Question about Kenmore 15516 Mechanical Sewing Machine
Kenmore 15516 bobbin
I need help please to thred the bobbin. Thanks! no instructions!
  • Anonymous Mar 27, 2014
    will not wind
    New Friend:
  • 46 Answers
1. Remove the bobbin case
2. Release the clutch by pulling out the handwheel
3. Draw the thread from the spool andguide the thread throught the hole in the bobbin from the inside to the outside
4. Put the bobbin on the bobbin spindle
5. Push the bobbin to the right
6. Hold the free end of the thread and depress the foot control, wind until full
7. Push the handwheel in (to wngage the clutch)
8. Push the bobbin spindle back tot he left to resume sewing mode.
9. Place the bobbin in the bobbin case (thread should feed clockwise)
10. Draw the thread through the slot in the bobbin case
11. Continue to draw the thread under the tension spring and through the opening Pull out about 4"' of thread
12. Holding the latch open position the bobbin case into the shuttle and release the latch
13. Case should lock into place when released
Hope this helps!
Bonnie
Posted on Nov 06, 2008
I am not able thred the thred from the bobbin. The thred got jammed up when I was sewing, and I removed the bobbin and now I can't get the thred back in.
What is blocking the hook and shuttle? I am not too sure what you are asking, where are you trying to put the thread? Please, be more clear.
Nov 20, 2010 | Brother CS-6000
Why is my machine skipping stitches
this is caused by uneven winding of the bobbin, sometimes the spool of thread winds unevenly when it travels up and down the spool. the best solution i have found is to use small spools of thread when winding the bobbins
Dec 02, 2009 | Kenmore 15516 Mechanical Sewing Machine
No bobbin tension
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on toip and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension)
Mar 18, 2009 | Kenmore 15516 Mechanical Sewing Machine
I need a bobbin case and bobbins for a kenmore 385.1292890
I bought my bobbins for this machine at Walmart. They are clear in color.
Mar 05, 2009 | Kenmore 15516 Mechanical Sewing Machine
Bobbin winder does not work on Model 17651
Make sure that the hand wheel is engaged by pushing it in. To disengage, pull it out.
Feb 03, 2009 | Kenmore 15516 Mechanical Sewing Machine
Needle thread tangling around bobbin
There should be a screw on the side of the bobbin also a screw on the bobbin holder so that you can ajust so you can time the mechin
Sep 14, 2008 | Kenmore 15516 Mechanical Sewing Machine
Problem with my machine
If you're not picking up a bobbin thread, it's either a timing issue, or the hook/needle clearance. Usually, with the hook/needle clearance the skipping stitch problem will be intermittent. If it's a timing issue, it may not pick up the bobbin at all.
Sep 08, 2008 | Kenmore 15516 Mechanical Sewing Machine
Problem of pulling the thread up from the bobbin place
I will be happy to resolve a tension issue with this machine but I need more information. I'm not sur ewhat you mean "hold the bobbin thread up well"
Manual can be ordered at www.sears.com or google kenmore owner's manuals and there are sites that you can download. I don't of any free ones though.
Bonnie
Aug 26, 2008 | Kenmore 15516 Mechanical Sewing Machine
Threading the Bobbin
Place the bobbin in the bobbin case making sure the thread feeds clockwise. Draw the thread through the slot on the case. Continue to draw under the tension spring and through the opening pulling out about 6" of thread. Hold the latch open, position the bobbin case into the suttle and release the latch. THe case should lock into place when the latch is relaeased.
With the top thread, hold out about 5" to the left. While holding on tot he top thread, turn the hand wheel toward you and you should see a loop at the feed dogs. grab the two thread and bring them behind the presser foot.
Bonnie
Dec 12, 2007 | Kenmore 15516 Mechanical Sewing Machine
Kenmore 15516 Mechanical Sewing Machine Logo
244 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
