Question about Whirlpool Washing Machines
I need a new agitator for my whirlpool auto washing machine the inner parts have worn and wont turn the top of the agitator when washing
  • llacey Sep 27, 2008
    the model numder is :6ALSQ8000JQ1
  • llacey Oct 02, 2008
    thanks it was most helpful, the only problem is im in Oz and the online store is in America. i know now what the part number is so i will search locally i.e in Australia.lol thanks again.
You need a agitator dog clutch kit
ring whirlpool customer line and find out your nearest service agent
then pop in to their workshop and ask for the kit, they maybe have to order it...
they shold be able to order what you want if they are a half decent agent
the company i work for in nsw would do that anyway.
good luck
Posted on Oct 24, 2008
  • 5,911 Answers
You may not need an entire agitator. The small internal components that help drive the agitator do wear out and can easily be replaced. More commonly, the agitator dogs are the cause of an agitator not spinning properly. Yes, there is such a thing. The following link explains how to replace them:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
If you go to searspartsdirect.com and type your model number as "LSQ8000JQ1", you can find an excellent exploded view drawing of the agitator and internal components under the "Agitator, Basket and Tub" heading. The agitator dogs are listed as item number 10. I would recommend ordering them as item number 9 which includes ALL the internal cam drive components for the upper portion of the agitator. I would also recommend you order item 22 which a space thruster for the bottom portion of the agitator. This also wears out and can cause slipping. The total cost is about $17 and a little elbow grease. If you still wish to order the whole agitator assembly, order it as item number 20. This includes ALL the parts. The cost is about $43. The choice is yours. The cost of the repair is still rather inexpensive either way.
I hope you find this information helpful. If you require additional assistance please post back and let me know.
PS The agitators on some of these older models frequently stick. Namely, the lower flange portion. It may take some effort to get it to come of the center post. One recommendation that I know of that can make this easier, is to take an old dryer belt or fan belt, fold it in half so you have two loops. Take each loop and place it under the flange of the agitator on either side. Using the folded part of the belt as a handle, pull straight up.
Posted on Sep 27, 2008
  • Jeff Rockwell
    Jeff Rockwell Oct 02, 2008
    Sorry about that. Your location was left as "unspecified". Yoiu still may be able to order online, however. The web site lists a toll free number you can call to confirm if they will ship internationally. Just a thought...anyway glad I could be of assistance. Good luck with your parts search.
    Genius:
  • 1,028 Answers
Try replacing the agitator dogs first part#80040 from whirlpool cheaper than new agitator approx $6 versus 40-50..remove agitator cap or may be dispenser first under cap will be 7/16 bolt or a 3/8 square drive socket..take it out remove top part may need to give it a good tug to pull loose from bottom section dogs are in cam assembly
We have a Whirlpool LA5800XT where the upper portion of the agitator does does spin. How can this be fixed?
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
Oct 10, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator not working properly
that's an easy fix... the agitator will need to be removed... usually only involving one screw in the top of it... the parts you need are called dog agits... they come in a package of 4... once you get the agitator apart you'll see where they go... shouldn't be a problem for ya... if you have any questions about it just holler at me
Feb 14, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Howbdo you remove the inner basket from the tube of a whirlpool cabrio wtw6400sw washer? I think my agitator is stuck or does not disangage and might have somthing stuck on the shaft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 09, 2009 | Washing Machines
Need help replacing the Agitator/Mover
Apr 30, 2009 | Washing Machines
My new Kenmore 400 top load washing machine terribly noisy.
Mar 27, 2009 | Kenmore 22422 Top Load Washer
Mod 20922 top load washer will not agitate or spin.
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
Feb 21, 2009 | Kenmore 15944 Top Load Washer
Washer clicking and not spinning
Feb 15, 2009 | Kenmore 24032\24036 Top Load Washer
Washer wont spin
Feb 14, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Top agitator on model 110.27812690 washer slipping
Jan 17, 2009 | Kenmore 22932 Top Load Washer
Washing machine agitates one way only
Jan 03, 2009 | Washing Machines
Washing Machines Logo
161 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
