aug 06, 2011 | Car Audio & Video
Model KDC-MP142/CR When turning radio is always goes to STANDBY mode I want the radio to go on in the normal way. Also the clock to backs to 12:00 when radio is turn on. Thanks
Hello swanaprslc,
It sounds like the "always hot" or battery wire is not connected to a 12V constant source. If you used a wiring harness, check and make sure that the pin in the harness that connects to the "yellow" wire coming from your Kenwood MP142 is hot with the ignition off. If you did not use a wiring harness, make sure that the yellow wire is connected to a fused 12V + constant source.
Hope this helps.
Oct 17, 2009 | Kenwood Car Audio & Video
How to hook up a kdc-105 kenwood in a sunfire
There are 3 things you need to purchase for this install. 1) The factory spec install kit. 2) The factory spec additional wiring harness. 3) Antenna adapter.
Find the easied way to remove the plastic cowling around the radio and ac controls. Usually you can locate screws helping to retain the plastic dash parts. Be careful not to break the plastic dash by taking your time and looking over and over the part ofr connection hardware. Once you have located and removed all/if any screws, carefully pry out on the piece you are removing. There are often metal clips on the back of the piece that also help to retain the dash. Once that is removed, unbolt/unclip the factory stereo and slowly pull it out of the dash. Remove the factory harness from the backside of the factory stereo. DO NOT CUT THE HARNESS!! The wiring harness you have purchased is designed to plug and play into the factory harness. All you hae to do is color match the Kenwoods harness with the one you purchased. When wiring the two harnesses together use connectors **** a **** connectors, crimp connectors so forth and so on. If there is wiring you will not be using, take some electrical tape and tape the bare wire. We don't want a short. Once you are sure and have doubled checked that all the wiring is secure and matched, reverse the order of disassembly.
The plastic install kit should replace the factory radio size difference. Just remember to take the metal sleeve tha came with the kenwood and install it into the plastic install kit via the instructions provided. Slide the Aftermarket stereo into the sleeve you just installed. Then you are ready to make all the needed connections. Before you reassemble everything make sure to do a test run with your stereo. If all is well reassemble and jam on.
Sep 10, 2009 | 1999 Pontiac Sunfire
Aftermarket Stereo connection
hi there
if you matched all the wires from the harness to the kenwood deck and its not working don't worry you just missed the last step........(all wires attached that a colour coded connected)
simply turn your car on.........now on the front of the kenwood deck there is a SOURCE button with all units it could be a (S, SRC, Power) hold the source button down till your kenwood unit powers up ..........if your unit still doesn't work check the fuse on back of kenwood unit should be a 10a fuse (blue) if the fuse is fine put the unit back in dash..........now check the fuse panel on driver side dash with the door open you will see this panel pull it off (some describe the fuse panel as looking like an air vent but its not its a handle to open) now on the panel that you just pulled off there is a fuse diagram on the inside look at it find radio fuse it will be a (blue fuse) located in the top row of fuses check it if blown replace and unit should work.............if this doesn't solve the issue than its a (sneaky) fuse not to many people know about if you pop the hood of your car there is a black plastic panel located just below the battery pins and just above the driver head light (usually black box with yellow writing on it......in this there are mini fuses check all of them do not touch the black relays in there just the small tiny fuses the fuse you will look at should be yellow 20a (this fuse is closest to engine and comes after the abs relay if you look inside the lid you took off it will have fuse locations cant remember which one it is for sure but check them..........now see if your kenwood unit powers up if not the last option is to ground to the black wire from back of kenwood unit to metal frame.............this last part is also done if your unit does power on but your car lights don't work if this happens ground the kenwood unit to the frame of car and open up fuse panel on driver side dash replace the blown fuse for lights or radio (make sure the kenwood unit is grounded to the frame before replacing the fuse in dash panel............if this doesnt help you than i would assume the kenwood deck needs to be repaired by kenwood.......
good luck
hope i was able to help and sorry this list is so long
Feb 26, 2009 | Car Audio & Video
I need to install a kenwood cd player into my 2001 ford explorer step by step
goto the auto parts store and purchase a pair of stereo keys, fascia adaptor and wiring harness (you may need to get fascia and harness from a car audio store or circuit city.)
Then use the stereo keys to remove the factory stereo. Push them into the small holes on the front of the stereo push them slightly outwards and pull to release the stereo. Unplug all the connectors from back keeping track of where they fall.
Insert wiring harness into the stock wiring
attach fascia in regards to its packaged instructions.
Place cage from new stereo into the hole in the dash using the tabs on cage to secure it,
Attach stereo to other end of new harness along with aerial (may need adaptor for this also depending on the new head unit.)
Insert stereo into new cage and voila nice new stereo.
Nov 27, 2008 | Kenwood Car Audio & Video
DDX7017
go to spareparts.com
Oct 16, 2007 | Kenwood DDX7017 Car DVD Player
Kenwood DDX-7015
Check to find there www.partstore.com (search by model).
Feb 22, 2007 | Kenwood Excelon DDX-7015 Car DVD Player
Kenwood Excelon DDX-7015 Car DVD Player Logo
687 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
