Question about Candy CPCA270FFK Bottom Freezer Refrigerator
Proper temerature for refrigerators and freezing compartments
Refrigerator temperatures
  • 943 Answers
Hi thanks for the question the best temp to have in fridge is 36 degrees and in freezer 0 and minusfor good ice cream thanks the appliance doc
Posted on Sep 27, 2008
Subzero refrigerator/freezer, model 590. Door gaskets replaced last year, but it still ices up in top front of freezer? Any ideas?
Ice or frost in the freezer can be caused by one of Three issues:
    • An improperly closed door.
    • Improper ventilation of the freezer.
    • The Ice Maker Flap.
    1. Door Not Closed Properly
    • Make sure that the freezer door closes completely.
    • Make sure that the door gaskets are attached properly to the door and that they are clean. Also, make sure they are sealing properly and are not torn or split.
    Take a dollar bill and close it in the door. If you can pull the dollar out with no resistance, the seals should be replaced.
    • Make sure there are no packages resting against the rear wall of the freezer.
2. Improper Ventilation
    • Space your food out as much as possible to improve ventilation.
    • Make sure that the air vent in the freezer is not blocked.
    Refrigerator Compartment
    If your refrigerator is freezing food, the temperature is set too low. Raise the temperature a few degrees to fix the problem.
    If your refrigerator temperature is too high, condensation may build up and freeze on the bottom of the refrigerator. Lower the temperature a few degrees to fix the problem.
Dec 06, 2016 | Refrigerators
Too cold
Refrigerators and freezers have a thermostat control inside the refrigerator compartment. It is normally some type of dial with numbers and a graphic indicating warmer or colder.
Place a thermometer inside the cold box. Wait one hour and record the temperature. Adjust the thermostat one or two numbers warmer, then wait 12 hours and record the temperature.
The interior temperature for a refrigerator must be below 40F for food safety. A good range is 35-38F.
Jul 26, 2012 | KitchenAid KBFS25EVMS Stainless Steel...
Amana SZD22MB2L is freezing in refrigerator compartment
I would start with checking that hte air damper that controls air coming from the freezer over to the fridge is working properly. Thats more than likely the issue. Just in case also check that the temperature control is working as designed
May 29, 2012 | Amana Refrigerators
Thermostat question: Does the temerature get
Most refrigerators the higher the setting the colder the output
Jan 14, 2011 | GE 21.7 Cu. Ft. Top-Mount Refrigerator...
Fridge is freezing in the lower part of the fridge...vegetable and meat compartments
have you check the temperature?
The temperature controls are preset in the factory at 37°F for the refrigerator compartment and 0°F for the freezer compartment. Allow 24 hours for the temperature to stabilize to the preset recommended
settings.
Jun 13, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
FRS26H5DSB2 freezer is only freezing bottom shelf, fresh air side
Your model should have an Adaptive defrost control located inside the fresh food compartment. That is the most likely reason for your problems with your defrost problems. If you are able to reset that leaves me curious. To get the proper air circulation we will need to get the defrost working on time, and clean around the condenser below the refrigerator. Once the ADC is replaced the refrigerator should begin to operate more efficiently and these problems will resolve themselves as long as door seals and temperature setting may need to be returned to there normal settings. The part number for the Adaptive Defrost is Part Number 1036287 I will assist you in the repair if you like, Thanks, Sea Breeze
Aug 16, 2009 | Frigidaire FRS26H5AS Side by Side...
Freezes food in refrigerator side
the problem should be with the temerature controller in the refrigerator. ask for the nearest technicain to come and fix it.
May 29, 2009 | Electrolux Refrigerators
Refrigerator not cooling sufficiently/ Freezer not freezing
Yes, if defrost board is bad it will cause problems. Need to listen for fan inside the freezer compartment also. If freezer does not defrost cold air will not circulate properly causing warmer temperatures inside refrigerator. Is model number SXD524VW ?
Let me know, Thanks, Sea Breeze
Mar 26, 2009 | Amana SXD524VW Side by Side Refrigerator
Candy CPCA270FFK Bottom Freezer Refrigerator Logo
171 people viewed this question
Top Candy Refrigerators Experts
Charles T Nevin
Charles T Nevin
Billy Detlefsen
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
