Question about Bosch Washing Machines
Door wont open and F34 error message on our axxis front loader
  • Anonymous Mar 13, 2014
    axxis front loader keeps beeping when try to start, won't start
  • Bosch Master
  • 19,396 Answers
Unplug the power cord for ten minutes.
Try to advance the cycle, if there is water inside the door wont open until it drains.
If there is water inside:
  1. The water hasn't pumped out properly and the washing machine has a pneumatic door safety lock (a rubber hose connected to the door interlock and connected to a pressure chamber bottle on the tub - water forces air up this tube and locks the door) Washing machine won't empty water
  2. The water has pumped out properly, but a blockage of gunge inside the pressure chamber bottle is trapping the air that's operating the door lock (if a pneumatic lock is fitted - not many have these days due to cost cutting)
  3. Door interlock jammed
  4. Door catch, handle, or mechanism broken
  5. ****** (a device that detects the motion of the drive belt fitted to many older Hotpoint washing machines which "pecks" at the belt when the door handle or button is operated) is broken or has fallen of"
You will need to drain the water inside the machine, if there is no water you will need to force the latch to open.
Posted on Sep 27, 2008
    Genius:
  • 1,550 Answers
This error message indicates that you have a Electrical Problem in your washing machine .
Make an attempt
  • Select PAUSE/CANCEL twice to cancel the cycle.
  • Select RINSE & SPIN, and then select EXTRA
  • RINSE (to turn off the rinse option) if there is
  • excessive water in the washer.
  • Re-select cycle and press START. If the problem
SAM ANDERSON
  • SAM ANDERSON Sep 27, 2008
    If the problem exists call service people to solve your problem .
Samsung wf8750lsw front loader door wont open
Not sure if you mean when it is fully off or operating, but if you mean that once it is operating the door won't open, then the following applies...
Once a front loader wash cycle starts, the door on a front loader is physically (electronically) locked until the full cycle ends after spin dry. This is to prevent anyone opening the door and letting all the water out in the middle of the wash cycle, which a lot of people try to do to put in more clothing etc.
Apr 11, 2014 | Zanussi F1045W Front Load Washer
My electrolux ewf 1087 front loader door wont open
You will need to remove the drum and reset the alignment.
The cloth is struck and has jammed on the drum movement.
click this link: drum removal
Jan 21, 2013 | Electrolux Washing Machines
My Samsung Front Loader (WF410ANW) door lock won't open. I have replaced it 3 times. Every time it lasts about a week and I get the LO error message. I would like to know how to bypass the door lo
You can short the door switch and it will stay activated BUT the DANGER is that it will be available to be opened at any time specially after the water has loaded and if you accidentally open the water and clothes might flow out.
Jul 03, 2012 | Samsung WF410ANW Washer
What does E-13 mean?
Low water pressure.
If this is the error message your washing machine is sending, it may be caused by inadequate water flow. There might be something trapped in the water hose such as sediments or lime deposits. If you are using tap water, this is a common problem.
Remove any sediments or dirt obstructing the flow of water in the hose. Pull the sensor that is located n the inlet valve and check inside to see if anything is trapped.
Dec 07, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Mould inside rubber seal
Bosch Axxis WFL 2060 Front Load Washer mould on door
gasket.
This video will show you how to change a door seal on this Bosch front loader washing machine.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 24, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Water wont drain from my front loader bosch axxis washer and no spin cycle
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
May 05, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 washer leaks
Hi. Check the doorseal by lifting the folded lip which faces toward the drum opening. Use a torch and carefully examine the doorseal. It may have a small hole which is hard to see at first.
If door seal is ok remove top of machine and check inlet valve. Turn power off and with your hand examine the inlet water valve. If it feels damp on the solenoid then it leaks from there and finds its way around to the front of the machine though the frame work. This leak happens due to to much water pressure at your laundry taps. If so install a pressure reducing valve before the water inlet hose and replace the water inlet valve in the machine as it is now faulty.
0417362396 Melbourne metro area
Regards Sam
Mar 08, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Where can we buy a door seal for Bosh Axxis in Toronto? Thanks!
You can get seals on eBay
Feb 17, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
841 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
