GE washer (WHDRR418GWW)(14 MO. OLD)HAS STOPPED AGITATING.WHERE TO LOOK? WHAT TO TRY?
  • 1 more comment
  • FARRGAP Jan 10, 2009
    I JUST STARTED TO HAVE THE SAME PROBLEM LESS THAN 2 YEARS OLD. FILLS DRAINS BUT WILL NOT SPIN OR ADGITATE.THERES POWER AT THE MOTOR,IT'S NOT THE LID SWITCH IT CHECKED OUT "OK".THE TIMER WILL ADVANCE ,FILL& PUMP OUT {ELECTRIC PUMP} .ALSO THE BELT IS GOOD
  • mboy72 Jan 19, 2009
    Same problem. I am 2 weeks within 1 year warranty.
  • Anonymous Mar 30, 2009
    14 month old GE(whdrr418gww) washer does not adgitate or spin.
My washer would fill/drain ok but would not agitate or spin. I unplugged the washer and listened for the motor to click. When the motor clicked I plugged the washer back in. Then I opened and closed the lid 10 times. I turned the washer to the drain/spin position and turned it on. The belt moved back and forth several times and then went into a fast spin.
Posted on Jun 20, 2010
  • janetkeith Nov 28, 2010
    this is for real. i had same problem. thought this was a joke. no joke. it worked. Of course, if it's a choice between tearing your washer apart or calling a tech...or simply trying this...I tried this.
    My washed went into a fast spin and walla... we looked at each other and said, "ain't that some ****!"
Well I know part of the answer and am looking for the exact sequence. Washer has to be reset. Sounds easy but I've had 3 techs tell me how to do it. I've been successful once.
First time I the tech told me how to do it I thought he was yanking my chain. Unplug, wait 60 secs, plug in turn on off 3 times, open and close lid 10 or 12 times, pray twice. Or some thing like that.
Has anybody found any write-up on the sequence?
Posted on May 06, 2009
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
I have a GE washer model # WHDRR418GWW. It is about 19 months old. It stopped agitating and spinning. It will fill with water and the timer/knob will go thru the cycles. But when it reaches the washing...
You have what is called "agitating dogs" there are usually 4 of them at the bottom of the agitator. They have small grippers which lock onto the agitator and agitates. If the washer is ever overfilled or over time filled to heavy this will wear down the nylon teeth on the "dogs". The top of the agitator will spin off, you will see a bolt inside at the bottom, remove bolt and the agitator will pull out. Google "agitating dogs on washer. It will give you pictures for a better understanding. If the belt was broken the washer would not drain, because the belt turns the pump. These dogs are about $5 and honestly easy to install. Good Luck.
Dec 04, 2010 | GE WHDRR418GWW 35 cu. ft. Washer
Not spinning or agitating
Most likely you have a bad belt or a defective lid switch.
Mar 07, 2010 | GE WBSR3140DW Top Load Washer
Washer squeaks really loud while agitating. Drains great 6yr old
Could indeed be the belt or at worst it could be thr main bearing getting dry and gradually seizing up. Hope it,s the belt!!
May 20, 2009 | Washing Machines
GE washer not agitating
when you pulled up agitator was the splined shaft moving back and forth ? If so replace the insert in the agitator. If not the problem is in the transmission .
Dec 11, 2008 | Washing Machines
Need long term soaking for new model whdrr418gww washer
sorry I dont know by the model which washer you have. I would suggest starting washer let it fill with water and then turn it off. If you let it soak overnight I suggest you start by spinning out the load and then starting the wash process over.
Jul 03, 2008 | GE Washing Machines
Washing Machines Logo
779 people viewed this question
Top Washing Machines Experts
