Question about NEC Computers & Internet
Computer runs for awhile then shuts down could it be the fan inside the computer
  • Nick Sharp May 11, 2010
    Sleepiejyes,
    Possibly, try installing http://www.almico.com/sfdownload.php and see what temperature readings you get.
    If you could also let me know whcih CPU you have and at what speed it is running it would also be helpful.
    Regards
    ElApe
    Scholar:
  • 191 Answers
Possibly it may be due to virus that is infected to your system.
try installing new antivirus (Avast,Norton) and scan your system.
Posted on Sep 27, 2008
The fan on ford escort van 51 plate continually runs even when the ignition off
Sounds like either a temp. sensor, or a timer malfunction. There are heat sensors that make the fan run after you shut it down, until it's cooler, usually doesn't run long. You didn't mention if it continually runs, or if it shuts down after awhile. Other than taking it to a shop, check your fuses, wires connecting the fan under the hood, look for any frayed wires and/or loose clips. Good Luck. Grimm
Apr 11, 2015 | Ford Escort Cars & Trucks
My acer all in one z5600 runs for awhile and then shuts down very annoying!!!
Start by cleaning the fan or fans, heatsink, and vents, you may have to open the computer. When you open, you may as well replace the Thermal Paste on the CPU and Graphics Chips. Overheating will cause shut downs, heat sensors set to detect a set temp. will shut down to protect vital components from heat related damage. ALSO, Open Control Panel, Power Options, set to High Performance, open Change plan settings, under Plugged In, set both to Never, open Advanced Power settings, go through thr Advanced settings set Sleep and Hibernate to Never, Adjust to your preference. It's a good idea to Always shut down your computer when not in use, it will last longer and a reboot everyday will reset the machine. Make sure ALL your Windows and Acer Updates are current.
Feb 15, 2013 | Acer Z5600 All-in-one 23" 4gb 2.8ghz 500gb...
When I plug the unit into power, the CPU fan runs very fast but no boot, and then when I press power on the fan slows down and the PC boots normally. It shuts down in about 30 minutes with no sign of...
Sounds like you are overheating. One way to tell if it's overheating is you say it will run for about 30 minutes then shuts down. When it shuts down try rebooting to see if the boots successfully. If it fails to boot successfully right after it shut down then you are probably overheating. If you wait awhile to let it cool down for 30 minutes or so and if you reboot and it does it successfully you definitely have a overheating problem. If I remember correctly all those compaq sr series have loud and fast running fans. Computers overheat because of three reasons for the most part: 1) A fan has stopped working. 2) The Thermal Paste on the CPU and Heat Sink has dried up or is not thick enough to keep the unit cool. 3) Dust has clogged the fan vents and inside the computer. Fortunately for you desktops don't have to be completely disassembled like laptops to get to the fan, CPU and heatsink. Just pop the case and you'll see the components attached to the motherboard
Mar 18, 2012 | HEWLETT-PACKARD Compaq Presario SR5518F...
Fan continues to run after the burners kick off. Fan should run for awhile then shut off, but mine is running all the time
Auto matic fan control AFC is not shutting down , you can roemove this and clean the back of it . It could be blocked with dust , or it may need replacing.
Mar 10, 2012 | Heating & Cooling
Boots up fine runs for awhile then shuts down for no apparant reason.
Most times if computer runs and then shuts down it is mother board over heating. It shuts down to prevent damage. Try to clean you mother board fan and also make sure no dust in the exhaust part on the bottom of the computer. You can clean it with air can for computers just make sure you hold it upright because if it is sideways or upside down it will put out freezing air and it can damage you computer. Hope this helps.
Jan 13, 2010 | HP Pavilion ze5270 PC Notebook
If the weather outside is cold and you are running the heatpump/aircondition. Is the fan motor on the outside suppose to stop running. I notice the there is heat coming from the unit after it as been...
yes the fan will shut down during the defrost cycle. But the fan only shuts down during this cycle....other than defrost the outdoor fan motor should be running during a call for heat.
Jan 07, 2010 | Amana Heating & Cooling
Fan motor runs for awhile and then runs hot and shuts off
Bearings in the motor may need oiling. look for a tiny funnel hole on a tube on the ends to oil it. Remove power first.
If none it could be permanently sealed and need to replace the motor.
Let it cool before touching anything. again remove power first.
Jul 06, 2009 | Heating & Cooling
Computer runs too hot then shuts down
remove your fan and install new one ,your hit sneak is not working properly ................ok
Apr 03, 2009 | Acer Aspire One PC Notebook
Keeps shutting down 5150inspiron
thermal shutdown.... it's overheating and you need to make sure the fan is working and clean out the dust and dirt
Robert
Jan 19, 2009 | Dell Inspiron 5150 Notebook
Computers & Internet Logo
29 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
