Question about Canon imageCLASS D760 All-In-One Laser Printer
Cannon Printer Not working screen says check doc. Open the ADF???? What do I DO! BC
  • Canon Master
  • 4,338 Answers
The ADF is the Automatic Document feeder through which you feed the paper in on top of the printer. Usually the cover swivle/opens up, and you can check if there is paper debris in the rollers. Clean the rollers with cotton pad and some alcohol.
Posted on Sep 27, 2008
Bizhub 211 - doc cover open
Something is open. Check and make sure you closed everything securely.
May 30, 2012 | Office Equipment & Supplies
Doc feeder jam error on HP laserjet M1522nf continuesly also due to that i am unable to scan and also its showing that "Device is busy try again later"
Open adf cover, remove adf pick up unit, two sensor located in it 1. paper leading edge sensor, located upper portion of the unit.2. paper out sensor located back side of the adf pick up unit. Carefully open this unit your will easily find out the sensor location..
Sep 13, 2011 | HP LaserJet M1522nf Multifunction Printer...
Brother MFC-8860DN All-In-One Laser Printer showing document jam error
Doc jam error usually means a jam in the adf (auto doc feed) when feeding a fax or doc to copy.
The most common reason brother mfc,s of this configuration have doc feed issues is believe it or not the hinge that operates the lid/adf, specifically the left side one (looking from the front). Inside the hinge there are two springs exerting tremendous force on the hinge (that enables the lid to stay up by itself) however this force eventually slowly breaks the fulcrum point of the hinge which leads to the lid not closing properly which means a sensor under the lid does not activate properly resulting in the adf stopping and resulting in the machine registering a jam. the difference between the sensor activating or not can be as little as a millimeter and is not often disernable. the hinge needs replacing by a techo.
the other reason could be you just have dirty adf feed rollers, clean them with a cotton rag dipped in metho, open the adf lid and give the rollers a scrub. the rollers should have 'tread' on them similar to a tyre, if not they are worn and need replacing.
One other possibility is there may be a paper fragment left over from a jam removal still caught in the paper path and activating a sensor activator that tells the machine paper is coming or going. most commonly in the section where the paper is looping on its return journey back out of the adf, open the adf lid, have a look with a torch and see how you go.
Regards, Andrew.
Dec 04, 2010 | Brother MFC-8860DN All-In-One Laser...
Canon MX330 - trying to use ADF. No doc inside on
Canon Pixma MX330, ADF error, Code : 2,103,0
Here's what I found. There were no stuck gears or pieces of plastic caught anywhere.
The ****** can still feed paper, except for (consistently) the last page -->error/stuck.
1) In order to CLEAR THE ERROR you need to do two things
a) & b):
a) Press OK, WITH THE HOOD OPEN, with a piece of paper loaded in the ADF, being careful to grab the paper manually as it comes out of the bottom of the hood.
b) Windex the strip of glass surface which sits under the ADF next to the platen. This needs to be done with attention to minute detail, and a bright LED flashlight; since ink smudges off of documents and collects on the glass with alarming frequency. The machine may think these smudges are caught/jammed paper.
2) In order to SCAN a stack of paper, add one blank sheet to the bottom of your document. This page will be the one that
fails to clear the ADF, generates an error, and must be manually cleared before the next job.
The rest of your pages will have already scanned.
Repeat Every Time You Use it
Sep 11, 2009 | Canon PIXMA MX310 All-In-One Printer
Brother 8840D ADF not working. The flat bed scanner runs instead for fax or copy. Displays Doc Cover Open message
Open ADF and close again. There must be tab in the ADF which is not pressing a microswitch located in the lower part of the ADF. IF you can locate it, try pressing it manually.
Jun 06, 2009 | Brother MFC-8840D All-In-One Laser Printer
Doc. feeder jam, after paper removed completely
HP LaserJet 3030 All-In-One Printer
Mar 11, 2009 | HP LaserJet 3030 All-In-One Printer
The copier keeps saying to put doc. feeder down and i it is. I ha
When you lift/ open the ADF you should see a tab in the back corner (slightly in from the corner) of the ADF. This tab is for the machine to see that the ADF is closed. Make sure tab is there. On its sister model they used a depression switch, check that and make sure it is there and working properly.
Jan 05, 2009 | Toshiba 2060 Copier
Check document Open the ADF
would be a good idea to check the ADF.
the ADF if the top part of your copier, where you put the originals to be taken one by one and then copied. if it tells you to check it you must open it and check there are no paper stuck inside. and then close it back.
Sep 27, 2008 | Office Equipment & Supplies
Doc feeder problem with adf unit
first check the copy wheather it is working it or not after that if it is working then try to fax and also check the phone line
May 09, 2008 | HP LaserJet 3380 All-In-One Printer
ADF can't print
maybe your ink is already empty... try to change ur ink cartridge... but first try to check out your printer settings at your computer... there might be problems there that's why it won't work...
Feb 24, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon imageCLASS D760 All-In-One Laser Printer Logo
166 people viewed this question
old marine
old marine
