Keyboard will not work. Have tried 3 different ones and it will only work in BIOS. Once I get the computer booted up it will not work. I need to use it to log on to the computer.
  • icstorm Oct 01, 2008
    1st USB Keyboard 2nd PS2 and 3rd brand new USB
  • 68 Answers
Icstorm,
Is this a USB keyboard?
On several occasions I have had the same problem.
I have resolved by temporarily plugging in a PS2 Keyboard to log me in and once i have done so the usb keyboard will work fine and I can remove the PS2 Keyboard.
Regards
ElApe
Posted on Sep 27, 2008
  • Nick Sharp Sep 27, 2008
    acdr,
    its unlikely to be a problem with incorrectly connecting the keyboard to the wrong port as icstorm said the keyboard works in the bios
    ElApe
    Genius:
  • 1,913 Answers
Check your mouse and keybord pin
also check slot on computer to which u connect keybord and mouse.
How can I change boot sequence in Compaq Evo N410c?
You need to access your BIOS configuration. 1. To do this, shutdown your computer and boot it by pressing the power button. 2. You need to hit F10 when the computer first powers up in order to get into BIOS (Note that the key is usually different for different computers. If F10 doesnt work, try F2, F12, Delete or F9. 3. Once in the BIOS, you should find the boot sequence option.
Hope this helps!
Apr 11, 2011 | Compaq Evo N410C Notebook
Screen is black and only shows cursor blinking in upper left hand corner. Keyboard not responding. Changed the keyboard 3 times.
Start the computer up and repeadetly keep pressing DELETE to access BIOS menu, Once BIOS menu is aquired make sure that BIOS can see your main harddrive, If that checks out then you may need to set your booting device order to boot the harddrive that contains your Operating System. If that still does not work then you may have a bad motherboard.
Jan 04, 2011 | Dell Computers & Internet
Well I'm having a little problem. Each time I try to boot my computer I want to open safe mode, but I can't because the keyboard doesn't function during the boot process. How do I make the keyboard work...
If it is a USB keyboard then you might need to either activate the USB keyboard support in the BIOS by using a different keyboard that plugs into the keyboard port so you can get into the BIOS or buy an adapter that turns the USB connector on your keyboard into a keyboard port connector.
Nov 26, 2009 | Cell Phones
When I enter BIOS on one computer, no keyboard. The other computer is OK Otherwise both computers work fine in all modes. Only when in BIOS on computer number one.
Hello there:
first try this boot the computer and go to device manager uninstall the keyboard and than click on view and than click on scan for changes and see if the computer will recognize the keyboard and reinstall the driver for the device and if this doesn't work.. boot back into bios and check the settings for plug and play and make sure that this is enabled and if this is a usb type keyboard make sure that the usb setting is enabled than save and reboot you can also use computer #2 to check the settings against computer #1 to find out if you have any thing set differently ok?
please try these ideas and see if they work
best regards mike
Jul 31, 2009 | GWC (KS-102) (ks102) 2-port KVM Switch
No boot no keyboard or mouse
First disconnect all external connections except video, see if system will boot normally (press the power button once on tower to shutdown)
If that works, then connect the keyboard only to the back USB port nearest the NIC. See if the keyboard works. If it does, shutdown and connect the mouse and try again. If it doesn't, try the mouse only. If you localize the problem to either the mouse or keyboard, replace that item.
If neither works, then reset the motherboard junper to reset BIOS defaults. the again, try them one at a time. If they still do not work, then you will need a mothebroard.
Apr 18, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
How to go to the BIOD set up
1. Restart your computer and while its powering up , keep pressing DELETE Key on the keyboard, this will take you to the BIOS screen.
2. Go to Advanced Setup, find the DMI logs option. This option may be located under different menus under different types of BIOS interfaces.
3. Once you locate the option, Select the option to Clear the DMI logs and also disable DMI logging if you don’t need it.
4. Save changes and exit from BIOS. Restart you computer.
Mar 12, 2009 | Microsoft Windows XP Professional
MotherBoard Problem (BIOS)
im not positive this will work for you but in my bios there is a setting for USB keyboard and USB mouse and at one point I had to enable both of those to use my keyboard and mouse during the windows formatting process. Try to find settings like that for USB keyboard and enable them in your bios. If that doesn't work then you will have to use a different keyboard or get a usb to ps/2 converter. you might want to try unplugging your keyboard and then booting and see if it still goes straight into bios. If it doesn't then your keyboard is sending signals without you pressing the keys and that is obviously the issue.
Dec 19, 2008 | ASUS P4S533-MX Motherboard
On boot with battery or on power same result. The computer boots to window sign on screen but mouse and keyboard do not work. On reboot tried F2 for setup screen which does work but then once at setup...
i would have told you to go into the bios but seen as you say that F2 key does not work on boot indicates that the keyboard has failed, to check this try another keyboard and see if you get the same result, or if the keyboard is USB try it in a different USB port
hope this helps
kind regards
Nov 18, 2008 | Acer Computers & Internet
Monitor shut off, no BIOS post, no keyboard or mouse lights, will not boot
Try another (Known good monitor). Or try you're monitor on another system.
Remove all memory except 1 DIMM. Double check all data cables (internally) & power cables. Remove the added video card. Try booting the system. Watch for the case LEDs to flash/blink, listen for hard drive spin up /cd-rom spin up. Lastly pull the battery & check with a volt meter. Bios battery should test no less than 3 volts. Post the correct MD rev.
Mike
Jul 22, 2008 | Intel Motherboard
Keyboard not detected
There are some steps to figure out what is causing this.
If you have a desktop:
1. Replace with another keyboard that you know works.
If it boots, than it is the keyboard that was bad
2. If it doesn't - try getting into bios. There is a secion for
keyboard and make sure it is enabled.
3. If it is enabled, than it would be the port for the keyboard that
is the problem. You can take the computer apart an replace
it, or take it to someone who can fix.
If you have a laptop:
1. Add a keyboard to the computer.
2. If it boots, than it is the keyboard on the laptop. This could
mean it is not connected, you have the wrong drivers, or
try getting into BIOS like #2 above.
3. If the keyboard is enabled in the BIOS, reinstall drivers
first. If this doesn't work than there is something wrong with
keyboard (follow #3 above).
(BIOS - when computer boots up, look closely. There is a button you must press to get into setup mode (BIOS). I press F2 on my computer to enter BIOS. Some computers are different).
Nov 09, 2007 | Logitech S 510 (967555) (DH967555)...
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
