Question about Hotpoint NVL333EY Electric Dryer
Dryer Heats - Drum Turns - Clothes Don't Dry - Dryer Seems To Over Heat
Dryer is Hotpoint NVL333EYOWW
I suspect the blower isn't functioning properly. Can feel the heat inside dryer, clothes tumble but don't dry. Also, the top of the dryer is very hot to the touch when operating on regular heat. Have any ideas? How do I get to the blower to replace it? Thanks for any info.
  • 3 more comments
  • pcbenny Sep 27, 2008
    MNTECH - Thanks for the quick reply. Checked airflow outside. It is a strong airflow. Checked the flex pipe. It is clear. Other ideas?
    MNTECH, Thanks again for the response. The dryer did work again at least temporarily and the dryer top was not hot to the touch. Don't really know what I did to get it working again on regular heat other than running it on "no heat" for 15 minutes or so and then turning the setting knob clockwise to a regular heat setting. Who knows with the next load. I don't think it had anything to do with the flex vent tho as we did examine it and tried drying with it outstretched. At the time the dryer did not function properly as previously described and the top was extremely hot to the touch. Perhaps the heating coil did sag down. What would be the steps to check this and if found to be sagging what would be the remedy? Thanks for the additional info and advice.
  • pcbenny Sep 28, 2008
    MNTECH, Thanks again for your timely response and the information. May try to tackle and fix this myself or save the headache and buy a new dryer. If I try to fix it, I will advise on the outcome.
  • ancyna Dec 03, 2008
    clothes tumble heating element is lit clothes do not dry no lint on lint screen this is a whirlpool dryer
  • Anonymous Apr 01, 2014
    Hoover 5020D Clothes dryer is not heating up, all other functions are working as normal, it just doesnt get hot.
  • 1,543 Answers
Before ripping into the dryer, with the dryer running, check the vent outside. There should be a rather strong air flow. I'll bet you have little or maybe no air flow. Check behind the dryer to make sure you don't have squished flex duct. If you have flex pipe, try running the dryer for a few minutes with the dryer pulled out into the room to stretch the vent out, and check outside airflow again. Try to eliminate all or as much of the flex stuff as you can, replacing it with aluminum dryer vent pipe. (tape joints with foil duct tape) Clean out remaining dryer vent. (there are special brushes you can buy to clean out vents, but they really only work on ridgid pipe.)
Posted on Sep 27, 2008
  • Carl Schulzetenberg
    Carl Schulzetenberg Sep 27, 2008
    Well, there are three things you need to dry clothes:
    1. Heat
    2. Tumbling
    3. Air flow
    If your air flow outside is strong, your blower is OK. Did you check the air flow outside before you moved the dryer? I've seen many dryer vent pipes slightly offset (2 or 3 inches) from the dryer outlet, connected by flex dryer pipe. The dryer is pushed back and the vent is nearly blocked off. Pull the dryer forward (restoring the opening, and thus full air flow) and dryer works. Also have seen lots of flex vents coiled back and forth behind dryer or kinked off at an elbow.
    Another thing which may have happened is that one of the two heating coils of the heating element may have sagged down and touched the dryer frame. This will cause constant (but usually insufficient) heating while the dryer is running. Without a ohm or amp meter, the only way to really tell this is to look at the actual element. If you want to check that I can list steps. (elements are behind dryer drum)
    Carl Schulzetenberg Sep 28, 2008
    To access heating element:
    1. Use a putty knife to push in at the seem of the top and front panel, two spring clips, to release the top and swing the top back.
    2. Remove one screw on each side near the top of the dryer, which are holding the front panel to the side panels. A phillips will work, but a #2 square drive bit works much better for the screws on this dryer.
    3. The front panel can now be pulled away from the dryer at the top and lifted off the two tabs at the bottom, then swing the entire front panel to the side. No need to disconnect the wires.
    4. Remove the one screw at the top center of the dryer opening holding the plastic tub block.
    5. Release the belt. Easiest way is to take the back access panel off to gain access. It is the louvered panel at the lower left as you face the dryer from behind. (four screws)
    6. There is a ball on the back of the drum in a plastic socket. To remove the drum, lift up about an inch or so on the drum (sort of hard) and then pull the drum out through the front of the dryer. Visually inspect element.
