Question about Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart Prep 11 Plus Food Processor - Help!
Never-been-used processor won't turn on with either the "pulse "or "on" buttons, even though the power light is on and all the parts have been assembled with a "click' lock.
  • shawniloc Nov 26, 2008
    Brand new custom prep 11 won't work, even though lights are on......help.
Not sure if you found the solution by now but we recently had a similar issue. Make sure the bowl is put on such that the handle is facing the front of the processor. There is a little black button that gets depressed when the lid gets put on. We had to get the thing to work one night and spent hours trying to get the processor on and then trying to get a blender to work before finding the problem.
Hope this helps.
Posted on Nov 28, 2008
  • Lisa Miner
    Lisa Miner Dec 27, 2013
    I am not a stupid person, but boy do I feel stupid! Thank you so much.
Need user manual
Google DLC-2 Mini Prep Plus Food Processor manual and you get https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=DLC-2+Mini+Prep+Plus+Food+Processor+manual
May 03, 2016 | Cuisinart DLC-2 Mini Prep Plus Food...
When the top section is clicked on and on button or pulse or dough button pressed it doesn't go. took top off and pressed the little black button to simulate top being put on and still no result.
Try taking the bowl off and pressing the safety switch with a screw driver. If the processor turns on then you have a problem with the bowl, if it doesn't turn on then the issue is inside of the food processor, and usually internal parts are not available.
If you can find your model & brand information off of the base of the food processor we can look up replacement parts for you.
Thank you,
colleen @ mendingshed.
May 12, 2015 | Food Processors
I have a small Cuisinart food processor and I cannot figure out how to turn it on. It has two levers low and high. I have it plugged in and the lid on? Please help. Fiona Slattery 858-752-8591
Your PowerBlend Duet™ comes with a food processor button. This button is the perfect speed for all your food processing tasks. Always use this speed when using the food processor. You may also use the Pulse button with this function for pulse-chopping.
To use your food processor, make sure that the bowl is assembled properly and the blade or slicing/shredding disc and the cover are locked into place.
When you use the control panel, the LED will light next to each button you press.
Press the On button. For continuous operation, press the Food Processor button. Motor will start if you have followed assembly instructions.
To turn motor off, press the Food Processor button again or the Off button.
For on/off operation, called pulse-chopping or pulsing, press the On button, press the Pulse button, and then press and release the
Food Processor button the desired number of times. Motor runs as long as you hold the Food Processor button down. The motor stops when you release control switch. Try it a few times.
You control the duration and frequency of pulses by the length of time you hold the Food Processor button down and the rate at which you press it. Pulses should be short bursts. Allow enough time between pulses to let food in work bowl fall to bottom.
Always use the Food Processor button for pulse/chopping. Never turn cover back and forth to start and stop processor.
You can download manual from the below link
http://www.cuisinart.com/share/pdf/manuals/bfp-10ch.pdf
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 12, 2009 | Cuisinart Food Processors
Unit assembled, lights are on (pulse, on) nothing happens
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. I am thinking this is an issue of assembly because the light is on, so the unit is definitely getting power.
Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
Jul 19, 2009 | KitchenAid KFP740 Food Processor
Power is available (light is one) but nothing
Sounds like a safety feature working. Unplug. Take apart as if you are going to clean it. Check all parts carefully to see if there is anything broken, like a nub.(Are all parts there?) Put back together, making sure they are fully engaged. Plug in and try. This happened to my food processor and it was a bit of dried food stuck in the bowls sliding track that kept it from clicking fully connected. Hope this helps!
Jul 19, 2009 | Cuisinart DLC-5 Food Processor
Cuisinart dlc-7 superpro food processor won't run.
The DLC-7 SuperPro is awesome -- very powerfull. Be aware they are 1.5 horsepower; the blade can take your hand completely off in a blink of an eye. Because of the potential danger, SAFEGUARDS are in place such that everything must be aligned and in correct position or it WILL NOT POWER-UP. So, yes, is very likely the safety switch.
Simple test: Use just the BASE, (no work bucket, no top, no blades), such that if it starts, only the spindle will turn. There is a little black button on the base, just back of the spindle. Use a chop-stick to depress it. Plug-in, press the button w/chop-stik, press the PULSE button. It should power up.
Presuming it powered up okay, the "problem" is probably in how the unit is assembled; such that the button is depressed properly.
1. The work bowl must be all the way down on the base, and the alignment column in the back, work bowl base skirt turned to the "Hard Stop". It will feel very solid when docked properly.
2. The top inserts and rotates into and snaps into position while pressing the plunger into the button.
It all sounds too easy, but if something is just a little off, the plunger doesn't plunge ind the power doesn't go on.
These are FABULOUS machines -- spend the time into getting it working. The near- equivalent if something this robust and powerful in today's products will cost nearly a THOUSAND dollars - seriously.
May 04, 2009 | Cuisinart DLC-2014 PowerPrep Plus Food...
Can't get cuisenart pro 11 to start
I am assuming you have a DLC-8S Pro Custom 11, and not another Cuisinart food processor.
Remove the work bowl and all other parts completely from base.
Plug the base in, and turn it on.
Use a pen to press in the dark grey or black button on top of the base.
If you hear a spinning or other noise, the motor is still good.
Now that you have verified that the motor is good:
Put each work bowl piece on one at a time - if you don't out it on one at a time, it will not lock in properly.
Put work bowl on with work bowl handle facing front, make sure bowl locks.
Put lid on with hollow feed tube facing the back of the food processor.
Put pusher sleeve into lid's feed tube, with sliding lock switch facing the front of the food processor.
You should now be good to go.
Apr 07, 2009 | Cuisinart DLC-2011 PowerPrep Plus Food...
Put in nuts and turned to mush
It is extremely difficult to chop walnuts in a food processor, because they turn to powder within a few seconds. I have chopped them using both a Cuisinart food processor and a Moulinex La Machine. The difficulty arises because even after you have released the on or chop button, the blade continues to spin for a second or two. The Cuisinart DLC-8S is not particularly well-suited for chopping nuts, because the blade is not reversible - there are many Cuisinarts that do have reversible blades - a particularly good one is the Cuisinart DLC-2A, which has both a reversible blade and a Chop function (retails for about $29.99 to 39.99 nowadays).
The only way to have any success whatsoever with the DLC-8S is to press the pulse button and release immediately - only use a small amount of walntus - and then dump the bowl and add a few more at a time.
Apr 04, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart DLC-8S Pro Custom Food Processor Logo
1,825 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Donni Steen
downhille
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
