Question about Lexmark Office Equipment & Supplies
How do I change the ink cartridge in my Lexmark x2470
    Problem Solver:
  • 4 Answers
Open the cover and you will see a cartidge holder click it and you will open it and change the ink cartidge
Posted on Sep 27, 2008
    Sergeant:
  • 264 Answers
How to Install or Replace the Ink Cartridges in the Lexmark i3 ID: 810 This document does not apply directly to your Lexmark X2470
  1. Make sure that plain paper is loaded in the paper tray.
  2. Ensure that the power light is on.
  3. Open the cartridge door.
    How do I change the - pattlnk_2112005_1715-810_cartridgeinstall1_i3_enfigs.gif
    The cartridge carrier may move slightly, and then return to the loading position.
  4. Push up on the cartridge lever.The cartridge holder springs open.
  5. Remove the old print cartridge and dispose of it.
  6. Remove the sticker and transparent tape from the new print cartridge.
    Warning! Do not touch the gold contact area on the print cartridge.
  7. Install the new print cartridge as illustrated below. Insert the cartridge into the carrier slot. Push the cartridge lever back to secure it under the cartridge hook. Press the cartridge lever down until it snaps into place.
    Insert the color cartridge in the front carrier slot.
    Insert the black cartridge in the back carrier slot.
  8. Close the cartridge door.
  9. On the PC, open the Lexmark i3 Solution Center and click Print Cartridges.
  10. Then click Print Cartridge Installation and follow the on-screen instructions to install the cartridges.
Please Rate the solution.
All the Best
Sammy
4 Suggested Answers
SOURCE: change ink cartridge
I just did it a few minutes ago and it's pretty simple. Just grab the thing right in the center, above the print tray (there's a little handle) and pull the top up. The ink carts will be right in there (towards you, on the right) just pull the one you need to replace out, directly towards you, and then pop the new one in. There are little notches on it so you can't put it in backwards/upside-down or anything, and there's no latch or anything physically holding the cartridges down
Posted on Dec 18, 2007
wayneard
  • 1901 Answers
SOURCE: I cant figure out how to change the ink cartridges on my lexmark
On an X4850 the whole top of the printer opens up to reveal the cartridge carriers. Press down on the latch of each side to reveal the cartridges.
Here is a link to the User guide: X4850 User Guide It is described on page 94.
Posted on Nov 20, 2008
SOURCE: refill ink for Lexmark X4850
I have a couple questions for you.
1. Is your cartidge 42 or 42A? The 42 cartridge will not work if you refill it. I learned that the hard way after paying to have it refilled and I got it home and it would not print. If you are using the 42A refillable cartridge, your ink levels will not reset. I called lexmark to ask them after not bieng able to find any answers online. He said that because I am using the 42A, it will print but will not register the level. The only downside is I have to keep an eye out for fading so that I do not ruin the printer heads.
I hoped this helped.
Posted on Oct 14, 2009
Locating ink cartridge for a 2470 lexmark printer
If you're looking where to purchase cartridges for your Lexmark X2470, it is available in most large office supply stores and online from Lexmark.com. You may also contact the Lexmark Sales Department at 1-800-539-6275.
Aug 11, 2011 | Lexmark X6570 InkJet Printer
Replace ink cartridge
Perhaps the Lexmark X2470 User's Guide will be able to help you. Click on this link to download http://bit.ly/aeFv76. Scroll to page 42 for the instructions on how to install/replace the ink cartridge.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridge. Close the cover. Plug the printer back to power source. Thanks.
Oct 08, 2010 | Lexmark X2470 All-In-One InkJet Printer
Printer Lexmark x2470 doesnt recognize the cartridge anymore.
Good day Sir, I suggest use the Solution Center. to open click start - programs or all programs - Lexmark Solution Center. find the maintenance tab. Maintenance tab help you install print cartridge and troubleshoot other ink problems.
have a nice day.
Jul 29, 2010 | Lexmark X2470 All-In-One InkJet Printer
Hi, replaced ink cartridge on Lexmark X2470. Now it goes as far as the "print alignment page" and freezes. Will not print the alignment page or any other page for that matter. Thanks.
Hello. The ink cartridge may not be seated properly in the carrier. Remove the cartridges from the printer. Close the cover. Clean the nozzles using a damp paper towel. Unplug the printer from the power source. Plug it back in after 10-15 seconds. When the printer asks for the cartridges, reinsert the cartridges. Also, make sure you're using the compatible ink cartridges for the printer. Let it print the alignment page all the way without cancelling it to align the cartridges properly. Hope this helps.
Mar 22, 2010 | Lexmark X2470 All-In-One InkJet Printer
How do i change ink cartridge lexmark 2470
Hello friend,
If you give the middle section of your printer a lift you will notice it opens and inside you will see two slots: one for black ink cartridges and the other for color. Click down and lift the slot you wish to fill with ink and close slot (you should hear a click sound after slot is closed)
Mar 06, 2010 | Lexmark X2470 All-In-One InkJet Printer
How do i change the ink on my lexmark x2470
Changing a print cartridge
Removing a used print cartridge
Make sure the printer is on.
2 Lift the scanner unit.
The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
3 Press down on the lever to raise the cartridge lid.
4 Remove the used print cartridge.
Good luck
Oct 04, 2009 | Lexmark X2470 All-In-One InkJet Printer
How to replace ink cart
Go to this website:
http://www.lexmark.com/publications/pdfs/2007/2400/en.html
You should be able to review the manual and it will show you how to change the ink cartridge.
May 04, 2009 | Lexmark X2470 All-In-One InkJet Printer
Piece to hold in ink broke
went to lexmark.com and chatted with agent , he said i had to replace entire printer. they don't make spare parts! isn't that a bunch of ****!!!
Nov 03, 2008 | Lexmark X2470 All-In-One InkJet Printer
291 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