    7. Dryer is actually manufactured by Frigidaire (Electrolux) part # 131776500 is assembly, but if you go to a big parts store you should be able to get just the coil. I use Sundberg here in the midwest. (C.E.Sundberg) http://www.appliance-parts.com/customers... but they will ship anywhere, even international. Might have to call about the individual coil part number. Sorry I don't have that number here with me at home and it does not show on the diagram, but should be available.
Dryer won't dry clothes
Heating element faulty not giving as much heat as it should
Nov 14, 2015 | Dryers
The dryer wont heat up the clothes dont get dry everything eles works on it the drum turns ok the timer works also it just wont dry the clothes
Hello,Sam
The usual reason a dryer will heat yet not dry the clothes is going to be a air flow problem. What ya need to check is for a blocked vent and or lint build up in the blower assambly.
By far though a leading cause of that on Maytag dryers is a broken blower wheel and therefore no warm air is being drawnthrough the clothes,to check that remove the front panel and the front drum support and in the lower left corner will be the blower asm. check to see if it moves free and doesnt seem to be attached to the motor shaft.
GENE
Sep 20, 2011 | Maytag MED5770TQ Electric Commercial Dryer
Blower does not blow on profile dryer GE Profile dryer drum turns heats but does not dry
the clip that holds the fan on the back shaft of the motor may have broken so the fan isn't turning, check that , but first check the duct and make sure that you don't have a ball of lint clogging the vent,, also check the venting all the way out of the house,, clean the overhang of the outside vent cover, they get moist and collect lint
Jun 21, 2011 | GE Profile DPSB620GCWW Gas Dryer
My tumble dryer squeaks really loudly when its going and seems to be taking ages to dry - any idea?
Check the following:
  1. Idler pulley - It keeps tension on the main drive belt and when it is worn, it can be squeaky and noisy. Replace then.
  2. Glides - Attached to the front bulkhead of the clothes drum for support. When worn, it can be noisy and squeaky.. Replace then.
  3. Rollers or wheels - They support the clothes drum. When they are are worn, you should replace the whole set of rollers at the same time.
  4. Blower wheel - It pulls air over the heat source through the clothes drum past the thermostats, then pushes it out the exhaust duct. It may wear out over time. If it is noisy, it may be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you need to replace it.
Oct 27, 2009 | Hotpoint Dryers
My dyer heats and tumbles, but doesn't dry
I'd check first for clogged vent hose or clogged lint filter or clogged vent flap on wall (outside).
If that's not a problem, it may be a faulty thermostat. Heating element is probably okay if it heats some of the time.
More info, let me know.
Charlie
Oct 01, 2009 | Kenmore Dryers
Dryer seems to be operating properly, it heats up, but the clothes aren't getting dry. I noticed the lint collector isn't collecting much lint, is it possibly the blower?
Could be a stripped blower wheel. Remove the front panel. Rotate the blower wheel and look for loose movement on the motor shaft. If that does not work,turn the dryer on with a NO HEAT setting and run it. See if the blower wheel is slipping. If the blower is OK,check the exhaust vent for blockage.
Sep 24, 2009 | Maytag PYE2300AY Electric Dryer
The dryer sometimes heats up to dry the clothes and sometimes it is just cool air. The drum still turns
I had this problem on my Hotpoint dryer and it turned out to be the timer.
Jun 16, 2009 | Hotpoint Dryers
Hotpoint Dryer Heater stays on when door is opened
Strange. Heaters usually shut down with the spinning drum when door is open. If you check the schematic for unit you can check to see if in fact this is correct operation. Attached site usually has schematics for appliances. You might want to check. Search Over 2 1 Million Appliance Parts
Sep 01, 2017 | Hotpoint NVL333EY Electric Dryer
Hot point model nvl333eyoww will ot dry clothes
your dryer has a belt switch go here to see it www.repairclinic.com once there enter your model # and it will show you your parts
Mar 10, 2009 | Hotpoint NVL333EY Electric Dryer
Long time to dry clothes
The dryer has one of its rows of heaters open. Open up the dryer and check the coils behind the drum. read more
Mar 09, 2009 | Hotpoint NVL333EY Electric Dryer
Hotpoint NVL333EY Electric Dryer Logo
559 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
