Question about Microwave Ovens
My GE microwave lights won't turn off & won't stop turning
My over-the-range GE microwave lights won't turn off & won't stop turning inside after running it. I have to unplug and plug it back in to stop it. Is this a bad circuit board and something I can fix?
  • bs39 Sep 26, 2008
    My over-the-range GE microwave (JVM1540) lights won't turn off & won't stop turning inside after running it. I have to unplug and plug it back in to stop it. Is this a bad circuit board and something I can fix? -Brett
  • Microwave Ovens Master
  • 8,862 Answers
It sounds like a relay or relay driver on the control board is getting stuck in the on state.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 28, 2008
Ge profile microwave just stopped working doesnt light up or turn on model pvm2070dmbb
You should first check the outlet with a toaster or hair dryer to be sure it's working under a load.
Then you should test the fuse then the TCOs.
There is a technical sheet hidden behind the grille or controls.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
You can download GE owner's manuals and installation instructions here.
Dec 26, 2013 | GE SpaceMaker Microwave Ovens
My GE XL1400 over-the-range Microwave does not power on to cook. The inside light will not turn off when the door is open or closed. Unplugged and re-powered with no change....where to start?
Easy....the reason the light does not go out when the door is closed and the microwave gun is not activating...is due to your door switch not "sensing" it being closed. Sometimes there two electrical switches on the door...yours probably have one and the actuating arm...metal tab on the switch is probably bent and need to be re-bent to sense door closure. Take apart the microwave and re-bent this switch tab...it's relatively easy to find and correct. The door switch might be bad too...won't cost much. 9 times out of 10 it's a bent switch bar.
Oct 31, 2013 | GE Profile Spacemaker Over-the-Range...
GE jvm1653sh01 range lights won't turn off
Got a short at or in the switch assembly that is causing this and unit would have to be unpowered and checked to see if one or both switches are bad.
Oct 29, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave lights up doesn't turn on
The part of the oven called the "magnetron" (this part is what creates/generates the microwave energy that heats the food or liquid) is burned out, the cost to repair is more this part is more than the cost to replace with the cost of Microwaves so depressed by the stagnant economy.
Jan 31, 2012 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
Are there any recalls on GE microwave JVM1540DN1ww Thanks, ssi96@aol.com
There are no recalls on GE over the range microwave JVM1540DN1WW but there SHOULD BE! Mine lasted only a year and a half and then started running and heating with the door open. Shortly after that it stopped heating at all. The light and fan works, and the keyboard lights up but the turntable doesn't turn anymore (yes I made sure the turntable was turned on), and it doesn't heat. It will count down like it's heating but it doesn't heat. Changing the door switches didn't work. Husband thinks it is the magnetron which is expensive to fix. I won't ever buy another GE microwave period! Check the web and you will see all the similar complaints. I just searched online and for a lesser price than I paid for the GE, Samsung sells one that has the one year warranty but also has a 10 year warranty on the magnetron.
Jan 25, 2010 | GE Microwave Ovens
Ge jvm1540dm2ww over the range unit: have a gas range and the fan on the above mounted microwave once in awhile turns on automatically while something is cooking on the range below it....
The heat sensor in the electronics panel senses the rise in heat from the stove below. Once the amount of heat reaches a certain level, the cooling fan turns on to keep the electronics inside the microwave cooled.
I wouldn't worry about it. mine does the same thing.
Jun 19, 2009 | Microwave Ovens
Miocrowave is not heating, item stays cold
hello. I can help you.
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician.
Jun 15, 2009 | GE Spacemaker 1.5 Cu. Ft. Over-the-Range...
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Microwave Ovens Logo
124 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
