Question about Foxconn P4M800P7MA-RS2 Motherboard
MEMORY UPGRADE FROM DDR 256Mb to DDR2 1GB hangs when Log on/Booting
Ck..ck..ck
Thanks before to FixYa
I have a problem with RAM MEMORY exactly DDR/DDR2
my motherboard is Foxconn P4M800P7MA-RS2 you know ya..
PROBLEM :
- i have installed 2 DDR 256Mb 400Mhz and the computer works normally every day
- and after i upgrade the memory to DDR2 1 GB (APACER 1GB UNB PC2-5300) the computer hangs/bluescreen every logon or booting...computer say :
STOP C0000221 Unknwon Hard Error
\SystemRoot\System32\ntdll.dll
after that computer restart suddenly
-any can help my problem ????
THANKKKKKKSS A LOTS for anyone give me resolve..
sorry for my bad english
..btw im Sumatranean Human
aswzen@bk.ru
thanks2
  • Zenislev Sep 28, 2008
    Thanks...before
    im trying..
  • jrxco Dec 30, 2008
    what type of memeory that match each other
What are the compatible memory and boards
Posted on Dec 30, 2008
  • 67 Answers
Its a memory problem obviously. Try dusting the memory slot and try inserting the memory into the slot a couple of times. If still not working, the memory may be incompatible(rarely, there are brands of boards that doesn't suit to certain brands of memory), or it may be damaged.
Posted on Sep 27, 2008
My mainboard A300M-E1394 freezes when I install more than 256MB of RAM, I am runing win Xp , it recognises the RAM in the BIOS but about half way into booting up it freezes tht is hang : from the spe
Try using one of those sited that specialize in RAM, like Memorystore dot com. You easily find correct memory to compare, or even a small diagnosis tool.
Jan 11, 2013 | Computers & Internet
I got intel 845 gl motherboard having ddr 256mb pc3200 ram. there are two slots availble. i want to upgrade
If you want to upgrade your ram, buy the same memory frequency like your current ddr 256 mb pc3200 memory. You can upgrade your memory up to 4GB and be sure they have all the same frequency to avoid system complications.
Dec 19, 2009 | Intel Motherboard
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
Longer Boot time after upgrading the Hard drive
first let's determine if the upgrade cause the boot speed.
Disconnect your NEW HDD and/or memory, one by one and see if you get back your fast boot. Then try with your NEW components only !
If you find it works better with new components only, then first connect your OLD HDD only and try.
If you connect both HDDs on one cable, check Jumper settings for both HDDs (Master/Slave).
Also HDD capacity and type is automatically detected by the BIOS and there is no need to put/change those settings manually.
I believe you new RAM is DDR type, too!
As written in the manual for the board, your motherboard has two pairs of memory slots, and you can use one or two modules of DDR memory, OR one or two modules of SDRAM memory, but you can NOT put BOTH DDR and SDRAM memory modules.
regards.
Apr 22, 2009 | Computers & Internet
PC Motherboard Memory upgrade
From Asus tech: Memory 3 184-pin DIMM slots for PC1600/PC2100 DDR SDRAM
Supports up to 2GB memory
No ECC supportThis is only compatible RAM so make sure your new chip is PC1600 or PC2100. If you mis the 2 it the faster RAM will run at the slower chip speed. Hope this helps.
Feb 20, 2009 | ASUS P4B266 Motherboard
Ram upgrade
Its support "DDR SDRAM"
Max Supported Ram is "1GB"/"1024 MB".
Ram Speed: 266 Mhz..
Good luck...
regards,
Dec 04, 2008 | Toshiba Satellite A65-S1068 Notebook
Upgrade ram
Each memory slot can hold DDR PC2700 with a maximum of 512MB per slot. 2 slots=1 gig or 1024MB ram.
May 22, 2008 | Compaq Presario M2000 Notebook
Please help me in my RAM
If your PC boots up successfully and load windows then its mean that RAM is working fine... There is some problem with OS settings.. So at XP booting press F8 for start-up menu and select Last known good configuration... Hope it will work...
Please Rate .... Thanks.
May 14, 2008 | Intel Motherboard
Memory upgrade problems
Hmm if the pc takes DDR Ram , it should deffently take 512 sticks, have u tried booting the computer with just the one 512 stick ? or try putting the 256 stick in and 1 x 512 stick , test it that way with both sticks , some older computers there is a bios setting for upgrading to higher amount of memory, but in your case with DDR ram i dont think so , i mean it may be worth a shot going into bio's and load optimized defaults , press f10 to save settings, try one stick at a time after that , if still no go , there is a jumper pin on the mother board that u can move over a slot which will restet the bios, if u dont know this jumper pin or where it is, just remove the round battery on the motherboard for 30 seconds , then put it back in , try your new ram then , u will be asked to save settings on boot up , if it still dosent work the ram is either faulty or incompatible, alot of the time with Dell , HP /Compaq desktops there fussy with the type of ram they take, but if u ordered from dell it should have worked !! whats the brand name of the ram u have is it hynix? /HP this brand of ram has alot of issues with compatibility,
Nov 21, 2007 | Dell Dimension 2350 PC Desktop
Memory Upgrade
First, this is what I would do before buying more RAM. Turn off two terminals, take the memory from one to add to the other (no new chips please). I'll assume each machine has 128MB right now and I'll assume there are only two memory slots. If it boots up fine with 256MB, then I'd try to match the RAM exactly. Probably using PC1600 with/without a SPD module chip. Use CPU-Z to find out the memory details. http://www.cpuid.com/cpuz.php ZT3000 Beta tester of "0"s and "1"s
Aug 23, 2007 | Casio QT-8000 Network Terminal
Foxconn P4M800P7MA-RS2 Motherboard Logo
248 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
