Computers & Internet Logo
A
Anonymous Posted on Nov 11, 2011
How to insert SIM card into the Apple4 IPhone
Andy
Level 1:
New Friend:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Nov 11, 2011
Andy
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
13
Questions
0
Helped
4044
Points
17
In the side somwhere you have to buy a smaller sim card for it the normal size dont fit.
1helpful
2answers
No Sim Card Installed Insert a valid Sim with no pin lock
3helpful
How do i insert sim card into iphone 4
Hello !
Here is step-by-step tutorial with images, how to insert SIM card into iPhone 4.
http://webtrickz.com/how-to-insert-sim-card-in-iphone-4/
2helpful
How to insert sim card in iphone 3g
Turn off your iPhone 3G and make sure any cords or connector cables are removed from the device. Then, hold your iPhone 3G upright.
  • Locate the Sleep/Wake button and headphone jack on the very top of the iPhone. Between these two components you will see a very small hole.
  • Insert the tip of a paper clip into the hole to release the iPhone's SIM card tray. The small tray will pop up relatively quickly from the top of the iPhone. If there is already a SIM card in the tray, use your fingers to remove it.
  • Insert the SIM card you want to install into the phone facedown in the tray. Make sure the side without the reflecting panel is inserted first.
  • Press the SIM card tray gently back into the slot until you hear it "click" into place. Now turn your iPhone on. All of the information on the card will now be in your iPhone 3G.
  • 0helpful
    How to insert sim card in iphone 4
    Kindly check the link below for step-by-step instructions on inserting SIM card in to an iPhone 4:
    Thank you and good luck!
    2helpful
    How do you open the iphone to insert SIM card?
    You can not open the iphone to insert a SIM card. There is a slot at the bottom of the iPhone and the SIM card goes in there. When you purchased the phone you should also have recieved a special gadget that you actually push into the bottom of the phone so that you can remove the Sim card. That is the only way to access the SIM card on the iPhone... The actual phone can not be opened..
    23helpful
    3answers
    Where to insert sim card in iphone 3gs
    At the top of the iPhone you will see a small hole. Use a paperclip to push in the hole and the sim card try will pop out.
    Put your sim card in the tray and put back in the iPhone
    4helpful
    My iphone can't recognize thr sim card
    remove and re-insert the SIM card when the iphone is off. then, hold the home button while turning the phone on.
    15helpful
    The sim card goes into a slot that is on the top of the phone. Use a paperclip to take the plastic "tray" out of the phone, put the sim card in, then slide it back in.
    Refer to this website for pictures . videos / detailed instructions:
    http://www.iphoneincanada.ca/tips-tricks/how-to-iphone-sim-card-removal/
    Restore &update problem
    what sim card are you trying to use after the restore in itunes and also when you finished the restore in itunes did your iphone come up with a message saying iphone activated?
    go here click here and tell him what has happend this chap is a god with iphones he actually makes his own software etc for iphones.
    Grand Canyon Tech
    Grand Canyon Tech
