HP iPAQ H5455 Pocket PC
Problem for HP iPAQ H5455 Pocket PC
Ok. i'm stomped.
By Rachel007 - usenet poster
ok. this may sound like a silly question, but I can't figure it out to save my life. ( this is my first pda. H5455)I do have wlan connection. It is on 128% signal. ( I have no idea how you get over 100% ) Naturally, I tried to use the internet explorer but I cannot get to any sites. I check the setting on connections/adapters/drivers. They are all correct. I have it set to dhcp. I want to use the lan line. I did find a setting to i connect to " work" or "internet" on connection settings. However, they are modem set up screens. I don't have modem and will never use modem. I have wireless broadband conection at work and home. I want to be able to use internet on my ipaq. Can anyone shed some lights? Thanks.
Solution #1
posted on May 30, 2006
Somewhat Helpful)
Horner
Rank: Apprentice
Rating: 0%, 0 votes
The work/internet settings are for the wireless adapter as well as modems. Go into the network settings - Start, Settings, Connections (tab), Connections, Set up my Proxy server. On the Proxy server tab, check the top box (This network connects to the Internet) but leave everything else on this page blank. On the General tab, the name should be "My Work Network." OK and then select the Advanced (tab), Select Networks and select "My Work Network" from both of the pull down lists.
I'm not sure if the iPaq has a powersave feature. Some PPCs do and this can cause the 'cannot connect' error so try to disable it.
Also, the 'welcome screen fix' works in some cases:
Open File Explorer
Go to Windows Folder
Scroll Down to the "W"s
Click on Welcome.exe
You will go through the welcome screen like you did when you first got your PPC (Note: Even though this will take you through the same process like after a hard reset, this is not the same as a hard reset. Your data/programs will not be lost).
Was this helpful?
Yes
No
Solution #2
posted on Jun 13, 2008
Not Rated)
sman99
Rank: Apprentice
Rating: 0%, 0 votes
These setting made no difference in my attempt to connect to the internet via my office wireless router.
Haaarumpf!
Was this helpful?
Yes
No
Popular Solutions for HP iPAQ H5455 Pocket PC
Questions and Unsolved Problems for HP iPAQ H5455 Pocket PC
Do you recommend HP iPAQ H5455 Pocket PC?
Answer
Answer
I´ve a pda hp h5455 that don´t start , i´ve tried to do a hard reset and... (More)
Answer
i can't perform a hard reset on my hp ipaq 5455
Answer
i have hp 510 intel celeron laptop, i am using windows xp. when i am open wi-fi i found some... (More)
Answer
It was working fine but after I removed the fully charged battery to try in another HP5455 (that... (More)
Answer
i recently got this from a friend so i know it worked b4 but the batter charger would not work so i... (More)
Describe your PDAs problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PDA Experts
Top Computer & Laptop Repairmen
in Newport, KY
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
