Question about Toshiba MV20FL4 20 in. TV/VCR Combo
Channel problem the tv channel wont get past 13. all the other higher channels are not coming in at all
  • Toshiba Master
  • 520 Answers
Try going into the menu and changing it to the cable setting.
Posted on Sep 27, 2008
When we turn on the TV the channels wont go past 13 not sure why. the other tvs in our house goes up to channels 65 Lost the manual
If the tv was setup with auto tune it will only store the amount of channels(signals) that it can pickup
so if the signal is worse on that outlet it will find and store less channels
May 13, 2011 | Hisense LCD1504 15 in. Television
Skips past all channels after 13. CableVision
I don't know the exact step to set it because I don't know you model TV. When you go to menu set channels it should give you the option to choose cable or air. If you pick cable all your channels will be in VHF which is what you want. If you pick air the first 13 channels will be VHF and the rest will be UHF which cable don't work on. After you pick cable then auto program and you should get all your channels.If this helps you and I hope it does give me a vote please.
Mar 04, 2010 | Televison & Video
My tv won't go past channel 17
Please try this free Philips Flat Panel Television owners manuals, user guides & how to ... A B C D E F G H I J K L M N O P Q R S T U V W X Y Z ... 13" LCD-TV PF7835 - Philips 20" LCD-TV Product Brochure ... 13MC3206 - Magnavox TV/DVD Combination ...
tv.manualsonline.com/manuals/mfg/philips/philips_flat_panel_televis... - 674k - Cached
Aug 21, 2009 | Philips Magnavox 20MS233S 20" TV
Only getting some channels to come in...
Check your latest phone bill and see if you have a basic extended package. If you dont you may have been downgraded to only get basic cable which is 2-13.
The auto program adds every channel that the television can detect.
Jan 04, 2009 | Sanyo DS25390 TV
TV WONT GO PAST CHANNEL 13
Go into your channel setup menu and make sure you selected "cable" and not "air". After selecting "cable", autoprogram the tv
Dec 06, 2008 | Televison & Video
I cant get the tv to go to higher channels
Most tv's have an Antenna mode and a cable mode. If you have cable tv service, the cable mode must be selected in order to receive channels higher than 23. Then you must auto program the channels thru the menu screen on the tv to receive the channels above 23. If you have a house antenna or rabbit ears, its hit or miss on receiving all VHF and UHV channels.
Jan 12, 2008 | RCA 20V500T 20" TV
Cannot watch channels past 13
Your tuner settings must be set on broadcast instead of cable. Below channel 13, they use the same frequencies so it doesn't matter. Find the tuner settings page in the menus and change the cable/air setting.
Jan 06, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Sound and picture distorted only on lower channels
Bad tuner.......they are electronically divided in sections called
bandwidths, i.e. 2-6 , 7-13 so-on.........T.
Give accurate model # / service # for RCA part #............
Nov 06, 2007 | RCA F32450 32" TV
Proscan TV Instruction Need
you wont be able to the high with rabbit ears antenna you will catch the low free channel.you need the cable to get the high channel.so it is est to connect back your cable good luck
May 06, 2007 | Proscan PS32600 32" TV
Remotes not working
well, sometimes the universal remote does not give you the whole functions, so it is better to work with the original one. you could fix it thought. here is how. most of the time, it just need cleaning. so get some denatured alcohol and clean the pc. do not apply any alcohol to the rubber button, that will ruin them. put it back together and give it a try again..good luck
Aug 01, 2006 | Orion STV2763 27" TV
Toshiba MV20FL4 20 in. TV/VCR Combo Logo
227 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
