Question about Kenwood Audio Players & Recorders
I have a 1987 model kenwood home stereo system ihave a graphic equalizer ge 76 control amplifier kc206 synthesizer tuner kt76 power amp km206 how does the RCA connections hook up which ones go to wich one and where please help.
    President:
  • 624 Answers
First connect all sources like tuner, cassette player, Cd player into the proper RCA inputs of the control amp, then connect the output of the control amp into the input of the equalizer. Then connect the output of the equalizer into the input of the amplifier. This is how to get the best performance and proper outputs to all the right equipment. The speaker outputs of the amplifier would then go to the speakers.
Let me know if you need more help from me by addressing your post to me, or if you wish to communicate with another expert you can address your post to them I.E. @tech48 or @whoever
Thanks and good luck,
Dave
Posted on Sep 27, 2008
  • Dave DeGain
    Dave DeGain Sep 27, 2008
    You did not mention having a tape deck, but in case you do connect a tape deck or other audio recorder like a CD recorder in the future this information would be helpful. The input of the equalizer you should use would be the main input and output, not the tape input or output. The tape input is for using a cassette player that you wish to use for recording tapes and have the ability to adjust the tone of the recording. Most equalizers have only the two inputs and outputs. It is not necessary to use the EQ for recording, you can get the proper level of tones for recording without the EQ's tape loop. If you do use the EQ's tape loop to adjust the tones of recording you can easily end up with too much or too little bass and treble.
I need to see an owners manual for the Kenwood Tuner KT-76. So I can determine if it's working properly.
The maual you need is at this link and it can be downloaded if you want a copy.
http://www.manualscenter.com/manuals/kenwood/kt76-owner-manual.html#.V7smMk1THIU
Mar 15, 2016 | Kenwood Audio Players & Recorders
Where can I get a free manual
go on panasonic website or google the manual you want.i use manuals lib
Jul 02, 2014 | Technics Audio Players & Recorders
I just got a Kenwood system, i would like to know how to hook it up, it has, Kenwood power amplifier km207, kenwood stereo control amplifier kc 207, disc player dp-m 97, cassette deck ky-77 cw, stereo...
That's a pretty standard setup. RCA cables from the KM207 to the preamp (KC207), and RCA cables from all of the other components into the KC207. Speakers connect into the KM207
Nov 01, 2012 | Master DE Kenwood with Housing...
How to wire up kenwood ge-760 graphic to my
First of all connect the source, the tape or the DVD, to the input of the equaliser, use the output to connect to the AUX of the amplifier. make sure that the L&R are not crossed over. In case your amp has an in and out of the preamp section use then connect the source to the amplifiers input specified for the source like tape or DVD or TV and use the preamp output to the equaliser input and the output of the equaliser to the input of the main ampflier. Now the bass and treble of your amp can be set to the mid point - 12 noon position and use the boost or attenuation according to your choice of music. hope you find my advice helpful. Good day
Jul 04, 2010 | Kenwood Audio Players & Recorders
I HAVE A OLDER KENWOOD STACK HOME STEREO SYSTEM WITH OUT MANUALS OR REMOTES AND NEED TO KNOW HOW TO HOOK ALL THE COMPONENTS TOGETHER. KC-206 STEREO CONTROL AMP KT-76 TUNER KX-96W CASSETTE DECK KM-106...
start with the tuner, hook up the equalizer to the tuner, then on the rear of the equilizer hook up all the peripherals except the amps which will go to the tuner outputs and all will feed thru the tuner to the amps and out to the speakers
Oct 23, 2009 | Audio Players & Recorders
Kenwood stereo synthesizer tuner t-85l
T-85L is a component of a hifi system not suposed to work alone. You have to connect it to another Kenwood component (an amplifier like the A85 ) through a special cable to power it on/off. The special cable can be used point to point or as daisy-chained.
Nov 05, 2008 | Yamaha HTR-5830 Receiver
Kenwood installation manual help?
Click HERE for Kenwood support and manuals.
May 15, 2008 | Kenwood Audio Players & Recorders
Kenwood stereo intergrated amplifier a-76
The only tricks to power up again are this:
Amp to Equalizer : Use the "Connector " of the Amplifier - IN and OUT and connect them to the Line IN and Line Out of the equalizer;
All modules: Use the system control cable like in serie, for example the lowest connects to the above and from thsi one to the other above and so on;
Regarding Power: both CD, Deck and Tunner have different colors to connect to the Amplifier power source, you can't miss it;
Audio Cables, just follow the IN and OUT with correct colors and you are done!
Rgds,
TrepaTrepa
Feb 21, 2008 | Audio Players & Recorders
241 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
