Question about Microwave Ovens
GE Microwave Spacesaver shuts down and trips circuit
Today our unit shutoff in the middle of a cooking cycle. It actually tripped the circuit. I reset circuit and tried to operate and it ran for about 5 seconds before tripping circuit again. I did notice that the fan did not seem to be operating and the units motor sound appeared much different (for this small amount of time) and the power lights dimmed just before shutting down. Lights, external fan/blower and clock work fine. Any ideas what problem might be?
  • Microwave Ovens Master
  • 9,098 Answers
I would suspect your high voltage transformer has failed. Here is a link you or someone you know can use for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Posted on Sep 28, 2008
Emerson Microwave MW8115SS --
I would suggest you check the door switches inside the microwave oven just below the keypad, rectangular in shape. The switches are normally open or closed, set meter to ohms, unhook lead from one side and test with door open and closed. If readings are the same both ways the switch is defective. "check all switches"
Mar 19, 2012 | Emerson Fans Emerson MW8115SS Microwave...
We have a GE Profile microwave and every time we open the door it trips the breaker. We turn the breaker back on and use the microwave and as soon as the food is done cooking and we open the door - bam,...
For a breaker to trip, you have to have an over voltage condition that is usually referred to as a short. Since your unit works in the cook cycle and only trips the circuit breaker when you open the door the short has to be in the door latch switch or reset circuit. So it wouldn't be that hard to repair, but since it is 7 years old and not the most energy efficient unit, if you aren't able do the repair yourself, then I would replace it!
You can get an idea of how hard the repair would be by going to the searspartsdirect.com web site and putting in the model # off the ID TAG. Then look for the door latch assembly and that will give you an idea of the cost of the parts and get an idea of how hard it is to replace.
Aug 07, 2011 | Microwave Ovens
GE Spacemaker Microwave JVM1441 BH04 tripping circuit breaker
your power transformer for the magnetron could have a shorted primary power winding,the door safety interlock switch could be mis-adjusted,this normally blows the internal unit fuse,a shorted high voltage capacitor,or diode,a bare wire inside the unit,more than the microwave on that circuit or a weak circuit breaker in the house power panel
Jun 19, 2010 | GE JVM1441 Microwave Oven
The power cuts off after 2 minutes of cooking. The microwave doesnt turn back on for ten minutes.
There is an automatic circuit breaker that it tripping. One of two options
1) Something in your oven is either malfunctioning (difficult to find and replace). It is likely better to just replace than pay to have it fixed.
2) The house circuit that you are using is not providing enough power to the microwave. Check if something else is connected on the same circuit. A microwave runs poorly when not getting the full 115 volts that it was designed for and may fall into a safe mode and shut down for a while.
Newer houses should have the microwave on a dedicated circuit and should not have this problem - I say should not because electricians can make mistakes too.
You can try to trip your microwave circuit and see if anything else stops working. If so, that is likely why your microwave is falling into a safe mode - it is not getting enough juice.
If you have an older home (pre 1995), try to find what else is on your microwave circuit by tripping the breaker as listed above, then not using the other appliance when using the microwave.
Good luck.
Mar 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave JVM1870SK03-NO POWER TO UNIT, PANEL DISPLAYS ARE ALL BLACK, CIRCUIT BREAKER NOT TRIPPED. The oven was actually working, then suddenly in the middle of warming the food, it did quit -...
change the units internal ceramic fuse and try this,may just be a fuse or if new one blows then could be h.v. diode.capacitor,thermal fuse,magnetron tube
Nov 09, 2009 | GE JVM1190 Microwave Oven
My microwave oven shuts down when set at high a high cooking number. I must wait a while before it can used again. I have a GE spacemaker
It may be that your magnetron is overheating, which will trip the magnetron's thermostat, which will interrupt power until it cools down a few minutes later.
Or it may be a defective magnetron causing electrical interference that disrupts the control circuit.
In order to help you, we need your full model number and some further information.
So please post a NEW question, and please include your brand name and the full model number from the tag in or on the unit, as well as the answers to these questions:
- How long does it cook before it shuts down?
- When it shuts down, does it go completely dead, or does it just stop with the display still lit?
- When you try to cook, do the inside light, turntable, and internal cooling fan all come on?
- Is it making any unusual noise?
- Is it louder or quieter than usual?
Oct 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver microwave trips the circuit breaker
Since power = voltage X current, 1.58kW / 120VAC = 13.166A
So this unit should be fine on a 15A breaker unless the breaker is bad, the wiring or a connection is loose somewhere between the breaker and the microwave, or the microwave's magnetron or high voltage transformer are failing and drawing extra current.
Microwaves should really be on the own separate breaker if at all possible. Plus, the more a breaker trips, the more work out it gets.
Have you measured the voltage at the outlet? If that's off, current and power will be affected. It should be about 110-125VAC.
A good power test for outlet and wiring integrity is a toaster, toaster oven, or hair dryer rated at about 1500 watts.
If it doesn't run and heat steadily, then there may be a problem with the house wiring or breaker.
If it passes this test, the problem is likely in the microwave.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 09, 2008 | GE JVM1190 Microwave Oven
Microwave stopped working completely
Fan turned on after cooking because a thermostat got to hot and tripped turning on the fan to try to cool the unit.  The unit went completely dead when thermal fuse tripped which is located above the cavity on the left side.
Oct 30, 2007 | Magic Chef CMV1000B Microwave Oven
Unit Electrical Problem
If it blows the fuse as soon as you hit the START button, it's almost certainly a shorted high-voltage capacitor.
If it blows a few seconds after you hit the START button, it's probably the high-voltage transformer. You'll possibly also smell a faint electrical burning smell from the rear vent after you shut if off.
Microwave can be very dangerous so it is best to have it looked by a professional
Would appreciate a solved rating for expert advise.
Oct 16, 2007 | GE JE1590 Convection / Microwave Oven
Clock Trips
Are you saying that the oven seems to shut off while cooking? Does it also happen if you cook at full power? This may be a bad connection on the controller (which we repair) or a failing magnetron. Please give usd a little more detail so we can follow up.
Sep 23, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
90 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
