Question about Cameras
My Sony HC47 camcorder is showing exposed pictures in the viewfinder, I can record indoors but not outdoors because all I get is a white picture , with some scraps where the subjects are darker. It is only just out of warranty, any ideas please? Peter
  • 1 more comment
  • peterofware Sep 27, 2008
    Thanks for quick response, no i tried reseting but it made no difference. Works fine indoors.
    I should add that this problem is intermittent, it has now cleared itself, but this has happened three times now in two days.
  • peterofware Sep 28, 2008
    Hi Welcome Jee,
    No can't say i am a camera repair guru, nasty habit of when opening things up and putting them back finding a bit left over. Is there a simple way of opening it please?
  • 10,594 Answers
1st try to reset your camera, hope problem should be resolve.
If this action doesn't effect, let me know. I will guide you further but it requires to open camera and bring out lens assembly for further check up as it seems aperture and iris problem.
Posted on Sep 27, 2008
  • Shahid Electronics
    Shahid Electronics Sep 27, 2008
    ok, its for sure problem in iris mechanism, part of lens assembly.
    now let me know do you know about camera repair work?
    Shahid Electronics Sep 30, 2008
    No simply way to open it. Lens mechanism requires high skills and as you said, you will find few parts left over after packing up it, so better get use to this intermittent problem... lol
Yashica ez digital 6032- 6 mp camera.. i got one sparingly used yashica camera... with above spec... which shows trouble when taking stil pictures outdoors... indoor pictures and video indoors n outdoors...
i am using yashica ez digital 6032 camera but while using SD card of 4GB memory, it is not working. it is asking to format. Pl. help me regarding this problem. Shall i format the camera?
Apr 27, 2010 | Cameras
Viewfinder and LCD screen only show black and record black
If camcorder shows old recorded tapes picture with correct colors in LCD but does not show live view in camera mode to record new movie then its ccd imager chip failure.
And if camcoder shows live view and old recorded tapes in its eye piece view finder but does not show any thing in LCD the its problem of broekn/ cracked flexible wire between lcd board and main board of camcorder.
Let me know your finding with bit detail to provide you solution/ helpful info.
Nov 18, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
Konica Minolta Dimage E50 suddenly over expose. Indoor at night, the picture looks almost normal. Daytime the wall will be too white. Outdoor the picture is white out.
The shutter cable inside the lens has broken - a common problem with the E50. The cable moves as the lens zoom so it brakes at some point and then camera isn't able to control the shutter - control the amount of light taken. If you look closely at the over exposed pictures, you will notice horizontal lines accross them.
The shutter or whole lens unit has to be changed. It is quite expensive, I believe it's not worth it. You can contact Sony / Konica - Minolta service center.
I work in a Sony / Konica - Minolta service center and have repaired a lot of these.
Hope this helps!
Oct 05, 2009 | Cameras
My camcorder
If you are not getting good color picture then I would advise to perform white balance adjustments in service data with help of concern service manual.
This kind of adjustments required service data handling tools, reference color charts, proper and up to date service manual etc.
Please contact nearest Sony service center for proper fix.
Oct 07, 2008 | Sony Handycam DCR-VX2100 Mini DV Digital...
Outdoor pictures
OVER EXPOSED i think change settings ???
Sep 24, 2008 | Samsung Digimax S500 Digital Camera
Recording problem
Knowledge Article C116445
There is no picture or a black screen appears in the viewfinder or LCD when attempting to record. Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record. NOTES:
  • Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
  • It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
  1. Ensure the lens cap on the front of the camcorder has been removed.
  2. Ensure a fully-charged battery is inserted in the camcorder.
  3. Ensure the STANDBY/LOCK switch is set to the STANDBY position.
  4. Turn on the camcorder and set it to the CAMERA mode.
  5. Look to see if an image can be seen in the viewfinder or LCD.
  6. IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
  7. If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshootin
Nov 30, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Won't record/No picture thru the LCD screen or viewfinder in Record or Standby Mode
it is a common problem with them. sony has a recall on ccd imager for this model. call sony and they will fix it for free
May 29, 2007 | Sony Handycam DCR-TRV22 Mini DV Digital...
No picture in LCD or viewfinder
Flexwire in electronic viewfinder (EVF) is broken, you need pro fix.
May 19, 2007 | Canon GL2 Mini DV Digital Camcorder
LCD and Viewfinder just blank in daylight but working well when indoors or anywhere during night
yes i did have this problem too. sadly i could not figure it out either so i traded with a friend. he found out the problem. he said you have to just leave the camcorder on playback and just let it sit there for about 3 minutes to warm up.
Oct 22, 2006 | Canon Optura 20 Mini DV Digital Camcorder
Cameras Logo
46 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
