Question about HP Officejet Pro L7780 All-In-One InkJet Printer
HP LASERJET 3055 Manual IP Address not saving
We have three HP LaserJet 3055 all in one printer which we thought as good all in one printer. However, recently one of system failed to accept Network Printing and when I have checked I found that the Manual IP address given to the printer lost. The printer control panel shows IP address as 000.000.000.000
I tried several time to set the IP address 192.168.1.11 and even printer menu shows "setting saved" but within next minute if I check the IP, it shows the same 000.000.000.000 IP address.
(Menu > Network Configuration > TCP/IP > IP = 192.168.1.11 > Yes > Settings Saved)
The Report for Network Configuration shows Following two important symptoms:
A) Status = Initializing
and
B) IP address = Configuring
Show to HP engineer, they told that main board is required to be replaced and the cost they told was almost 40% of the new HP 3055.
Now the same problem observed with the second HP 3055 and again same symptoms. It does not save IP address even the control panel confirms "Settings Saved"
Any idea, is it related to any firm ware problem or actually a printer's main board problem ?
Thanks in advance.
Tried to enter a Manual IP Address multiple times. Press OK and when I got back into the settings it isn't saved. The printer was working fine before it was moved and was set to a Manual IP then
  • sanjay_ran Apr 14, 2009
    how can cheng a ip address a network hp legarjet printar
Try flashing the firmware: one of the fixes is this - (Improved IP address management of DHCP to Manual changes).  See link below. Firmware
Gerben People tend to evaluate events in light of their paradigm rather than evaluate their paradigm in light of events.
Posted on Oct 07, 2008
3 Suggested Answers
  • 61 Answers
SOURCE: HP LaserJet 3055 unable to save IP setting
i can solved this problem please give me one chance
Posted on Jul 24, 2008
checkitright
  • 1362 Answers
SOURCE: HP LASERJET 3055 Manual IP Address not saving
Try doing a cold reset first, then check that DHCP is manual not Auto. then try to input IP address again. If the Network card is seperate then you may only have to replace the Nic
Posted on Jul 16, 2008
HOW TO CONFIGURE LASERJET 3055
USB: Run the cd, when its asked for connecting connect the usb cable, do rest..Network. Menu>network setup>TCP/IP>enter IP address>save it.connect network patch cable, take configuration page through printer menu settings, verify the IP address save or not> go to system 1. Run the CD select network as network printer> system will detect the printer go for rest of the process..
2. Through system> start> settings>printers& faxes>add printer wizard > select as local printer> select create new port in dialog box> select TCP/IP> type configured IPadress> do rest of the run process..
Jul 11, 2012 | HP LaserJet 3055 All-In-One Printer
The HP 3055 network printer, connected to 3 dell inspiron laptops doesn't print...it says it's offline, even though the screen on the printer says "ready." I tried adding a printer profile and...
Check the IP of the printer, it should be manually assigned, if you are not confirmed,
  1. Press menu/enter .
  2. Use the or the > button to select Reports , and then press menu/enter .
  3. Use the or the > button to select Config report , and then pressmenu/enter .
  4. The printer exits the menu settings and prints the report.
Try re installing the printer software from the cd, or download the full version from the links below for your area
HP LaserJet 3050/3052/3055/3390/3392 Asia Pacific Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 Eastern Europe Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 North America/Western Europe Full Software Solution
(The full software solution provides print, fax and scan functionality. This software solution is the same solution as the Version 4.0 in-box CD that came with your HP LaserJet 3050/3052/3055/3390/3392.)
You can download Printer manual from the link below
Printer Manual
If you require more assistance in this regard feel free to reply to this post
Best regards-BA
Jan 20, 2011 | HP LaserJet 3055 All-In-One Printer
Hello, I have a LaserJet 3055 that cannot retain a static IP address. I am able to change the IP to what I want, but still ,it does not connect. Anytime I shut the printer off it losses its IP, the...
Hey!
Make sure that the printer's DHCP is not on because the only time it looses the ip address is when its not on static and on DHCP!
Hope it helps!
Jan 10, 2011 | HP LaserJet 3055 All-In-One Printer
Ip not save in hp lj 3055 aio
Please describe the problem in detail. IP is never saved in any printer.
Dec 22, 2010 | HP LaserJet 3055 All-In-One Printer
Hp 3055 all in one ip address is not saving
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00495173/c00495173.pdf.....Check this link, this is the user manual of HO3055 all in one printer..
Nov 10, 2010 | HP LaserJet 3055 All-In-One Printer
Switch off the printer and press * & enter key together &switch on wait till you see " permanent storage int"
then release button your printer comes back to original defaults
then re-configure printer as you require
Murali,
PALLAVI INFOTECH
BANGALORE
Jul 16, 2008 | HP LaserJet 3055 All-In-One Printer
Jul 05, 2008 | HP LaserJet 3055 All-In-One Printer
How to install Hp laserjet 3055
If the connection is ethernet. Print configuration from Printer.
Manually install printer.
Select computer is on local port
Local port to select is TCP/IP
then type in the network address to the printer.
Driver will still be inside computer.
Mar 03, 2008 | HP LaserJet 3055 All-In-One Printer
HP laserJet 3055 network connection
HOW TO CONNECT HP 3055 TO ROUTER/WIRELESS NETWORK. WINDOWS XP/WINDOWS VISTA.
I have just finished successfully connecting my HP 3055 to my router and using it over wireless on 2 computers, one with windows XP SP2 and one with VISTA.
INSTRUCTIONS FOR CONNECTING HP 3055 ON XP:
FIRST CONNECT THE PRINTER TO THE ROUTER WITH A ETHERNET CABLE. FIND OUT THE IP ADDRESS OF YOUR PRINTER. By me it was 192.168.0.66
Go to CONTROL PANEL and open "PRINTERS AND FAXES". on the top left choose "ADD A PRINTER" click "NEXT".
In the "LOCAL OR NETWORK PRINTER" window, choose "LOCAL PRINTER ATTACHED TO THIS COMPUTER" and uncheck "AUTOMATICALLY DETECT"... click "NEXT".
In the "SELECT A PRINTER PORT" window click the radio button "CREATE A NEW PORT", click the down arrow and choose "STANDARD TCP/IP PORT".
In the window that pops up click "NEXT"
In the ADD PORT window, where it says "PRINTER NAME OR IP ADDRESS, type in your printers IP address, by me it was 192.168.0.66. The bottom line will fill in automatically. Click "NEXT".
In the "INSTALL PRINTER SOFTWARE" window, if you have the disk just choose "HAVE DISK" and install from there. If not, in the left column choose "HP" and in the right column choose "HP LASERJET 3050" (by me it showed up in the list, you can download the driver from here http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1140780&prodTypeId=18972&prodSeriesId=1161389&swLang=8&taskId=135&swEnvOID=228
click "NEXT"
In the "NAME YOUR PRINTER" window, choose a name and also choose if you want to set it as the default printer (recommended) Click "NEXT"
In the next window choose whether or not you want to share the printer, and if you do assign a printer name. Click NEXT. The next window is optional if you want to make a name, you can just click NEXT and your done! Print a test page to make sure that all is fine.
Feb 11, 2008 | HP LaserJet 3055 All-In-One Printer
Hp 3055 all in one
ok DO check my link to setup the network
http://www.fixya.com/support/t391229-hp_laserjet_3055_network_connection
thank you
Dec 14, 2007 | HP LaserJet 3055 All-In-One Printer
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
1,367 people viewed this question
Ben Johnson
