Question about Cuisinart DLC-5 Food Processor
Cuisinart Little pro Plus Type 20 - jammed lid won't come off
Dear Friend,
The cover was put on incorrectly so that the bowl fin in the back has slid into its cover groove, but the bowl fin in the front did not slide into its groove and is below the cover. Amazingly enough, the machine chopped the carrot anyway, despite the faulty placement of the cover, but now the cover will not twist off as usual.
At present the bowl has shredded carrot in it, but the cover is jammed closed and the bowl will not remove from the base. I am afraid to force anything -- we all know how fragile that kind of plastic is, especially after many years.
Any ideas or info on how to get the thing apart without breaking anything?
At first I thought there was a release button in the back, but I think not at this point. Do you know of any tricks?
Thanks in advance.
  • Anonymous Mar 04, 2009
    The cuisinart blade is jammed and nothing can seem to unjam it, we even tried forcing it out but that didn't work. What can I do?
4 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: Cuisinat DLC 8 Plus Bowl won't unlock
You have to remove the pusher first by twisting it off. Then press the sides of the pusher sleeve inward and slide the sleeve up and out of place. Then twist off the lid - all twisting on these food processors works either clockwise or counterlcokwise - not both. Then twist the work bowl to the left (clockwise). Voila!
-Tha Mp3 Doctor
Posted on Dec 09, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: How to get bowl off the base
There is no switch or relase - you just have to grip the sides and twist them off the base locks - requires quite a bit of force - not the easiest thing to remove.
Posted on Mar 20, 2009
SOURCE: The plastic clip on the Work Bowl Cover with a feed tube fell off
I just encountered the same problem and cannot figure out how to get the clip back on. Did you ever solve this problem? If so, I would love to know how.
Posted on Feb 07, 2010
Is the Cuisinart DLC 7 Super Pro Manual available to download?
Manuals can be found here:
Food Processors Product Manuals Cuisinart com
You'll have to look around at the options and pick one that looks like the one you have.
If you have an older one, the handle for the bowl generally goes in front, and check the base to see if the button that gets pushed down when the top is in locked position is in the front or the back... and try to match that. The DLC-10s has it in the front (7 cup machine), but many of the larger machines have it in the back. The feed tube matches up with the button when you put the lid on. If you put the lid on with the feed tube 180 degrees off, you can break the lid/bowl getting them apart again.
Getting this right is the most important thing... otherwise they just kind of work. The link for the 7-cup Pro Classic Food Processor (DLC-10s) has really good technique information with color photos. It's worth grabbing regardless of the machine you have.
http://www.cuisinart.com/share/pdf/manuals/dlc-10s.pdf
Other manuals have other recipes... so you might want to download more than one manual.
Jul 03, 2014 | Cuisinart DLC-5 Food Processor
How does the slide lock on the Cuisinard Custom 11 Food Process go back on?
The main important thing if you have an older style machine is to make sure when putting it together that the feed tube from the top aligns with the part of the bowl with the spring, so the button on the base gets depressed correctly. For some, the spring mechanism is on the front with the handle, for some it is opposite the handle... check the base for the tiny button to double check.
If you put the top on backwards it won't work (at least not correctly) -- but what's worse is that you are likely to break the locking mechanism when trying to get it apart... either on the lid, or the bowl, or both. It can be an expensive mistake.
Luckily, bowls and lids are available from Cuisinart... and many times the same bowl/lid was used for different machine numbers (the various models are about the base, not the bowls/lids/blades/etc.)
Dec 15, 2013 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart Processor workbowl lid fitting
Cuisinart DCL-7 replacement work bowl lid is cuisinart dlc-017bgtx work bowl lid fitting with large feed tube.
Jun 05, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
May 11, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Can't get cuisenart pro 11 to start
I am assuming you have a DLC-8S Pro Custom 11, and not another Cuisinart food processor.
Remove the work bowl and all other parts completely from base.
Plug the base in, and turn it on.
Use a pen to press in the dark grey or black button on top of the base.
If you hear a spinning or other noise, the motor is still good.
Now that you have verified that the motor is good:
Put each work bowl piece on one at a time - if you don't out it on one at a time, it will not lock in properly.
Put work bowl on with work bowl handle facing front, make sure bowl locks.
Put lid on with hollow feed tube facing the back of the food processor.
Put pusher sleeve into lid's feed tube, with sliding lock switch facing the front of the food processor.
You should now be good to go.
Apr 07, 2009 | Cuisinart DLC-2011 PowerPrep Plus Food...
Tried to use my powerprep pluss cuisinart food processor and nothing happens. The on button lights up but nothing happens when i press the pulse button.
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the lid lined up with the handle of the work bowl.
Put the pusher sleeve in the lid, with the metal piece facing the front of the processor.
Your processor should now turn on.
If it doesn't call Cuisinart and see if you are still in-warranty (3-year warranty).
-Tha Mp3 Doctor (also loves Cuisinart)
Mar 23, 2009 | Cuisinart DLC-2014 PowerPrep Plus Food...
I put all parts on just do a simple and it won't turn on.
Put the lid on, with the hollow feed tube facing the back of the processor.
Put the pusher sleeve in the lid, with the sliding lock switch facing the front of the processor.
Mar 21, 2009 | Cuisinart DLC-10S Pro Classic Food...
Lid stuck on bowl of my Cuisinart Mini Prep Plus.
Generally they twist off, but on the DLC-2, if the lid won't come off, a replacement bowl and lid is around $18.00
Dec 24, 2008 | Cuisinart DLC-2 Mini Prep Plus Food...
Cuisinart prep 11 Plus won't run.
Remove the work bowl completely and separate the work bowl, lid and pusher sleeve. Plug the base into the wall outlet and press the on switch. Use a pen to depress the dark grey or black button on top of the base of the processor. If you don't hear a sound, then call Cuisinart and get it repaired. If you do hear a sound:
1. Put the work bowl on first, making sure the handle is facing front
2. Put the lid on, making sure the hollow feed tube is facing the back of the food processor
3. Put the pusher sleeve in, making sure the sliding lock switch faces toward the front of the processor
Turn the machine on - it should now be working
-Tha Mp3 Doctor
Cuisinart Prep 11 Plus Food Processor - Help!
Not sure if you found the solution by now but we recently had a similar issue. Make sure the bowl is put on such that the handle is facing the front of the processor. There is a little black button that gets depressed when the lid gets put on. We had to get the thing to work one night and spent hours trying to get the processor on and then trying to get a blender to work before finding the problem.
Hope this helps.
Sep 26, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart DLC-5 Food Processor Logo
233 people viewed this question
Top Cuisinart Food Processors Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
